EYW09238048BH-EAK-12
    YSTECH(仁新科技)
    E-SERIES FAN HIGH SPEED W/PWM
EYW09238048BH-EAK-12 数据手册
EYW09238 SERIES 92x92x38mm Airflow: 56.6~192.9 CFM mA 240 570 1100 2400 4400 160 300 530 1050 2200 80 150 270 540 1100 W 2.88 6.84 13.20 28.80 52.80 3.84 7.20 12.72 25.20 52.80 3.84 7.20 12.96 25.92 52.80 Noise Level mm-H 2 O 13.2 29.1 48.9 66.9 79.0 13.2 29.1 48.9 66.9 103.7 13.2 29.1 48.9 66.9 103.7 Power Consumption CFM 56.6 84.6 113.6 150.9 184.5 56.6 84.6 113.6 150.9 192.9 56.6 84.6 113.6 150.9 192.9 Current RPM 4000 6000 8000 10500 12500 4000 6000 8000 10500 13500 4000 6000 8000 10500 13500 P-Q Curve 48 VDC 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 12~28.0 12~28.0 12~28.0 12~28.0 12~28.0 36~56.0 36~56.0 36~56.0 36~56.0 36~56.0 Life at 40 o C L10 24 Max. Static Pressure 12 Max. Airflow VDC 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B Speed Model No. EYW09238012BL EYW09238012BM EYW09238012BH EYW09238012BS EYW09238012BU EYW09238024BL EYW09238024BM EYW09238024BH EYW09238024BS EYW09238024BU EYW09238048BL EYW09238048BM EYW09238048BH EYW09238048BS EYW09238048BU Operating Voltage Range Rated Voltage Bearing Static Pressure: 13.2~103.7 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1061 #22 AWG Weight: 2 33 . 0 g Hour 80000 80000 75000 65000 65000 80000 80000 75000 65000 65000 80000 80000 75000 65000 65000 5 4 3 2 1 5 4 3 2 1 5 4 3 2 1 dB(A) 39.5 51.5 57.5 65.0 67.5 39.5 51.5 57.5 65.0 68.5 39.5 51.5 57.5 65.0 68.5 2B: 2-ball bearing L: sintetico bearing S: sleeve bearing Voltage Available 05 12 24 48 Bearing System Available 2B L S PERFORMANCE P-Q CURVE Function Available N A I F R Q S T M V C P DW U OUTLINE DIMENSIONS 66.0 44.0 82.5±0.3 88.0 92.0±0.5 Static Pressure (mm-H 2 O) 110.0 22.0 0 38.0±0.5 0 40.0 80.0 120 160 200 45.0 ±0.1 300±10 Airflow (CFM) Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystechusa.com for updated information. Customized Specifications are designed accordingly
EYW09238048BH-EAK-12 价格&库存
很抱歉,暂时无法提供与“EYW09238048BH-EAK-12”相匹配的价格&库存,您可以联系我们找货
