YW04020012BS-N-5
YW04020012BS-N-5
    YSTECH(仁新科技)
    N-SERIES FAN EXTRA HIGH W/TACH
YW04020012BS-N-5 数据手册
rtment. 40x40x20mm VDC 05 5 12 24 RPM 4500 6000 7500 8500 4000 4500 6000 7500 4500 6000 7500 8500 CFM 6.08 8.06 10.04 11.36 5.42 6.08 8.06 10.04 6.08 8.06 10.04 11.36 mm-H 2 O 2.81 5.02 7.87 10.12 2.21 2.81 5.02 7.87 2.81 5.02 7.87 10.12 W 0.30 0.50 0.85 1.05 0.36 0.48 0.72 1.32 0.72 1.08 1.44 2.04 Hour 50000 50000 50000 65000 50000 50000 50000 50000 50000 50000 50000 65000 4 3 2 1 5 4 3 2 4 3 2 1 Noise Level mA 60 100 170 210 30 40 60 110 30 45 60 85 P-Q Curve Max. Static Pressure Max. Airflow Speed Operating Voltage Range VDC 4~5.5 4~5.5 4~5.5 4~5.5 7~13.2 7~13.2 7~13.2 7~13.2 12~26.4 12~26.4 12~26.4 12~26.4 Life at 40 oC L10 L L L 2B L L L 2B L L L 2B Power Consumption Model No. YW04020005LL-N YW04020005LM-N YW04020005LH-N YW04020005BS-N YW04020012LL-N YW04020012LM-N YW04020012LH-N YW04020012BH-N YW04020024LL-N YW04020024LM-N YW04020024LH-N YW04020024BS-N Rated Voltage Bearing Airflow: 5.42~11.36 CFM Static Pressure: 2.21~10.12 mm-H 2 O Blade / Housing: Plastic Material UL 94V-0 P.B.T. Lead Wire: UL1061 #26 AWG Weight: 26.9 g Current A) 0 5 5 0 5 5 5 5 0 5 5 5 5 YW04020-N SERIES dB(A)
YW04020012BS-N-5 价格&库存
很抱歉,暂时无法提供与“YW04020012BS-N-5”相匹配的价格&库存,您可以联系我们找货
