CBL-C61ES-WT-AM
CBL-C61ES-WT-AM
    Y.C.CABLE
    CAT6 SLD SHIELDED WHITE 1000
CBL-C61ES-WT-AM 数据手册
Y.C. CABLE EAST, INC. SPECIFICATION: CBL-C61ES-XX-AM Description: Length Per Reel: UL File No.: UL Specification: Flame Test: Other Standards: Compliances: Conductors: Insulation: Shielding: Jacket: CAT.6, SOLID, SHIELDED, 4PR, 24AWG, PVC 1000 feet E213738 CMR FT4 ANSI/TIA-568-C.2, ISO/IEC 11801, UL444 RoHS and REACH Bare Copper, Solid 24 AWG HD-PE. Diameter 1.0±0.02mm Mylar, AL Foil and Drain Wire CMR-PVC. Diameter 6.3 ± 0.2mm Tel.: 732-868-0800 ♦ Fax: 732-868-0810 ELECTRICAL CHARACTERISTICS Temperature Rating: -20°C - 75°C Spark Test: 2000 ± 250 VOC Dialectric Strength: AC-750V/1 sec. MIN Insulation Resistance: PE:DC-500V 1500MΩ / 100M MIN at 20°C Mutual Capacitance: 5600pF / 100m MAX Capacitance Unbalance: 330pF / 100m MAX Conductor Resistance: MAX 9.38Ω / 100m at 20°C Resistance Unbalance: 5% Max Impedance: 100 ± 15Ω General Cable Marking: Grandmax E213738-Y 24AWG 4PR SOLID CMR (UL) C(UL) STP CAT6 FT4 550MHz CONFORM TO ANSI/TIA-568-C.2 & ISO/IEC 11801 75°C ROHS REACH COMPLAINT ORDERING PART NUMBER: CBL - C61E S - XX - AM 1 1. 2. 3 4. Pair No. 1 2 3 4 Pair Color Code Blue / White-Blue Orange / White-Orange Green / White-Green Brown / White-Brown Revision Date: 05.23.2017 (BB) 2 3 4 CBL: Bulk Cable C63E: CAT.6 Solid Series S: Shielded Cable XX Color: BK (black), GY (gray), PR (violet), RD (red), WT (white), YL (yellow), BL (blue), GN (green), OG (orange), PK (pink)
CBL-C61ES-WT-AM 价格&库存
很抱歉,暂时无法提供与“CBL-C61ES-WT-AM”相匹配的价格&库存,您可以联系我们找货
