QYW12025024BH-5
QYW12025024BH-5
    YSTECH(仁新科技)
    Q-SERIES FAN HIGH SPEED W/TACH
QYW12025024BH-5 数据手册
QYW12025 SERIES 120x120x25mm 48 Power Consumption Current mm-H 2 O mA 3.1 130 6.0 220 14.1 550 24.3 1300 3.1 85 6.0 130 14 . 1 320 24 . 3 700 3.1 60 6.0 85 180 14.1 400 24.3 W 1.56 2.64 6.60 15.60 2.04 3.12 7.68 16.80 2.88 4.08 8.64 19.20 Noise Level 24 CFM 56.5 81.8 127.9 181.0 56 . 5 81 . 8 127 . 9 181 . 0 56 . 5 81 . 8 127 . 9 181 . 0 P-Q Curve 12 RPM 2000 2800 4400 6000 2000 2800 4400 6000 2000 2800 4400 6000 Life at 40 o C L10 VDC 7~13.2 7~13.2 7~13.2 7~13.2 12~26.4 12~26.4 12~26.4 12~26.4 24~56.0 24~56.0 24~56.0 24~56.0 Max. Static Pressure Speed Operating Voltage Range VDC 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B 2B Max. Airflow Model No. QYW12025012BL QYW12025012BM QYW12025012BH QYW12025012BS QYW12025024BL QYW12025024BM QYW12025024BH QYW12025024BS QYW12025048BL QYW12025048BM QYW12025048BH QYW12025048BS Rated Voltage Bearing Airflow: 56.5~181.0 CFM Static Pressure: 3.1~24.3mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1007 #24 AWG Weight: 205 g Hour 80000 80000 75000 65000 80000 80000 75000 65000 80000 80000 75000 65000 4 3 2 1 4 3 2 1 4 3 2 1 dB(A) 29.3 39.1 51.4 60.5 29.3 39.1 51 . 4 60.5 29.3 39.1 51.4 60.5 2B: 2-ball bearing L: sintetico bearing S: sleeve bearing Voltage Available 05 12 24 48 Bearing System Available 2B L S PERFORMANCE P-Q CURVE Function Available N A I F R Q S T M V C P DW U OUTLINE DIMENSIONS 15.0 10.0 105.0±0.5 20.0 120.0±0.5 Static Pressure (mm-H 2 O) 25.0 5.0 0 0 37 74 111 148 185 25.0±0.5 ∅4.5±0.1 300±10 Airflow (CFM) Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystech.com.tw for updated information. Customized Specifications are designed accordingly
QYW12025024BH-5 价格&库存
很抱歉,暂时无法提供与“QYW12025024BH-5”相匹配的价格&库存,您可以联系我们找货
