BV0914AP3I155D030N100
    XTALTQ(恒晶科技)
    振荡器
BV0914AP3I155D030N100 数据手册
Features Applications ● Ultra Stable ● Low Phase Noise ● SMD Package(9.2×14.2mm) Parameter Supply Voltage Output Current Frequency Range Nominal Frequency Freq. Stability Vs. Temp. VOH VOL LVPECL Duty Cycle Rise/Fall Edge Load Vpp Vos LVDS OE Function ● Low phase noise signal source ● Wireless Communication System ● Low jitter RF Communication ● GNSS BV0914A Series Specifications Value Unit Min. Typ. Max. – – – 3.3 – 5 – 30 – 40 ~ 150 80;100;120;122.88 ±10 ±12 ±15 1.86 – 2.11 1.06 – 1.31 45 50 55 – 0.2 1 – – 50 250 350 450 V V mA MHz MHz ppm V V % ns Ω dbm 1.125 1.25 1.375 dBc Duty Cycle 45 – 55 dBc Rise/Fall Edge – 0.2 1 ns Load – – 100 Ω Enable 2 Disable RMS Jitter(By E5052B) Supply Sensitivity Load Sensitivity Aging/ First Year SSB Phase Noise @100MHz Control Voltage Frequency Turning Range Tuning Slope Linearity 200 – – – – – – – – ±20 – V 0.4 V – 700 – +0.2 – +0.2 – ±1.0 –78 -75 -112 -110 -140 -135 -150 -145 -155 -150 0~3.3 ±30 ±40 Positive – 10 fs ppm dBc/Hz V ppm % Environmental Conditions Operating Temperature Storage Temperature Range -40℃ ~ +85℃ -55℃ ~ +105℃ Conditions Vcc ±5% Vcc ±5% -40℃~+85℃ CMOS Output, Load=15pf CMOS Output, Load=15pf 20%~80% Vdd Vcc -2V or equivalent Kelvin Conneactions ( VOH - VOL)/2 20%←→80% Pin 2 no connection or Vdd>2V 12KHz~5MHz@100MHz Vcc ±5% ±5% load change Offset 10Hz Offset 100Hz Offset 1kHz Offset 10kHz Offset 100kHz at 25℃ At shipment, nominal EFC, +25℃ Outline Dimension & Pin Connections * Height 4mm or 6mm is availble and 2.5mm can be customized. Maximum Ratings Parameter Supply Voltage Control Voltage ESD, HBM/CDM/MM Rating -0.5V / 6V 0V / 3V 4KV/ 2KV/ 200V Symbol Vdd Vcon Reliability Parameter Temperature Stress Test Mechanical Stress Test EMC Test (ESD) Solder Ability Contact Pads RoHS Condition IEC60068, GJB360B IEC60068, GJB360B IEC61000, JESD22 EIA/JESD22-B102-C Gold over Nickel RHOS Directive 2011/65/EU Annex II Recasting 2002/95/EC Ordering Guide BV 0914A X X X XXX X XXXX XX.XX Product: VCXO Frequency in MHz Outline: 14.65mm×9.35mm Tuning Range: XXXN: XXX ppm Min. eg: 020N Output: P: LVPECL D:LVDS Phase Noise: C: -130dBc/Hz@1kHz D: -135dBc/Hz@1kHz E: -140dBc/Hz@1kHz Supply Voltage: 3: 3.3 V 5: 5.0 V Example: BV0914AP5I155D010N100 Stability vs. Temp. 155: ±15ppm Temp. Range: C: -20℃~+70℃ I: -40℃~+85℃
BV0914AP3I155D030N100 价格&库存
很抱歉,暂时无法提供与“BV0914AP3I155D030N100”相匹配的价格&库存,您可以联系我们找货
