BT0507EC3I207EN40B
BT0507EC3I207EN40B
    XTALTQ(恒晶科技)
    振荡器
BT0507EC3I207EN40B 数据手册
Features Applications ● Low Phase Noise ● Wide Temperature Range ● SMD Package (7.0×5.0mm) ● ● ● ● ● Base Stations Instrumentations Synthesizer SDH/SONET Medical Electronics BT0507E Specifications Parameter Supply Voltage Supply Current Min. Value Typ. Max. – 3.3 – – 5 – V 3 – 10 ~ 52 8 mA Frequency Range MHz – ±0.5 ppm At shipment, nominal EFC, +25℃ ±0.05 – ±0.5 ppm -20℃~+70℃ ±0.05 – ±0.5 ppm -40℃~+85℃ ±0.2 – ±1.0 ppm -50℃~+90℃ ±0.5 – ±1.0 ppm -55℃~+95℃ Output Level 0.8 – Vp-p Load VOH – 10kΩ//10pF Freq. Stability Vs. Temp. CMOS V ±0.05 Initial Frequency Tolerance Clipped Sine Wave Conditions MHz 10, 12.8, 13, 15.36, 16, 16.32, 16.384, 19.2, 19.44, 20, 24.576, 25, 26, 30.72, 38.4, 38.88, 40, 50 Nominal Frequency Unit 2.4 – – V LVCMOS Output, Load=15pf VOL – – 0.4 V Duty Cycle 45 – 55 % LVCMOS Output, Load=15pf ( VOH - VOL)/2 Rise/Fall Edge – – 6 ns LVCMOS Output, Load=15pf – – 15 pf 0.4 – 1.3 ps Supply Sensitivity – – ±0.1 Load Sensitivity – – ±0.2 Load RMS Jitter(By E5052B) Aging/ First Year SSB Phase Noise @10MHz Vcc±5% ppm Load±5% – – ±1.0 ±0.3 – ±0.8 Customized – – -105 Offset 10Hz – – -130 Offset 100Hz – – -150 – – -155 – – 1.5 ± 1.0 -158 – ±12 ppm 10 % Control Voltage Range Frequency Turning Range 12KHz~5MHz ±5 Tuning Slope dBc/Hz Standard Offset 1kHz Offset 10kHz Offset 100kHz V positive – Non-linearity – Phase Noise @1KHz Freq. Range
BT0507EC3I207EN40B 价格&库存
很抱歉,暂时无法提供与“BT0507EC3I207EN40B”相匹配的价格&库存,您可以联系我们找货
BT0507EC3I207EN40B
    • 1+323.399701+41.84039
    • 10+281.1336010+36.37214
    • 25+265.9323225+34.40545
    • 50+254.9943750+32.99033
    • 100+244.52177100+31.63542
    • 250+242.72908250+31.40349
    库存:10
