Crystal Clock Oscillator Specification
Part No. + Packaging: LFSPXO083343Reel
Customer Part:
Description
LVPECL output crystal oscillator using a high frequency
fundamental crystal to give very low jitter. Hermetically sealed
ceramic package with a seam sealed metal lid.
Model
IQXO-624
Model Issue number
2
Note: Operating temperature ranges -40 to 105°C and -40 to
125°C are intended for industrial use and not for safety critical
applications such as automotive. Please contact IQD for
alternative options.
Frequency Parameters
Frequency
100.0MHz
Frequency Stability
±50.00ppm
Operating Temperature Range
Ageing
-40.00 to 105.00°C
±3ppm max per year @ 25°C
Electrical Parameters
Supply Voltage
Current Draw
3.3V ±5%
Outline (mm)
50.000mA
Output Details
Output Compatibility
Rise and Fall Time
Duty Cycle
Output Voltage Levels:
Output Low (VOL): 1.680V max
Output High (VOH): 2.275V min
LVPECL
0.5ns max
45/55%
Output Control
Standby Operation:
Logic ‘1’ (70% Vs min) to pad 1 enables oscillator output.
Logic ‘0’ (30% Vs max) to pad 1 disables oscillator output.
No connection to pad 1 enables oscillator output due to
internal pull-up resistor.
Standby Current: 10µA max
Start-up Time: 10ms max
Noise Parameters
Phase Jitter (12kHz to 20MHz): 300fs rms max
@100MHz:
155fs rms typ
@125MHz:
132fs rms typ
@156.25MHz: 106fs rms typ
Environmental Parameters
Storage Temperature Range: –55 to 125°C
Shock: 1500G, 0.5ms, 3 times for each surface, total 18 times.
Vibration: Freq. range: 20~2000Hz, peak to peak amplitude:
1.52mm, peak acceleration: 20G (196m/s²), 3 direction(X, Y,Z)
,each cycle: 20min, 4 cycles for each direction.
Manufacturing Details
RoHS Terminations
RoHS Reflow Temp
Au over Ni
260°C max for 10sec mac
Sales Office Contact Details:
UK: +44 (0)1460 270200
USA: +1.760 668 8935
Printed on 10 May 23 12:13 using Part Data Sheet V1.0021
Email: info@iqdfrequencyproducts.com
Web: www.iqdfrequencyproducts.com
Page 1 of 2
Customer Part:
Compliance
RoHS Status (2015/863/EU)
REACh Status
MSL Rating (JDEC-STD-033):
Compliant
Compliant
Not Applicable
Packaging Details
Pack Style: Reel
Pack Size: 3,000
Tape & reel in accordance with EIA-481-D
Alternative packing option available
Page 2 of 2
很抱歉,暂时无法提供与“LFSPXO083343REEL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+70.25400
- 200+28.03680
- 500+27.09720
- 1000+26.63280
