Features
Applications
Ultra Stable
Wide Temperature Range
SMD Package (7.0×5.0mm)
Provide Stratum Ⅲ Level Frequency Stability
Base Stations
Instrumentations
Synthesizer
SDH/SONET
Medical Electronics
BT0507B Specifications
Parameter
Supply Voltage
Supply Current
Frequency Range
Nominal Frequency
Min.
Value
Typ.
Max.
3.3
5
V
8
mA
10MHz~26MHz(Including 26MHz)
12
10 ~ 52
10, 12.8, 13, 15.36, 16, 16.32,
16.384, 19.2, 20, 24.576, 25, 26,
30.72, 40, 50
mA
26MHz~60MHz
Unit
Conditions
V
MHz
MHz
±0.5
ppm
At shipment, nominal EFC, +25℃
±0.05
±0.5
ppm
-20℃~+70℃
±0.1
±0.5
ppm
-40℃~+85℃
±0.2
±1.0
ppm
-50℃~+90℃
±0.5
±1.0
ppm
-55℃~+95℃(except for 10MHz)
0.8
10kΩ//10pF
Vp-p
2.4
V
HCMOS Output, Load=15pf
VOL
0.4
V
Duty Cycle
45
55
( VOH - VOL)/2
Rise/Fall Edge
6
ns
15
pf
0.4
1.3
ps
Supply Sensitivity
±0.1
Load Sensitivity
±0.2
Aging/ First Year
±1.0
Standard
-95
Offset 10Hz
-120
-140
-145
1.5 ± 1.0
-150
±12
ppm
10
Initial Frequency Tolerance
Freq. Stability Vs. Temp.
Output Level
Clipped
Sine Wave Load
VOH
HCMOS
Load
RMS Jitter(By E5052B)
SSB Phase Noise
@10MHz
Control Voltage Range
Frequency Turning Range
±5
Tuning Slope
Non-linearity
12KHz~5MHz
Vcc±5%
ppm
Load±5%
Offset 100Hz
dBc/Hz
Offset 1kHz
At +25℃
Offset 10kHz
Offset 100kHz
V
positive
很抱歉,暂时无法提供与“BT0507BH3I106EN10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+75.662441+9.78896
