NYW03010005LL-6
NYW03010005LL-6
    YSTECH(仁新科技)
    N-SERIES FAN LOW SPEED W/PWM
NYW03010005LL-6 数据手册
rtment. 30x30x10mm 05 12 RPM 5800 6800 7800 10000 6000 7000 8000 10000 5800 6800 7800 10000 6000 7000 8000 10000 CFM 2.5 3.0 3.4 4.0 2.6 2.9 3.3 4.0 2.5 3.0 3.4 4.0 2.5 2.9 3.3 4.0 mm-H 2 O 2.0 2.7 3.3 5.2 2.0 2.8 3.6 5.2 2.0 2.7 3.3 5.2 2.0 2.8 3.6 5.2 mA 50 80 90 120 80 105 130 190 35 40 40 60 35 50 60 80 W 0.25 0.40 0.45 0.60 0.40 0.53 0.65 0.95 0.42 0.48 0.48 0.72 0.42 0.60 0.72 0.96 Hour 80000 80000 75000 65000 50000 50000 50000 50000 80000 80000 75000 65000 50000 50000 50000 50000 4 3 2 1 4 3 2 1 4 3 2 1 4 3 2 1 Noise Level Max. Static Pressure Max. Airflow Speed Operating Voltage Range VDC 4~5.5 4~5.5 4~5.5 4~5.5 4~5.5 4~5.5 4~5.5 4~5.5 9~13.2 7~13.2 7~13.2 7~13.2 9~13.2 7~13.2 7~13.2 7~13.2 P-Q Curve VDC Life at 40 oC L10 2B 2B 2B 2B L L L L 2B 2B 2B 2B L L L L Power Consumption Model No. NYW0301 00 05BL NYW03 0100 05BM NYW03 0100 05BH NYW03 0100 05BS NYW03 0100 05LL NYW03 0100 05LM NYW03 0100 05LH NYW03 0100 05LS NYW030 10 012BL NY W03010 012BM NY W03010 012BH NY W03010 012BS NYW03 0100 012LL NYW03 0100 012LM NYW03 0100 012LH NYW03 0100 012LS Rated Voltage Bearing Airflow: 2.5~4.0 CFM Static Pressure: 2.0~5.2 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1571 #28 AWG Weight: 9 g Current A) 0 5 0 0 .0 2 0 5 0 0 .0 2 NYW03010 SERIES dB(A)
NYW03010005LL-6 价格&库存
很抱歉,暂时无法提供与“NYW03010005LL-6”相匹配的价格&库存,您可以联系我们找货
