Approval Sheet
for
Cement Resistors
Power Wirewound & Axial / Vertical
Lead Type
PSP & PSM series
±5% & ±10%
YAGEO CORPORATION
Headquarters: 3F, No.233-1, Pao Chiao Rd., Xindian, Taipei, Taiwan, R.O.C.
Tel: 886-2-6629-9999 Fax: 886-2-6628-8885
URL: www.yageo.com
Page-1
Rev.
Description
Issue Date
Drawn
Approved
00
issue new spec.
Feb 12, 2008
Lynn Chen
Joyce Chung
01
Series adjustment
Sep 1, 2008
Lynn Chen
Joyce Chung
02
Product marking information is included
Dec 3, 2010
Feng Ye
Ken Hsu
03
Electrical characteristics table and
environmental characteristics are
adjusted
Revise dimension map
Dec 29, 2010
Feng Ye
Ken Hsu
Dec 06, 2012
Feng Ye
Flora Shen
Revise dimensions of PSM700,
PSM7WS and PSM 900 series.
Revise maps of derating curve and
dimensions
PSP11A, PSP17A, PSM11A, PSM17A
are included.
Taped in reel is included, add packing
info.
Dec 12, 2012
Feng Ye
Flora Shen
Feb 21, 2013
Feng Ye
Ken Hsu
Jul. 07, 2016
Feng Ye
Flora Shen
Jul. 19, 2016
Feng Ye
Flora Shen
04
05
06
07
08
Description
Cement Resistors-Power Wirewound & Axial/Vertical Lead Type
Series
PSP&PSM
Rev.
Page-2
08
1.
PRODUCT:
1. Power Wirewound Resistors. Fiber Glass Core and with Ceramic Case. Wirewound
construction, Insulated and Flameproof
(PSP & PSM SERIES)
2.
PART NUMBER:
Part number of the cement resistor is identified by the name, power, tolerance, packing,
temperature coefficient and resistance value.
Example:
PSP
400
J
B
100R
(1)
(2)
(3)
(4)
(5)
(6)
Series Power Resistance Packing Temperature Resistance
Name Rating Tolerance Style
Coefficient
Value
of Resistance
(1) Style: PSP SERIES: Axial Type
PSM SERIES: Vertical Type
(2) Power Rating: 400=4W、500=5W、7WS=7W、700=7W、900=9W、11A=11W、
17A=17W
(3) Tolerance: J = ±5%、K = ±10%
(4) Packaging Type: B = Bulk Packing
R = Taped in reel
(5) Temperature Coefficient : ±400ppm/℃
(6) Resistance Value:E24 Series
Example:0R1, 1R、10R、100R、10K……
Page-3
3.
ELECTRICAL CHARACTERISTICS
STYLE
Power Rating at 70 ℃
Max. Cont. Work. Voltage
PSP400
4W
Resistance range
Operating Temp. Range
0.1~2.2KΩ
±400ppm/℃
STYLE
PSM400
4W
Resistance range
0.1~2.2KΩ
±400ppm/℃
PSP500
5W
PSP7WS
7W
PSP700
PSP900
9W
PSP11A
11W
PSP17A
17W
P70 R
0.1~2.5KΩ 0.5~3.9KΩ
1~10KΩ
- 55 ℃ to + 275 ℃
PSM500
5W
PSM7WS
7W
PSM700
PSM900
9W
PSM11A
11W
PSM17W
17W
P70 R
0.1~2.5KΩ 0.5~3K9Ω
1~10KΩ
- 55 ℃ to + 275 ℃
* Below or over this resistance range on request
4.
DERATING CURVE
For resistors operated in ambient temperatures above 70℃, power rating must be derated in accordance with
the curve below.
Rated Load (%)
70℃
275℃
100
80
60
40
20 40 60 80 100 120 140 160 180 200 220 240 260 280
Ambient Temperature (℃)
Page-4
5.
DIMENSIONS
Yageo logo
PSP Series
Produce date
Resistance
Value
Power
Tolerance
PSM Series
PSM400-PSM700
Unit:mm
TYPE
L1
W
H
PSP400
20±1.0
6.4 ± 0.3
6.4 ± 0.3
PSP500
25±1.0
6.4 ± 0.3
6.4 ± 0.3
PSP700
38±1.0
6.4 ± 0.3
6.4 ± 0.3
PSP7WS
25±1.0
9.0 ± 0.3
9.0 ± 0.3
PSP900
38±1.0
9.0 ± 0.3
9.0 ± 0.3
PSP11A
50±1.5
9.0 ± 0.3
9.0 ± 0.3
PSP17A
75±2.0
9.0 ± 0.3
9.0 ± 0.3
TYPE
L1
W
H
PSM400
20±1.0
7.0 ± 0.5
8.0 ± 0.4
PSM500
25±1.0
7.0 ± 0.5
8.0 ± 0.4
PSM700
38±1.0
7.0 ± 0.5
8.0 ± 0.4
PSM7WS
25±1.0
9.0 ± 0.4
10.0 ± 0.4
PSM900
38±1.0
9.0 ± 0.4
10.0 ± 0.4
PSM11A
50±1.5
9.0 ± 0.4
10.0 ± 0.4
PSM17A
75±2.0
9.0 ± 0.4
10.0 ± 0.4
Page-5
PSM7WS-PSM17A
6.
ENVIRONMENTAL CHARACTERISTICS
(1) Short Time Over Load Test
At 2.5 times of the rated voltage applied for 5 seconds, the resistor should be free from defects after the
resistor is released from load for about 30 minutes
Short Time Overload Voltage =
2.5 * Power Rating Resistance Value
The change of the resistance value should be within ± 2.0 % + 0.05Ω
(2) Voltage Proof
The resistor shall be clamped in the trough of a 90° metal V Block. Apply the insulation voltage of 1000V
between the terminals connected together with the block for about 60 seconds.
