NCR-25KT-52-4K7
NCR-25KT-52-4K7
    YAGEO(国巨)
    轴向
    4.7 kOhms ±10% 0.25W,1/4W 轴向 通孔电阻器 阻燃涂层,非电感,安全 炭膜
NCR-25KT-52-4K7 数据手册
Through-hole resistors Non-Inductive & Flame-Proof Type Carbon Film Resistors Normal & Miniature Style [ NCR Series ] FEATURES Power Rating 1/4W, 1/2W, 1W, 2W, 3W Resistance Tolerance ±5%, ±10% T.C.R. see Table 1 Flameproof Multi-layer Coating Meets UL-94V-0 Flameproof Feature Meets Overload Test UL-1412 INTRODUCTION DERATING CURVE The NCR Series Carbon Film Non-Inductive & Flame-Proof Resistors are manufactured by coating a homogeneous film of pure carbon on high grade ceramic rods. Tinned connecting leads of electrolytic copper are welded to the end-caps. The inductance is 1,000MΩ Solderability IEC 60115-1 4.17 235±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥2.5kg (24.5N) Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±1.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±3.0%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV for 1,000 Hr. (1.5 Hr. on, 0.5 Hr. off) ±3.0%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±1.0%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±1.0%+0.05Ω Accidental Overload Test IEC 60115-1 4.26 4 times RCWV for 1 Min. No evidence of flaming or arcing Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 201304
NCR-25KT-52-4K7
物料型号:NCR系列碳膜电阻器,包括标准尺寸和迷你尺寸。
器件简介:NCR系列碳膜非感性防火电阻器通过在高等级陶瓷棒上涂覆纯碳的均匀薄膜制造而成,端盖焊接了镀锡的电解铜连接引线。电感量小于1μH。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 功率等级:1/4W, 1/2W, 1W, 2W, 3W - 电阻公差:±5%, ±10% - 温度系数:见表1 - 防火多层涂层符合:UL-94V-0 - 防火特性符合过载测试:UL-1412
功能详解: - 电阻器在70°C以上的环境温度下工作时,需要根据下面的曲线降额使用。 - 电阻器涂有灰色漆(标准尺寸)和粉红色漆(迷你尺寸)。
应用信息:文档中未明确提供应用信息
封装信息: - 尺寸单位:毫米 - 标准尺寸和迷你尺寸的详细尺寸数据。
NCR-25KT-52-4K7 价格&库存
很抱歉,暂时无法提供与“NCR-25KT-52-4K7”相匹配的价格&库存,您可以联系我们找货
