HYW08025048BSS-12
HYW08025048BSS-12
    YSTECH(仁新科技)
    H-SERIES FAN SUPER SPEED W/PWM
HYW08025048BSS-12 数据手册
HYW08025 SERIES 80x80x25mm Noise Level Max. Airflow Speed Operating Voltage Range P-Q Curve 48 CFM 47.4 55.7 62.3 70.0 80.0 47.4 55.7 62.3 70.0 80.0 47.4 55.7 63.2 70.0 80.0 Life at 40 o C L10 24 RPM 3800 4400 5000 5600 6200 3800 4400 5000 5600 6200 3800 4400 5000 5600 6200 Power Consumption 12 VDC 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 24~56.0 24~56.0 24~56.0 24~56.0 24~56.0 Current VDC 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B Max. Static Pressure Model No. HYW08025012BL HYW08025012BM HYW08025012BH HYW08025012BS HYW08025012BSS HYW08025024BL HYW08025024BM HYW08025024BH HYW08025024BS HYW08025024BSS HYW08025048BL HYW08025048BM HYW08025048BH HYW08025048BS HYW08025048BSS Rated Voltage Bearing Airflow: 47.4~ 80.0 CFM Static Pressure: 6.8~ 17.2 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1007 #24 AWG Weight: 1 03. 5 g mm-H 2 O 6.8 9.0 11.3 14.2 17.2 6.8 9.0 11.3 14.2 17.2 6.8 9.0 11.3 14.2 17.2 mA 180 260 330 480 600 100 130 180 220 330 65 85 100 130 160 W 2.16 3.12 3.96 5.76 7.20 2.40 3.12 4.32 5.28 7.92 3.12 4.08 4.80 6.24 7.68 Hour 80000 80000 75000 65000 65000 80000 80000 75000 65000 65000 80000 80000 75000 65000 65000 5 4 3 2 1 5 4 3 2 1 5 4 3 2 1 dB(A) 39.5 43.5 46.7 50.0 53.5 39.5 43.5 46.7 50.0 53.5 39.5 43.5 46.7 50.0 53.5 2B: 2-ball bearing L: sintetico bearing S: sleeve bearing Voltage Available 05 12 24 48 Bearing System Available 2B L S PERFORMANCE P-Q CURVE Function Available N A I F R Q S T M V C P DW U OUTLINE DIMENSIONS 14.4 80.0±0.5 10.8 7.2 71.5±0.3 Static Pressure (mm-H 2 O) 18.0 3.6 0 ∅4.5±0.3 0 25.4±0.5 17.0 34.0 51.0 68.0 85.0 Airflow (CFM) Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystechUSA.com for updated information. Customized Specifications are designed accordingly
HYW08025048BSS-12 价格&库存
很抱歉,暂时无法提供与“HYW08025048BSS-12”相匹配的价格&库存,您可以联系我们找货
