BO0907LH3I509HN10
BO0907LH3I509HN10
    XTALTQ(恒晶科技)
    振荡器
BO0907LH3I509HN10 数据手册
Features Applications ● Ultra Stable ● Base Stations ● Wide Temperature Range ● Instrumentations ● SMD(9.0mm*7.0mm) ● Others Parameter Supply Voltage Min. BO0907L Specifications Value Unit Typ. Max. – 3.3 – V – – 2.5 W – – 1.0 W Conditions Vcc±5% Power Consumption Frequency Range 5~50 Nominal Frequency 10, 40 MHz – – ±500 ppb At shipment, nominal EFC, +25℃ ±5 – – ppb -40℃ ~ +70℃ ±10 – – ppb -40℃ ~ +85℃ VOH 2.7 – – V HCMOS Output, Load=15pf VOL – – 0.3 V HCMOS Output, Load=15pf Duty Cycle 45 – 55 % ( VOH - VOL)/2 Rise/Fall edge – – 5 ns HCMOS Output, Load=15pf Load – 15 – pf Warm-up Time – – 3 Min Supply Sensitivity – – ±2.0 Load Sensitivity – – ±2.0 Initial Frequency Tolerance Freq. Stability Vs. Temp. HCMOS At +25℃, with accuracy of ±100ppb Vcc±5% Load±5% ppb Aging per Day – – ±2.0 After 30 days of operation Aging per Year – – ±500 After 30 days of operation – – -110 Offset 10Hz – – -135 Offset 100Hz – – -150 – – -155 Offset 10kHz – – -155 Offset 100kHz Control Voltage Range 0.5 1.5 2.5 V Frequency Turning Range ±0.5 – ±2.0 ppm SSB Phase Noise @10MHz Tuning Slope Positive dBc/Hz Offset 1kHz 3.3V At +25℃ Environmental Conditions Operating Temperature Range -40℃~+85℃ Storage Temperature Range -55℃~+125℃ Reliability Parameter Condition Temperature Stress Test IEC60068, GJB360B Mechanical Stress Test IEC60068, GJB360B EMC Test (ESD) IEC61000, JESD22 Solder Ability EIA/JESD22-B102-C RoHS RoHS Directive 2011/65/EU Annex II Recasting 2002/95/EC Outline Dimension & Pin Connections Ordering Guide BO 0907 L X X X XXX X X XX.XX Product OCXO Outline 9.0mm x 0.7mm Freq. Range: L:
BO0907LH3I509HN10 价格&库存
很抱歉,暂时无法提供与“BO0907LH3I509HN10”相匹配的价格&库存,您可以联系我们找货
BO0907LH3I509HN10
    • 1+1089.472931+140.95241
    • 10+951.6381610+123.11980
    库存:10
