EYW06015012LL-12
EYW06015012LL-12
    YSTECH(仁新科技)
    Q-SERIES FAN LOW SPEED W/PWM
EYW06015012LL-12 数据手册
EYW06015 SERIES 60x60x15mm Noise Level Max. Airflow Speed Operating Voltage Range P-Q Curve 24 CFM 14.1 18.0 20.9 14.1 18.0 20.9 23.5 27.0 14.1 18.0 20.9 23.5 27.0 14.1 18.0 20.9 23.5 14.1 18.0 20.9 23.5 Life at 40 o C L10 12 RPM 3300 4100 4800 3300 4100 4800 5300 6100 3300 4100 4800 5300 6100 3300 4100 4800 5300 3300 4100 4800 5300 Power Consumption 05 VDC 4 ~5.5 4 ~5.5 4 ~5.5 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 Current VDC L L L 2B 2B 2B 2B 2B L L L L L 2B 2B 2B 2B L L L L Max. Static Pressure Model No. EYW06015005LL EYW06015005LM EYW06015005LH EYW06015012BL EYW06015012BM EYW06015012BH EYW06015012BS EYW06015012BSS EW06015012LL EYW06015012LM EYW06015012LH EYW06015012LS EYW06015012LSS EYW06015024BL EYW06015024BM EYW06015024BH EYW06015024BS EYW06015024LL EYW06015024LM EYW06015024LH EYW06015024LS Rated Voltage Bearing Airflow: 14.1~27.0 CFM Static Pressure: 2.0~6.5 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1007 #26 AWG Weight: 33.5 g mm-H 2 O 2.0 3.0 3.9 2.0 3.0 3.9 5.0 6.5 2.0 3.0 3.9 5.0 6.5 2.0 3.0 3.9 5.0 2.0 3.0 3.9 5.0 mA 130 200 360 55 100 130 150 230 70 100 130 150 260 25 40 55 70 25 40 55 70 W 0.65 1.00 1.80 0.66 1.20 1.56 1.80 2.76 0.84 1.20 1.56 1.80 3.12 0.60 0.96 1.32 1.68 0.60 0.96 1.32 1.68 Hour 50000 50000 50000 80000 80000 75000 65000 65000 50000 50000 50000 50000 50000 80000 80000 75000 65000 50000 50000 50000 50000 5 4 3 5 4 3 2 1 5 4 3 2 1 5 4 3 2 5 4 3 2 dB(A) 22.0 28.4 33.0 22.0 28.4 33.0 35.0 38.0 22.0 28.4 33.0 35.0 38.0 22.0 28.4 33.0 35.0 22.0 28.4 33.0 35.0 2B: 2-ball bearing L: sintetico bearing S: sleeve bearing Voltage Available Bearing System Available 05 12 24 48 2B L S PERFORMANCE P-Q CURVE Function Available N A I F R Q S T M V C P DW U OUTLINE DIMENSIONS 3.90 2.60 50.0±0.3 5.20 60.0±0.5 Static Pressure (mm-H 2 O) 6.50 1.30 0 0 ∅4.3±0.1 6.00 12.0 18.0 24.0 30.0 15.0±0.5 300±10 Airflow (CFM) Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystechUSA.com for updated information. Customized Specifications are designed accordingly
EYW06015012LL-12 价格&库存
很抱歉,暂时无法提供与“EYW06015012LL-12”相匹配的价格&库存,您可以联系我们找货
