Features
Applications
● Ultra Stable
● Base Stations
● Wide Temperature Range
● Instrumentations
● SMD(9.0mm*7.0mm)
● Others
Parameter
Supply Voltage
Min.
BO0907L Specifications
Value
Unit
Typ.
Max.
3.3
V
2.5
W
1.0
W
Conditions
Vcc±5%
Power Consumption
Frequency Range
5~50
Nominal Frequency
10, 40
MHz
±500
ppb
At shipment, nominal EFC, +25℃
±5
ppb
-40℃ ~ +70℃
±10
ppb
-40℃ ~ +85℃
VOH
2.7
V
HCMOS Output, Load=15pf
VOL
0.3
V
Duty Cycle
45
55
( VOH - VOL)/2
Rise/Fall edge
5
ns
Load
15
pf
Warm-up Time
3
Min
Supply Sensitivity
±2.0
Load Sensitivity
±2.0
Initial Frequency Tolerance
Freq. Stability Vs. Temp.
HCMOS
At +25℃, with accuracy of ±100ppb
Vcc±5%
Load±5%
ppb
Aging per Day
±2.0
After 30 days of operation
Aging per Year
±500
-110
Offset 10Hz
-135
Offset 100Hz
-150
-155
Offset 10kHz
-155
Offset 100kHz
Control Voltage Range
0.5
1.5
2.5
V
Frequency Turning Range
±0.5
±2.0
ppm
SSB Phase Noise
@10MHz
Tuning Slope
Positive
dBc/Hz
Offset 1kHz
3.3V
At +25℃
Environmental Conditions
Operating Temperature Range
-40℃~+85℃
Storage Temperature Range
-55℃~+125℃
Reliability
Parameter
Condition
Temperature Stress Test
IEC60068, GJB360B
Mechanical Stress Test
IEC60068, GJB360B
EMC Test (ESD)
IEC61000, JESD22
Solder Ability
EIA/JESD22-B102-C
RoHS
RoHS Directive 2011/65/EU Annex II Recasting 2002/95/EC
Outline Dimension & Pin Connections
Ordering Guide
BO 0907 L X X X XXX X X XX.XX
Product
OCXO
Outline
9.0mm x 0.7mm
Freq. Range:
L:
很抱歉,暂时无法提供与“BO0907LH3I208HN40”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1089.472931+140.95241
- 10+951.6381610+123.11980
