EYW08038048BU-12
EYW08038048BU-12
    YSTECH(仁新科技)
    E-SERIES FAN ULTRA SPEED W/PWM
EYW08038048BU-12 数据手册
EYW08038 SERIES 80x80x38mm Airflow: 55.2~135.0 CFM mA 550 950 1550 2900 4800 300 450 730 1300 2300 200 270 360 700 1200 W 6.60 11.40 18.60 34.80 57.60 7.20 10.80 16.80 31.20 55.20 9.60 12.96 17.28 33.60 57.60 Noise Level mm-H 2 O 23.3 39.6 63.0 102.1 145.0 23.3 39.6 63.0 102.1 145.0 23.3 39.6 63.0 102.1 145.0 Power Consumption CFM 55.2 70.9 87.1 111.6 135.0 55.2 70.9 87.1 111.6 135.0 55.2 70.9 87.1 111.6 135.0 Current RPM 7000 9000 11000 14000 17000 7000 9000 11000 14000 17000 7000 9000 11000 14000 17000 P-Q Curve 48 VDC 7~14.0 7~14.0 7~14.0 7~14.0 7~14.0 10~28.0 10~28.0 10~28.0 10~28.0 10~30.0 24~75.0 24~75.0 24~75.0 24~75.0 24~75.0 Life at 40 o C L10 24 Max. Static Pressure 12 Max. Airflow VDC 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B Speed Model No. EYW08038012BL EYW08038012BM EYW08038012BH EYW08038012BSS EYW08038012BU EYW08038024BL EYW08038024BM EYW08038024BH EYW08038024BSS EYW08038024BU EYW08038048BL EYW08038048BM EYW08038048BH EYW08038048BSS EYW08038048BU Operating Voltage Range Rated Voltage Bearing Static Pressure: 23.3~145.0 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1061 #22 AWG Weight: 220.0 g Hour 80000 80000 75000 65000 65000 80000 80000 75000 65000 65000 80000 80000 75000 65000 65000 5 4 3 2 1 5 4 3 2 1 5 4 3 2 1 dB(A) 50.0 56.0 60.8 67.5 69.5 50.0 56.0 60.8 67.5 69.5 50.0 56.0 60.8 67.5 69.5 2B: 2-ball bearing L: sintetico bearing S: sleeve bearing Voltage Available 05 12 24 48 Bearing System Available 2B L S PERFORMANCE P-Q CURVE Function Available N A I F R Q S T M V C P DW U OUTLINE DIMENSIONS 90.0 60.0 71.5 ±0.3 120.0 80.0 ±0.5 Static Pressure (mm-H 2 O) 150.0 30.0 0 38.0 ±0.5 0 28.0 56.0 84.0 112 140 45.0 ±0.1 Airflow (CFM) Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystech.com.tw for updated information. Customized Specifications are designed accordingly
EYW08038048BU-12 价格&库存
很抱歉,暂时无法提供与“EYW08038048BU-12”相匹配的价格&库存,您可以联系我们找货
