CBL-C58ES-BL-AM
CBL-C58ES-BL-AM
    GRANDMAX
    CABLE CAT5E 8COND 24AWG 1000
CBL-C58ES-BL-AM 数据手册
Y.C. CABLE EAST, INC. SPECIFICATION: CBL-C58ES-XX-AM Description: Length Per Reel: UL File No.: UL Specification: Flame Test: Other Standards: Compliances: Conductors: Insulation: Shielding: Jacket: CAT.5E, STRANDED, SHIELDED, 4PR, 24AWG, PVC 1000 feet E213738 CMR FT4 ANSI/TIA-568-C.2, ISO/IEC 11801, UL444 RoHS and REACH Bare Copper, Stranded 24 AWG (7/0.193mm) HD-PE. Diameter 1.05 ± 0.03mm Mylar, AL Foil and Drain Wire CMR-PVC. Diameter 6.0 ± 0.3mm Tel.: 732-868-0800 ♦ Fax: 732-868-0810 ELECTRICAL CHARACTERISTICS Temperature Rating: -20°C - 75°C Spark Test: 2000 ± 250 VOC Dialectric Strength: AC-750V/1 sec. MIN Insulation Resistance: PE:DC-500V 1500MΩ / 100M MIN at 20°C Mutual Capacitance: 5600pF / 100m MAX Capacitance Unbalance: 330pF / 100m MAX Conductor Resistance: MAX 8.76Ω / 100m at 20°C Resistance Unbalance: 3% Max Impedance: 100 ± 15Ω General Cable Marking: Grandmax E213738-Y 24AWG 4PR STRANDED CMR (UL) C(UL) STP CAT5E FT4 350MHz CONFORM TO ANSI/TIA-568-C.2 & ISO/IEC 11801 75°C ROHS REACH COMPLAINT ORDERING PART NUMBER: CBL - C58E S - XX - AM 1 Pair No. 1 2 3 4 Pair Color Code Blue / White-Blue Orange / White-Orange Green / White-Green Brown / White-Brown Revision Date: 05.23.2017 (BB) 1. 2. 3 4. 2 3 4 CBL: Bulk Cable C58E: CAT.5e Stranded Series S: Shielded Cable XX Color: BK (black), GY (gray), PR (violet), RD (red), WT (white), YL (yellow), BL (blue), GN (green), OG (orange), PK (pink)
CBL-C58ES-BL-AM
- 物料型号:CBL-C58ES-XX-AM - 器件简介:这是一种符合CAT.5E标准的、24AWG、4对、双绞线、屏蔽型电缆,外层为PVC材质,每卷长度为1000英尺。 - 引脚分配:文档中列出了4对颜色编码的导线,分别是蓝/白-蓝、橙/白-橙、绿/白-绿和棕/白-棕。 - 参数特性: - 温度等级:-20°C至75°C - 火花测试:2000 ± 250V - 介电强度:AC-750V/1秒 - 绝缘电阻:PE:DC-500V 1500MΩ/100M,最小值在20°C - 电容不平衡:330pF/100m,最大值 - 导体电阻:最大8.76Ω/100m,在20°C - 电阻不平衡:最大3% - 阻抗:100 ± 15Ω - 功能详解:电缆符合UL规格CMR FT4和其他标准,如ANSI/TIA-568-C.2和ISO/IEC 11801,并且符合RoHS和REACH环保要求。 - 应用信息:适用于高速数据传输,符合高速局域网(LAN)的需求。 - 封装信息:电缆的外层为CMR-PVC材质,直径6.0 ± 0.3mm,内部包含裸铜导体、HD-PE绝缘、麦拉膜、铝箔和排水线。
CBL-C58ES-BL-AM 价格&库存
很抱歉,暂时无法提供与“CBL-C58ES-BL-AM”相匹配的价格&库存,您可以联系我们找货
