QYW09225048BH-12
QYW09225048BH-12
    YSTECH(仁新科技)
    Q-SERIES FAN HIGH SPEED W/PWM
QYW09225048BH-12 数据手册
QYW9225 SERIES 92x92x25mm Noise Level Max. Airflow Speed Operating Voltage Range P-Q Curve 48 CFM 25.9 39.6 50.3 64.8 78.3 92.5 25.9 39.6 50.3 64.8 78.3 92.5 25.9 39.6 50.3 64.8 78.3 92.5 Life at 40 o C L10 24 RPM 2000 3000 4000 5000 6000 7000 2000 3000 4000 5000 6000 7000 2000 3000 4000 5000 6000 7000 Power Consumption 12 VDC 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 7~13.2 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 12~26.4 24~56.0 24~56.0 24~56.0 24~56.0 24~56.0 24~56.0 Current VDC 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B Max. Static Pressure Model No. QYW09225012BL QYW09225012BM QYW09225012BH QYW09225012BS QYW09225012BU QYW09225012BV QYW09225024BL QYW09225024BM QYW09225024BH QYW09225024BS QYW09225024BU QYW09225024BV QYW09225048BL QYW09225048BM QYW09225048BH QYW09225048BS QYW09225048BU QYW09225048BV Rated Voltage Bearing Airflow: 25.9~92.5 CFM Static Pressure: 2.1~20.7 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1007 #24 AWG Weight: 117.0 g mm-H 2 O 2.1 4.6 6.9 10.3 15.7 20.7 2.1 4.6 6.9 10.3 15.7 20.7 2.1 4.6 6.9 10.3 15.7 20.7 mA 35 85 145 300 490 750 45 70 100 160 230 340 35 45 70 90 130 180 W 0.42 1.02 1.74 3.60 5.88 9.00 1.08 1.68 2.40 3.84 5.52 8.16 1.68 2.16 3.36 4.32 6.24 8.64 Hour 80000 80000 75000 65000 65000 60000 80000 80000 75000 65000 65000 60000 80000 80000 75000 65000 65000 60000 6 5 4 3 2 1 6 5 4 3 2 1 6 5 4 3 2 1 dB(A) 16.7 28.2 35.0 41.3 46.5 50.3 16.7 28.2 35.0 41.3 46.5 50.3 16.7 28.2 35.0 41.3 46.5 50.3 2B: 2-ball bearing L: sintetico bearing S: sleeve bearing Voltage Available Bearing System Available 05 12 24 48 2B L S PERFORMANCE P-Q CURVE Function Available N A I F R Q S T M V C P DW U OUTLINE DIMENSIONS Static Pressure (mm-H 2 O) 22.0 17.6 13.2 8.8 4.4 0 0 19.0 38.0 57.0 76.0 95.0 ∅4.50±0.30 300±10 Airflow (CFM) Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystech.com.tw for updated information. Customized Specifications are designed accordingly
QYW09225048BH-12 价格&库存
很抱歉,暂时无法提供与“QYW09225048BH-12”相匹配的价格&库存,您可以联系我们找货