The resistor shall be able to withstand without breakdown or flashover.
(3) Temperature Coefficient Test
Test of resistors above room temperature 100°C ± 2°C ( Testing Temperature 115°C to 130°C ) at the
constant temperature silicon plate for over 5 minutes. Then measure the resistance value.
The Temperature Coefficient is calculated by the following equation and its value should be within the
range of requested.
Re sistor Temperature Coefficient
R
R0
t
to
R R0
1
10 6
R0
t t0
= Resistance value under the testing temperature
= Resistance value at the room temperature
= The testing temperature
= Room temperature
(4) Insulation Resistance
Apply "measuring voltage" between protective coating and termination for 1 min.,then measure. The
measuring voltage shall be either 100V±15V d.c. for resistors with an insulation voltage lower than 500V
or 500V±50V d.c. for resistors with an insulatin voltage equal to or greater than 500V.
The test resistance should be high than 1,000M ohm.
(5) Solderability
Immerse the specimen into the solder pot at 235 ± 5 °C for 3 ± 0.5 seconds.
At least 90% solder coverage on the termination.
(6) Solvent Resistance of Marking
The specimen into the appropriate solvent of IPA condition of ultrasonic machine for 5± 0.5 minutes.
The specimen is no deterioration of coatings and color code.
(7) Robustness of Terminations
Direct Load – Resistors shall be held by one terminal and the load shall be gradually applied in the
direction of the longitudinal axis of the resistor unit the applied load reached the requirement.
The load shall be held for 10 seconds. The load of weight shall be ≧ 2.5 kg ( 24.5N ).
Page-6
(8) Periodic-pulse Overload
Apply 4 times of rated voltage to the specimen at the 1 second on and 25 seconds off cycle, subjected
to voltage application cycles specified in 10,000 time。
The change of the resistance value shall be within ± 2.0% + 0.05 Ω
(9) Damp Heat Steady State
Place the specimen in a test chamber at 40 °C and 93 % relative humidity. Apply the rated voltage to
the specimen at the 1.5 hours on and 0.5 hour off cycle. The total length of test is 1,000 hours
The change of the resistance value shall be within ± 5.0 % + 0.05 Ω
(10) Endurance at 70 °C
Placed in the constant temperature chamber of 70 ± 3 °C the resistor shall be connected to the lead wire
at the point of 25mm. Length with each terminal, the resistors shall be arranged not much effected
mutually by the temperature of the resistors and the excessive ventilation shall not be performed, for 90
minutes on and 30 minutes off under this condition the rated D.C. voltage is applied continuously for
1000+48/-0 hours then left at no-load for 1hour, measured at this time the resistance value。
The change of the resistance value shall be within ± 5.0 % + 0.05 Ω .
There shall be no remarkable change in the appearance and the color code shall be legible after the test.
(11) Temperature Cycling Test
The temperature cycle shown in the following table shall be repeated 5 times consecutively. The
measurement of the resistance value is done before the first cycle and after ending the fifth cycle,
leaving in the room temperature for about 1 hour。
Temperature Cycling Conditions:
Step
Temperature(°C)
Time (minute)
1
-55 ± 3
30
2
25 ± 3
10 ~ 15
3
155 ± 3
30
4
25 ± 3
10 ~ 15
The change of the resistance value shall be within ± 2.0 % + 0.05 Ω
After the test the resistor shall be free from the electrical or mechanical damage.
(12) Resistance to Soldering Heat
The terminal lead shall be dipped into the solder pot at 260 ± 3 °C for 10 ± 1.0 seconds up to 2.5 ~ 3.5
mm.
The change of the resistance value shall be within ± 1.0 % + 0.05 Ω
(13) Overload Flame Retardant
At 4 times of the rated voltage. ( If the voltage exceeds the maximum load voltage, the maximum load
voltage will be used as the rated voltage ) applied for 1 minute
Overload Test Voltage =
4 * Power Rati ng Resistance Value
The resistor shall be able to no evidence of flaming arcing
Page-7
7.
PACKING
Bulk
TYPE
Packing
Pieces
Pack. Code
TYPE
Packing
Pieces
PSP400
200
PSM400
200
PSP500
200
PSM500
200
PSP700
200
PSM700
200
PSP7WS
Bulk
200
PSM7WS
B
Bulk
200
PSP900
200
PSM900
200
PSP11A
100
PSM11A
200
PSP17A
100
PSM17A
100
Tape/Reel
Only for PSP type
TYPE
Packing
PSP400
PSP500
PSP700
PSP7WS
PSP900
Taped in
Reel
C
S
1000
95
10
1000
95
10
95
10
500
95
10
500
95
10
Pieces
1000
Pack. Code
R
Page-8
Pack. Code
B
8.
Plant Address
A.
China Dongguan Plant
7-1, Gaoli Road, Gaoli Industrial Zone
Tangxia Zhen, Dongguan, Guangdong, China
(廣東省東莞市塘廈鎮高麗工業區高麗路 7-1 號)
Tel. 86-769-8772 0275
Fax. 86-769-8772 0275 #4333
B.
China Suzhou Plant
No.158, Jinchang Road, No.1 Building of Nan Bang IND. Zone,
Mu Du New District, Suzhou, China
(江蘇省蘇州市木瀆新區金長路 158 號南濱工業區 1 號)
Tel. 86-512-66518889
Fax. 86-512-66519889
Page-9
