MHP-25PTA52-5K6
MHP-25PTA52-5K6
    YAGEO(国巨)
    插件,D1.8xL6.2mm
    RES 5.6K OHM 1/4W .02% AXIAL
MHP-25PTA52-5K6 数据手册
Approval Sheet for Metal Film High Precision Resistors MHP series ±0.02% & ±0.05% YAGEO CORPORATION Headquarters: 3F, No.233-1, Pao Chiao Rd., Hsin Tien, Taipei, Taiwan, R.O.C. Tel: 886-2-2917-7555 Fax: 886-2-2917-4286 Hsin Tien Plant: 3F, No.5, Lane 560, Chung Cheng Rd., Hsin Tien Taipei, Taiwan, R.O.C Tel: 886-2-2218-2139 Fax: 886-2-6629-8898 URL: www.yageo.com Page-1 Rev. Description Issue Date Drawn Approved 00 issue new spec. Sep 13, 2007 Lynn Chen Joyce Chung 01 Revise the dimensions of MHP-25 and Jun 25,2010 Feng Ye Ken Hsu Rev. 01 MHP-50 series. Description Metal Film High Precision Resistors Series MHP Page-2 1. PRODUCT: Metal film high precision resistors, painting color is blue. 2. PART NUMBER: Part number of the metal film high precision resistor is identified by the name, power, tolerance, packing, temperature coefficient, special type and resistance value. Example: MHP -25 A T B 73- 100R (1) (2) (3) (4) (5) (6) (7) Series Power Resistance Packing Temperature Special Resistance Name Rating Tolerance Style Coefficient Type Value of Resistance (1) Style: MHP SERIES (2) Power Rating: -25=1/4W 、-50=1/2W (3) Tolerance: = P=± 0.02%、A=± 0.05% (4) Packaging Type: B =Bulk Packing (5) Temperature Coefficient:A=5PPM (6) Special Type: B=10PPM 73- = 73m m (7) Resistance Value:E192 Series Example: 1R、10R、100R、10K、100K、330K、1M… … Page-3 3. BAND-CODE: MHP-25 PA 0R1 4. ELECTRICAL CHARACTERISTICS STYLE MHP-25 MHP-50 Power Rating at 70 ℃ 1/4W 1/2W Maximum Working Voltage 250V 300V Maximum Overload Voltage 500V 600V Dielectric Withstanding Voltage 450V 900V Resistance Range 1Ω ~ 5MΩ for E192 series value Operating Temp. Range - 65 ℃ to + 150 ℃ Temperature Coefficient ± 5 ppm /℃ , ± 10 ppm /℃ ※ 5. Below or over this resistance range on request. DERATING CURVE Rated Load (%) 70℃ 100 80 60 40 20 -65 125 150 180 Ambient Temperature (℃ ) Page-4 6. DIMENSIONS ψd L H ψD STYLE 7. DIMENSION ψD H ψd Normal L MHP-25 6.2± 0.3 1.8±0.3 36± 2.0 0.63± 0.05 MHP-50 9.1±0.3 2.1±0.3 36± 2.0 0.63± 0.05 ENVIRONMENTAL CHARACTERISTICS (1) Short Time Over Load Test At 2.5 times of the rated voltage. ( If the voltage exceeds the maximum load voltage, the maximum load voltage will be used as the rated voltage ) applied for 5 seconds, the resistor should be free from defects after the resistor is released from load for about 30 minutes Short Time Overload Voltage = 2.5 * Power Rating × Resistance Value The change of the resistance value should be within ± 0.25 % + 0.05Ω (2) Dielectric Withstanding Voltage The resistor is placed on the metal V Block. Apply a Table I dielectric withstanding between the terminals connected together with the block for about 60 seconds. The resistor shall be able to withstand without breakdown or flashover. (3) Temperature Coefficient Test Test of resistors above room temperature 85°C ±1°C at the constant temperature silicon plate for over 1 hour at an ambient temperature 165°C. Then measure the resistance value. The Temperature Coefficient is calculated by the following equation and its value should be within the range of requested. Re sistor Temperature