BT0503CH3I507EN10
BT0503CH3I507EN10
    XTALTQ(恒晶科技)
    SMD6
    振荡器 10 MHz HCMOS TCXO 3.3V 6-SMD,无引线
BT0503CH3I507EN10 数据手册
Features ● ● ● ● Applications ● ● ● ● ● Ultra Stable Wide Temperature Range SMD Package (5.2×3.4mm) Provide Stratum Ⅲ Level Frequency Stability Base Stations Instrumentations Synthesizer SDH/SONET Medical Electronics BT0503C Specifications Parameter Supply Voltage Supply current Frequency Range Nominal Frequency Max. – 3.3 – V – 5 – V – – 8 mA 10MHz~26MHz(including26MHz) – 12 10~52 10, 12.8, 13, 15.36, 16, 16.32, 16.384, 19.2, 20, 24.576, 25, 26, 30.72, 40, 50 mA 26MHz~60MHz Unit – Conditions MHz MHz ±0.3 ±0.5 ±1 ppm At shipment, nominal EFC, +25℃ ±0.05 – ±0.5 ppm -20℃~+70℃ ±0.1 – ±0.5 ppm -40℃~+85℃ ±0.2 – ±1.0 ppm -50℃~+90℃ ±0.5 – ±1.0 ppm -55℃~+95℃(except for 10MHz) 0.8 – 10kΩ//10pF – Vp-p 2.4 – – V HCMOS Output, Load=15pf VOL – – 0.4 V Duty Cycle 45 – 55 % HCMOS Output, Load=15pf ( VOH - VOL)/2 Rise/Fall Edge – – 6 ns HCMOS Output, Load=15pf – – 15 pf ps Initial Frequency Tolerance Freq. Stability Vs. Temp. Output Level Clipped Sine Wave Load VOH HCMOS Min. Value Typ. Load RMS Jitter(By E5052B) 0.4 – 1.3 Supply Sensitivity – – ±0.1 Load Sensitivity – – ±0.2 Aging/ First Year – – ±1.0 Standard – – -92 Offset 10Hz – – -120 – – -140 – – -145 Offset 10kHz – – 1.5 ± 1.0 -150 Offset 100kHz – positive ±12 ppm – 10 % SSB Phase Noise @10MHz Control Voltage Range Frequency Turning Range Tuning Slope Non-linearity ±5 – 12KHz~5MHz Vcc±5% ppm Load±5% Offset 100Hz dBc/Hz Offset 1kHz At +25℃ V Phase Noise @1KHz Frequency Range
BT0503CH3I507EN10 价格&库存
很抱歉,暂时无法提供与“BT0503CH3I507EN10”相匹配的价格&库存,您可以联系我们找货
