EYW12038012BM-12
EYW12038012BM-12
    YSTECH(仁新科技)
    E-SERIES FAN MEDIUM SPEED W/PWM
EYW12038012BM-12 数据手册
EYW12038 SERIES 120x120x38mm mA 1300 2200 4000 750 1200 1700 2900 400 550 900 1400 Power Consumption Current Speed Operating Voltage Range mm-H 2 O 19.3 29.2 49.9 19.3 29.2 41.5 60.0 19.3 29.2 41.5 60.0 W 15.60 26.40 48.00 18.00 28.80 40.80 69.60 19.20 26.40 43.20 67.20 Noise Level 48 CFM 155.8 194.0 233.6 155.8 194.0 238.8 275.6 155.8 194.0 238.8 275.6 P-Q Curve 24 RPM 4000 5000 6000 4000 5000 6000 7000 4000 5000 6000 7000 Life at 40 o C L10 12 VDC 7~13.2 7~13.2 7~13.2 15~30.0 15~30.0 15~30.0 15~30.0 35~60.0 35~60.0 35~60.0 35~60.0 Max. Static Pressure VDC 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B Max. Airflow Model No. EYW12038012BL EYW12038012BM EYW12038012BH EYW12038024BL EYW12038024BM EYW12038024BH EYW12038024BS EYW12038048BL EYW12038048BM EYW12038048BH EYW12038048BS Rated Voltage Bearing Airflow: 155.8~275.6 CFM Static Pressure: 19.3~60.0 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1007 #22 AWG Weight: 425 g Hour 80000 75000 65000 80000 75000 65000 65000 80000 75000 65000 65000 4 3 2 4 3 2 1 4 3 2 1 dB(A) 54.0 60.4 64.9 54.0 60.4 64.9 69.2 54.0 60.4 64.9 69.2 2B: 2-ball bearing L: sintetico bearing S: sleeve bearing Voltage Available 05 12 24 48 Bearing System Available 2B L S PERFORMANCE P-Q CURVE Function Available N A I F R Q S T M V C P DW U OUTLINE DIMENSIONS 39.0 26.0 105.0±0.3 52.0 120.0±1.0 Static Pressure (mm-H 2 O) 65.0 13.0 0 0 60.0 120 180 240 300 ∅4.5±0.1 38.0±0.5 300±10 Airflow (CFM) Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystech.com.tw for updated information. Customized Specifications are designed accordingly
EYW12038012BM-12 价格&库存
很抱歉,暂时无法提供与“EYW12038012BM-12”相匹配的价格&库存,您可以联系我们找货
