BV0914BH3I155E030N100 数据手册
Features
Applications
● Ultra Stable
● Low Phase Noise
● SMD Package(9.2×14.2mm)
Parameter
Supply Voltage
Output Current
Frequency Range
Nominal Frequency
Freq. Stability Vs. Temp.
VOH
VOL
CMOS
Duty Cycle
Rise/Fall Edge
Load
Output Level
Sine Wave
● Low phase noise signal source
● Wireless Communication System
● Low jitter RF Communication
● GNSS
BV0914B Series Specifications
Value
Unit
Min.
Typ.
Max.
3.3
5
30
40 ~ 150
80;100;120;122.88
±10
±12
±15
2.4
0.4
45
50
55
6
15
7
V
V
mA
MHz
MHz
ppm
V
V
ns
pf
dbm
-30
dBc
-70
dBc
Harmonious
Spurious
Load
RMS Jitter(By E5052B)
Supply Sensitivity
Load Sensitivity
Aging/ First Year
SSB Phase Noise
@100MHz
Control Voltage
Frequency Turning Range
Tuning Slope
Linearity
Vcc±5%
Vcc±5%
-40℃~+85℃
CMOS Output, Load=15pf
90%~10% Vdd
50ohm
±20
40
+0.2
+0.2
±1.0
–80
-75
-112
-110
-142
-140
-155
-158
-160
-160
0~3.3
±30
±40
Positive
10
fs
ppm
dBc/Hz
V
ppm
Environmental Conditions
Operating Temperature
Storage Temperature Range
Conditions
-40℃ ~ +85℃
-55℃ ~ +105℃
12KHz~5MHz
Supply voltage varied ±5% at 25℃
±5% load change
Offset 10Hz
Offset 100Hz
Offset 1kHz
Offset 10kHz
Offset 100kHz
at 25℃
At shipment, nominal EFC, +25℃
Outline Dimension & Pin Connections
Maximum Ratings
Parameter
Supply Voltage
Control Voltage
ESD, HBM/CDM/MM
Rating
-0.5V / 6V
0V / 3V
4KV/ 2KV/ 200V
Symbol
Vdd
Vcon
Reliability
Parameter
Temperature Stress Test
Mechanical Stress Test
EMC Test (ESD)
Solder Ability
Contact Pads
RoHS
Condition
IEC60068, GJB360B
IEC60068, GJB360B
IEC61000, JESD22
EIA/JESD22-B102-C
Gold over Nickel
RHOS Directive 2011/65/EU Annex II Recasting 2002/95/EC
Ordering Guide
BV 0914B X X X XXX X XXXX XX.XX
Product:
VCXO
Frequency in MHz
Outline:
14.65mm×9.35mm
Tuning Range:
XXXN: XXX ppm Min.
eg: 020N
Output:
H: CMOS
S:Sine Wave
Phase Noise:
C: -130dBc/Hz@1kHz
D: -135dBc/Hz@1kHz
E: -140dBc/Hz@1kHz
Supply Voltage:
3: 3.3 V
5: 5.0 V
Example: BV0914BH5I155E010N100
Stability vs. Temp.
155: ±15ppm
Temp. Range:
C: -20℃~+70℃
I: -40℃~+85℃
BV0914BH3I155E030N100 价格&库存
很抱歉,暂时无法提供与“BV0914BH3I155E030N100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+226.713051+29.33139
- 10+197.0377210+25.49209
- 25+186.3686425+24.11176
- 50+178.6919350+23.11857
- 100+171.34172100+22.16763
- 250+162.66370250+21.04489
