NYW06025048BJ-W-6
NYW06025048BJ-W-6
    YSTECH(仁新科技)
    W-SERIES FAN J-SPEED W/PWM
NYW06025048BJ-W-6 数据手册
rtment. 60x60x25mm 24 24 48 2B: 2-ball bearing L : sintetico bearing S: sleeve bearing Voltage Available Bearing System Available 05 12 24 48 2B L S PERFORMANCE P-Q CURVE CFM 14.4 19.7 24.5 26.9 31.2 35.9 40.6 45.4 50.2 14.4 19.7 24.5 31.2 50.2 14.4 19.7 24.5 32.7 50.2 Current Max. Static Pressure Max. Airflow Operating Voltage Range Speed RPM 3000 4100 5100 5600 6500 7500 8500 9500 10500 3000 4100 5100 6500 10500 3000 4100 5100 6800 10500 mm-H 2 O mA 5.0 50 7.5 80 9.3 120 10.2 150 190 11.8 300 13.2 17.4 420 22.2 630 27.6 900 5.0 35 7.5 55 9.3 75 11.8 110 27.6 410 5.0 30 7.5 40 55 9.3 12.4 80 240 27.6 Noise Level 12 VDC 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 24~56.0 24~56.0 24~56.0 24~56.0 24~56.0 P-Q Curve VDC 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B Life at 40 oC L10 Model No. NYW06025012BL-W NYW06025012BM-W NYW06025012BH-W NYW06025012BS-W NYW06025012BSS-W NYW06025012BF-W NYW06025012BG-W NYW06025012BJ-W NYW06025012BU-W NYW06025024BL-W NYW06025024BM-W NYW06025024BH-W NYW06025024BSS-W NYW06025024BU-W NYW06025048BL-W NYW06025048BM-W NYW06025048BH-W NYW06025048BSS-W NYW06025048BU-W Rated Voltage Bearing Airflow: 14.4~50.2 CFM Static Pressure: 5.0~27.6 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1007 #24 AWG Weight: 56 g Power Consumption A) 5 5 0 5 0 5 5 0 5 0 5 5 0 5 NYW06025-W SERIES W 0.60 0.96 1.44 1.80 2.28 3.60 5.04 7.56 10.80 0.84 1.32 1.80 2.64 9.84 1.44 1.92 2.64 3.84 11.52 Hour 80000 80000 75000 65000 65000 65000 65000 65000 65000 80000 80000 75000 65000 65000 65000 80000 80000 65000 65000 9 8 7 6 5 4 3 2 1 9 8 7 5 1 9 8 7 5 1 dB(A) 25.0 31.0 36.0 38.1 41.0 47.0 49.5 51.5 25.0 31.0 36.0 41.0 51.5 25.0 31.0 36.0 42.0 42.0 51.5 Function Available 1 6 5 4 3 2 7 8 9 10 1114 1213 OUTLINE DIMENSIONS Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystechusa.com/ for updated information. Customized Specifications are designed accordingly. 36
NYW06025048BJ-W-6 价格&库存
很抱歉,暂时无法提供与“NYW06025048BJ-W-6”相匹配的价格&库存,您可以联系我们找货
