XYW04028012BSS-E-12
XYW04028012BSS-E-12
    YSTECH(仁新科技)
    X E-SERIES FAN SUPER SPEED W/PWM
XYW04028012BSS-E-12 数据手册
XYW04028-E SERIES 40x40x28mm rtment. 2B: 2-ball bearing L : sintetico bearing S: sleeve bearing Voltage Available Bearing System Available 05 12 24 48 2B L S 24 PERFORMANCE P-Q CURVE CFM 23.61 26.26 29.57 33.68 mm-H 2 O 44.66 50.78 56.02 62.52 Life at 40 oC L10 Max. Static Pressure Max. Airflow Speed RPM 17000 19000 21000 23500 mA 600 900 1200 1800 W Hour 7.20 80000 10.80 75000 14.40 65000 21.60 65000 Noise Level VDC 7~13.2 7~13.2 7~13.2 7~13.2 P-Q Curve 12 Operating Voltage Range Rated Voltage VDC 2B 2B 2B 2B Power Consumption Model No. XYW04028012BM-E XYW04028012BH-E XYW04028012BS-E XYW04028012BSS-E Current (A) .6 .7 .4 .6 .6 Bearing Noise Level Airflow: 23.61~33.68 CFM Static Pressure: 44.66~62.52 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1061 #28 AWG Weight: 48.1 g 4 3 2 1 dB(A) 52.5 56.0 58.0 61.0 Function Available 1 6 5 4 3 2 7 8 9 10 1112 1314 OUTLINE DIMENSIONS Please refer to Model Numbering System for bearing, function and speed level indication. Specifications are subject to changes without notice. Please refer to the formally issued product specification via contacting Y.S. TECH sales department. Visit Y.S. TECH web site at http://www.ystechusa.com/ for updated information. Customized Specifications are designed accordingly 26
XYW04028012BSS-E-12 价格&库存
很抱歉,暂时无法提供与“XYW04028012BSS-E-12”相匹配的价格&库存,您可以联系我们找货
