LFXTAL084885
LFXTAL084885
    IQD
    SMD-2
    32.768 kHz ±20ppm 晶体 6pF 2-SMD,无引线
LFXTAL084885 数据手册
Quartz Crystal Specification Part No.: LFXTAL084885 Description 3.2 x 1.5mm SMD crystal in a ceramic package with a seam sealed metal lid, hermetically sealed. Model IQXC-217 Model Issue number 2 Frequency Parameters Frequency 32.7680kHz Frequency Tolerance Tolerance Condition Overtone Order Ageing ±20.00ppm @ 25°C ±5°C Fundamental ±3ppm max in 1st year @ 25°C Electrical Parameters Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 6.00pF 1.5pF max Outline (mm) 0.1µW typ, 0.5µW max 70.00kΩ max Environmental Parameters Storage Temperature Range: –55 to 125°C Drop: 150g dummy, 180cm drop (6 directions x 3 times) onto concrete board Vibration: 1.5mm amplitude, 10Hz-60Hz with cycle time 2-3 minutes in 3 directions (X, Y and Z axis) each for 2 hours Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260°C max for 10s max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Recommended Solder Pad Layout Compliant Not Applicable Packaging Details Tape & reel in accordance with EIA-481 Quantities below the standard reel size to be supplied on cut tape. Standard Quantity: 3,000 Pieces Sales Office Contact Details: UK: +44 (0)1460 270200 USA: +1.760 668 8935 Printed on 2 May 23 23:51 using Part Data Sheet V1.0021 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Quartz Crystal Specification Part No.: LFXTAL084885 Typical Frequency Stability Characteristics Sales Office Contact Details: UK: +44 (0)1460 270200 USA: +1.760 668 8935 Printed on 2 May 23 23:51 using Part Data Sheet V1.0021 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFXTAL084885 价格&库存
很抱歉,暂时无法提供与“LFXTAL084885”相匹配的价格&库存,您可以联系我们找货
LFXTAL084885
  • 3000+4.939073000+0.64207
  • 6000+4.735126000+0.61555
  • 9000+4.619809000+0.60056
  • 15000+4.4786115000+0.58221
库存:10199
LFXTAL084885
  • 1+8.034591+1.04447
  • 10+6.9878510+0.90840
  • 25+6.6107725+0.85938
  • 50+6.3388950+0.82404
  • 100+6.07684100+0.78997
  • 250+5.74632250+0.74701
  • 500+5.50861500+0.71611
  • 1000+5.280781000+0.68649
库存:10199
LFXTAL084885
    • 1+9.75240
    • 200+3.88800
    • 500+3.75840
    • 1000+3.69360
