BT0914AS3I106EN100
BT0914AS3I106EN100
    XTALTQ(恒晶科技)
    SMD6
    振荡器 100 MHz 正弦波 TCXO 3.3V 6-SMD,无引线
BT0914AS3I106EN100 数据手册
Features Applications ● Ultra Stable ● Low Phase Noise ● SMD Package(9.35*14.65mm) Parameter ● ● ● ● Base Stations Instrumentations Synthesizer SDH/SONET BT0914A Series Specifications Value Unit Min. Typ. Max. 3.3 – 5 – – 45 10 ~ 125 10, 20, 40, 50,100,122.88,125 ±0.3 ±0.5 ±1 V mA MHz MHz ppm ±0.20 ±0.5 ±2 ppm ±0.20 ±0.5 ±2 ppm ±0.10 – ±2 ppm ±0.28 ±0.5 ±2 ppm 7 – – – 2.4 – – – 50 – – -30 -70 – – dBm dBc dBc Ω V VOL – – 0.4 V Duty Cycle 45 – 55 % HCMOS Output, Load=15pf ( VOH - VOL)/2 Rise/Fall Edge – – 6 ns HCMOS Output, Load=15pf Load – – 15 pf RMS Jitter(By E5052B) 20 – 40 fs Supply Sensitivity Load Sensitivity Aging/ First Year – – – – – – – -77 ±0.1 ±0.2 ±1.0 -75 – -112 -110 – -142 -140 – -158 -155 – -163 1.5 ± 1.0 -158 Supply Voltage Current with Output Frequency Range Nominal Frequency Initial Frequency Tolerance – – – Conditions Freq. Stability Vs. Temp. Sine wave HCMOS Output Level Harmonics Spurious Load VOH SSB Phase Noise @10MHz Control Voltage Range Frequency Turning Range Tuning Slope Linearity ±5 – – Positive – ppm At shipment, nominal EFC, +25 -20℃~+70℃ *Height≥4mm -40℃~+85℃ *Height≥4mm -40℃~+85℃ *Height≥7mm -50℃~+85℃ *Height≥6mm HCMOS Output, Load=15pf 12KHz~5MHz Vcc±5% Load±5% Standard Offset 10Hz Offset 100Hz dBc/Hz V – ppm 10 % Offset 1kHz At +25℃ Offset 10kHz Offset 100kHz Phase Noise @1KHz Frequency Range 10MHz~20MHz(Including 20MHz) 20MHz~100MHz(Including 100MHz) >100MHz
BT0914AS3I106EN100 价格&库存
很抱歉,暂时无法提供与“BT0914AS3I106EN100”相匹配的价格&库存,您可以联系我们找货
