Features
Applications
● Ultra Stable
● Low Phase Noise
● SMD Package(9.35*14.65mm)
Parameter
Base Stations
Instrumentations
Synthesizer
SDH/SONET
BT0914A Series Specifications
Value
Unit
Min.
Typ.
Max.
3.3
5
45
10 ~ 125
10, 20, 40, 50,100,122.88,125
±0.3
±0.5
±1
V
mA
MHz
MHz
ppm
±0.20
±0.5
±2
ppm
±0.20
±0.5
±2
ppm
±0.10
±2
ppm
±0.28
±0.5
±2
ppm
7
2.4
50
-30
-70
dBm
dBc
dBc
Ω
V
VOL
0.4
V
Duty Cycle
45
55
HCMOS Output, Load=15pf
( VOH - VOL)/2
Rise/Fall Edge
6
ns
Load
15
pf
RMS Jitter(By E5052B)
fs
Supply Sensitivity
Load Sensitivity
Aging/ First Year
-77
±0.1
±0.2
±1.0
-75
-112
-110
-142
-140
-158
-155
-163
1.5 ± 1.0
-158
Supply Voltage
Current with Output
Frequency Range
Nominal Frequency
Initial Frequency Tolerance
Conditions
Freq. Stability Vs. Temp.
Sine
wave
HCMOS
Output Level
Harmonics
Spurious
Load
VOH
SSB Phase Noise
@10MHz
Control Voltage Range
Frequency Turning Range
Tuning Slope
Linearity
±5
Positive
ppm
At shipment, nominal EFC, +25
-20℃~+70℃
*Height≥4mm
-40℃~+85℃
*Height≥4mm
-40℃~+85℃
*Height≥7mm
-50℃~+85℃
*Height≥6mm
12KHz~5MHz
Vcc±5%
Load±5%
Standard
Offset 10Hz
Offset 100Hz
dBc/Hz
V
ppm
10
Offset 1kHz
At +25℃
Offset 10kHz
Offset
100kHz
Phase Noise @1KHz
Frequency Range
10MHz~20MHz(Including
20MHz)
20MHz~100MHz(Including
100MHz)
>100MHz
很抱歉,暂时无法提供与“BT0914AH3I106EN100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+732.270621+94.73876
- 10+636.7833110+82.38492
- 25+608.6057725+78.73941