Coefficient = R R0 t to (4) R − R0 1 × × 10 6 R0 t − t0 = Resistance value under the testing temperature = Resistance value at the room temperature = The testing temperature = Room temperature Insulation Resistance Apply test terminal on lead and resistor body. The test resistance should be high than 10,000M ohm. Page-5 (5) Resistance to Solvent The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 1 minute. The specimen is no deterioration of coatings and color code. (6) Terminal Strength Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the direction of the longitudinal axis of the resistor unit the applied load reached 2 pounds 。 The load shall be held for 5 seconds. The load of weight shall be ≧ 0.9 kg ( 9N ). (7) Load Life in Humidity Place the specimen in a test chamber at -10 °C+ 65 °C and 80 ~ 98 % relative humidity. Apply the rated voltage to the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 240 hours. The change of the resistance value shall be within ± 0.5 % + 0.05 Ω (8) Load Life Test Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90 minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for 1000+48/ -0 hours then left at no -load for 1hour, measured at this time the resistance value。 The change of the resistance value shall be within ± 1.0 % + 0.05 Ω. There shall be no remarkable change in the appearance and the color code shall be legible after the test. (9) Temperature Cycling Test The temperature cycle shown in the following table shall be repeated 5 times consecutively. The measurement of the resistance value is done before the first cycle and after ending the fifth cycle, leaving in the room temperature for about 0.5 hour。 Temperature Cycling Conditions: Step 1 2 3 4 Temperature(°C) -55 ± 3 25 ± 3 155 ± 3 25 ± 3 Time (minute) 30 2~3 30 2~3 The change of the resistance value shall be within ± 0.015 % + 0.05 Ω After the test the resistor shall be free from the electrical or mechanical damage. (10) Resistance to Soldering Heat The terminal lead shall be dipped into the solder pot at 350 ± 10 °C for 3 ± 0.5 seconds up to 2 ~ 2.5 mm. The change of the resistance value shall be within ± 0.1 % + 0.05 Ω Page-6 10. Plant Address: A. Taiwan Hsin Tien Plant 3F, No.5, Lane 560, Chung Cheng Road, Hsin Tien Taipei, Taiwan, ROC (台北縣新店市中正路 560 巷 5 號 3 樓 ) Tel. 886 -2-2218-2139 Fax. 886-2-6629-8898 B. China Dongguan Plant 7-1, Gaoli Road, Gaoli Industrial Zone Tangxia Zhen, Dongguan, Guangdong, China (廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號) Tel. 86-769-772 0275 Fax. 86-769-772 0295 C. China Mudu Plant No.158, Fengjiang Road, Mudu New District, Suzhou, Kiangsu, China (江蘇省蘇州木瀆新區楓江路 158 號) Tel. 86-512-6651 8889 Fax. 86-512-6651 9889 Page-7
MHP-25PTA52-5K6
物料型号:MHP系列,包括MHP-25和MHP-50型号。
器件简介:金属膜高精度电阻器,涂有蓝色油漆。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性: - 功率等级:MHP-25为1/4瓦,MHP-50为1/2瓦。 - 容差:±0.02%和±0.05%。 - 最大工作电压:MHP-25为250V,MHP-50为300V。 - 最大过载电压:分别为500V和600V。 - 介质耐压:900V。 - 电阻范围:E192系列值,1Ω至5MΩ。 - 工作温度范围:-65℃至+150℃。 - 温度系数:±5ppm/℃和±10ppm/℃。
功能详解:文档中未提供具体的功能详解
应用信息:文档中未提供具体的应用信息
封装信息:提供了MHP-25和MHP-50的尺寸信息,包括长度、直径、高度和引脚直径。
MHP-25PTA52-5K6 价格&库存
很抱歉,暂时无法提供与“MHP-25PTA52-5K6”相匹配的价格&库存,您可以联系我们找货
MHP-25PTA52-5K6
  • 3000+62.904333000+8.15360
