BT0507BH3I106DN20
BT0507BH3I106DN20
    XTALTQ(恒晶科技)
    SMD10
    振荡器 20 MHz HCMOS TCXO 3.3V 10-SMD,无引线
BT0507BH3I106DN20 数据手册
Features ● ● ● ● Applications ● ● ● ● ● Ultra Stable Wide Temperature Range SMD Package (7.0×5.0mm) Provide Stratum Ⅲ Level Frequency Stability Base Stations Instrumentations Synthesizer SDH/SONET Medical Electronics BT0507B Specifications Parameter Supply Voltage Supply Current Frequency Range Nominal Frequency Min. Value Typ. Max. – 3.3 – – 5 – V – – 8 mA 10MHz~26MHz(Including 26MHz) – 12 10 ~ 52 10, 12.8, 13, 15.36, 16, 16.32, 16.384, 19.2, 20, 24.576, 25, 26, 30.72, 40, 50 mA 26MHz~60MHz Unit Conditions V – MHz MHz – – ±0.5 ppm At shipment, nominal EFC, +25℃ ±0.05 – ±0.5 ppm -20℃~+70℃ ±0.1 – ±0.5 ppm -40℃~+85℃ ±0.2 – ±1.0 ppm -50℃~+90℃ ±0.5 – ±1.0 ppm -55℃~+95℃(except for 10MHz) 0.8 – 10kΩ//10pF – Vp-p 2.4 – – V HCMOS Output, Load=15pf VOL – – 0.4 V Duty Cycle 45 – 55 % HCMOS Output, Load=15pf ( VOH - VOL)/2 Rise/Fall Edge – – 6 ns HCMOS Output, Load=15pf – – 15 pf 0.4 – 1.3 ps Supply Sensitivity – – ±0.1 Load Sensitivity – – ±0.2 Aging/ First Year – – ±1.0 Standard – – -95 Offset 10Hz – – -120 – – -140 – – -145 – – 1.5 ± 1.0 -150 – ±12 ppm 10 % Initial Frequency Tolerance Freq. Stability Vs. Temp. Output Level Clipped Sine Wave Load VOH HCMOS Load RMS Jitter(By E5052B) SSB Phase Noise @10MHz Control Voltage Range Frequency Turning Range ±5 Tuning Slope Non-linearity 12KHz~5MHz Vcc±5% ppm Load±5% Offset 100Hz dBc/Hz Offset 1kHz At +25℃ Offset 10kHz Offset 100kHz V positive – –
BT0507BH3I106DN20 价格&库存
很抱歉,暂时无法提供与“BT0507BH3I106DN20”相匹配的价格&库存,您可以联系我们找货
