Features
Applications
Ultra Stable
Wide Temperature Range
SMD Package (5.2×3.4mm)
Provide Stratum Ⅲ Level Frequency Stability
Base Stations
Instrumentations
Synthesizer
SDH/SONET
Medical Electronics
BT0503C Specifications
Parameter
Supply Voltage
Supply current
Frequency Range
Nominal Frequency
Max.
3.3
V
5
V
8
mA
10MHz~26MHz(including26MHz)
12
10~52
10, 12.8, 13, 15.36, 16, 16.32,
16.384, 19.2, 20, 24.576, 25, 26,
30.72, 40, 50
mA
26MHz~60MHz
Unit
Conditions
MHz
MHz
±0.3
±0.5
±1
ppm
At shipment, nominal EFC, +25℃
±0.05
±0.5
ppm
-20℃~+70℃
±0.1
±0.5
ppm
-40℃~+85℃
±0.2
±1.0
ppm
-50℃~+90℃
±0.5
±1.0
ppm
-55℃~+95℃(except for 10MHz)
0.8
10kΩ//10pF
Vp-p
2.4
V
HCMOS Output, Load=15pf
VOL
0.4
V
Duty Cycle
45
55
( VOH - VOL)/2
Rise/Fall Edge
6
ns
15
pf
ps
Initial Frequency Tolerance
Freq. Stability Vs. Temp.
Output Level
Clipped
Sine Wave Load
VOH
HCMOS
Min.
Value
Typ.
Load
RMS Jitter(By E5052B)
0.4
1.3
Supply Sensitivity
±0.1
Load Sensitivity
±0.2
Aging/ First Year
±1.0
Standard
-92
Offset 10Hz
-120
-140
-145
Offset 10kHz
1.5 ± 1.0
-150
Offset 100kHz
positive
±12
ppm
10
SSB Phase Noise
@10MHz
Control Voltage Range
Frequency Turning Range
Tuning Slope
Non-linearity
±5
12KHz~5MHz
Vcc±5%
ppm
Load±5%
Offset 100Hz
dBc/Hz
Offset 1kHz
At +25℃
V
Phase Noise @1KHz
Frequency Range
很抱歉,暂时无法提供与“BT0503CH3I106EN10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+71.139561+9.20380
