BV0507DH3I155E030N100
    XTALTQ(恒晶科技)
    SIP4
    振荡器 100 MHz HCMOS VCXO 3.3V 振幅控制 4-SMD,无引线
BV0507DH3I155E030N100 数据手册
Features Applications ● High frequency & Low Noise ● SMD Package (7.0×5.0mm) ● Quick Warm-up ● ● ● ● ● Low vibration RF Communication Wireless Communication Low Phase Noise Signal Resource SDH/SONET GNSS BV0507D Specifications Parameter Supply Voltage Supply Current Value Typ. Max. – 3.3 – – 5 – Unit Conditions V Vcc±5% V Vcc±5% – 30 10 ~ 156.52 40,80, 100, 120, 122.88 ±10 ±12 ±15 MHz MHz ppm 20 Frequency Range Nominal Frequency Freq. Stability Vs. Temp. CMOS Min. mA -40℃~+85℃ CMOS Output, Load=15pf VOH 2.4 – – V VOL – – 0.4 V Duty Cycle 45 – 55 % CMOS Output, Load=15pf ( VOH - VOL)/2 Rise/Fall Edge – – 3 ns CMOS Output, Load=15pf Load RMS Jitter(By E5052B) – – 15 pf 20 – 45 fs Supply Sensitivity – – ±0.1 Load Sensitivity – – ±0.2 Aging/ First Year ±0.3 – ±1.0 Standard – -80 -75 Offset 10Hz – -112 -110 – -142 -140 Offset 100Hz dBc/Hz Offset 1kHz – -158 -155 Offset 10kHz – -160 0~3.3 -158 SSB Phase Noise @100MHz Control Voltage Range Frequency Turning Range ±20 Non-linearity – – Vcc±5% ppm -40℃~+85℃ Storage Temperature Range -55℃ ~ +125℃ At +25℃ Offset 100kHz 10 ppm % Environmental Conditions Operating Temperature Range Load±5% V ±30 ±40 positive Tuning Slope 12KHz~5MHz At +25℃ Outline Dimension & Pin Connections Package D: Maximum Ratings Parameter Symbol Rating Supply Voltage Vdd -0.5V / 6V Control Voltage Vcon 0V / 3V ESD, HBM/CDM/MM 4KV/ 2KV/ 200V Reliability Parameter Condition Temperature Stress Test IEC60068, GJB360B Mechanical Stress Test IEC60068, GJB360B EMC Test (ESD) IEC61000, JESD22 Solderability EIA/JESD22-B102-C Contact Pads Gold over Nickel RoHS RoHS Directive 2011/65/EU Annex II Recasting 2002/95/EC Ordering Guide BV 0507D X X X XXX X XXXX XX.XX Product: VCXO Outline: 7.0 × 5.0mm Output: H: CMOS Frequency: xx MHz e.g.: 100 (100MHz) Tuning Range: XXXN: XXX ppm Min. eg: 020N Supply Voltage: 3: 3.3 V 5: 5.0 V Phase Noise: C: -130dBc/Hz@1kHz D: -135dBc/Hz@1kHz E: -140dBc/Hz@1kHz Temp. Range: C: -20℃~+70℃ I: -40℃~+85℃ Stability vs. Temp. 155: ±15ppm Example: BV0507DH3I155E020N100
BV0507DH3I155E030N100 价格&库存
很抱歉,暂时无法提供与“BV0507DH3I155E030N100”相匹配的价格&库存,您可以联系我们找货
  • 1+308.624771+39.92885
