Features
Applications
● Low Phase Noise
● Wide Temperature Range
● SMD Package (7.0×5.0mm)
Base Stations
Instrumentations
Synthesizer
SDH/SONET
Medical Electronics
BT0507E Specifications
Parameter
Supply Voltage
Supply Current
Min.
Value
Typ.
Max.
3.3
5
V
3
10 ~ 52
8
mA
Frequency Range
MHz
±0.5
ppm
At shipment, nominal EFC, +25℃
±0.05
±0.5
ppm
-20℃~+70℃
±0.05
±0.5
ppm
-40℃~+85℃
±0.2
±1.0
ppm
-50℃~+90℃
±0.5
±1.0
ppm
-55℃~+95℃
Output Level
0.8
Vp-p
Load
VOH
10kΩ//10pF
Freq. Stability Vs. Temp.
CMOS
V
±0.05
Initial Frequency Tolerance
Clipped Sine
Wave
Conditions
MHz
10, 12.8, 13, 15.36, 16, 16.32,
16.384, 19.2, 19.44, 20, 24.576, 25,
26, 30.72, 38.4, 38.88, 40, 50
Nominal Frequency
Unit
2.4
V
LVCMOS Output, Load=15pf
VOL
0.4
V
Duty Cycle
45
55
( VOH - VOL)/2
Rise/Fall Edge
6
ns
15
pf
0.4
1.3
ps
Supply Sensitivity
±0.1
Load Sensitivity
±0.2
Load
RMS Jitter(By E5052B)
Aging/ First Year
SSB Phase Noise
@10MHz
Vcc±5%
ppm
Load±5%
±1.0
±0.3
±0.8
Customized
-105
Offset 10Hz
-130
Offset 100Hz
-150
-155
1.5 ± 1.0
-158
±12
ppm
10
Control Voltage Range
Frequency Turning Range
12KHz~5MHz
±5
Tuning Slope
dBc/Hz
Standard
Offset 1kHz
Offset 10kHz
Offset 100kHz
V
positive
Non-linearity
Phase Noise @1KHz
Freq. Range
很抱歉,暂时无法提供与“BT0507EC3I107EN40B”相匹配的价格&库存,您可以联系我们找货
