BXRV-DR-1827G-0600-A-13
    BRIDGELUX(普瑞)
    LED 照明 COB、引擎、模块 板上芯片(COB) Vesta™ 白色,暖色 矩形
BXRV-DR-1827G-0600-A-13 数据手册
Bridging Light and Life™ Bridgelux Vesta® Flex April 2020 Bridging Light and Life™ 1 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Human Centric Lighting: Definition ▪ Human centric lighting is broadly defined as: • Lighting that can benefit the biological, emotional, health, or wellbeing of people ▪ This is typically achieved through: • Providing high quality light sources for visual appeal − Full spectrum emission over the visual range with high CRI and R values • Enabling personalization and control − Supporting individual preferences for lighting intensities, colors and styles − Circadian adjustable to mimic the levels of sunlight throughout the day • Ensuring the light delivered is as close to that provided by nature − Emulating the spectrum of the sun under which humans have evolved for millions of years, sunlight during the day and firelight at night − Avoiding deviations from natural light that may disrupt the circadian rhythm 2 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Lighting Market: Dynamics And Challenges ▪ The lighting market is in the early stages of human- centric lighting adoption • Tunable white lighting systems are an important part of this evolution with strong growth potential ▪ The lighting component market is siloed • This forces luminaire manufacturers to source building blocks (LEDs, drivers, and controls) from multiple suppliers • Unfortunately, this often results in challenges as the sourced components may not work together out of the box ▪ Most tunable white opportunities are project based • The control system decisions may be made outside of the luminaire manufacturers control, driven by the installation ▪ To accelerate the adoption of tunable white lighting a flexible, future ready solution is needed • Enabling lighting manufacturers to quickly react to projects with a solution that works together, seamlessly and reliably 3 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex: Dual Channel LED Driver and Control Module Family ▪ Bundled system from one manufacturer guaranteed to work together out of the box ▪ Control module and driver family enables application flexibility and interoperability with third party systems • Includes WiZ Wi-Fi, WiSilica BLE mesh, DALI2 DT8 and 0-10V • Casambi and Silvair BLE modules under development • Flexible, future-proof solution ▪ 30W and 60W Brick and 60W Linear options • Smooth CCT tuning and dimming to 0.1% and dim-to-off • NFC programmable features ▪ Robust RJ45 digital communication interface • Direct open protocol digital PWM communication • Simple, standard, keyed, robust solution ▪ Sampling now, production shipments May 2020 4 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex: Architecture And Ecosystem Vesta Flex enables you and your customers to connect to third party data management, control systems, and ecosystems smart lighting management 5 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex Drivers: Features and Specifications ▪ Smooth, flicker free CCT tuning and dimming to 0.1% with dim-to off ▪ High resolution linear, square and logarithmic dimming curves ▪ NFC programmable dimming curves and maximum output currents ▪ Built-in overvoltage, over-temperature and short circuit protection ▪ Driver autodetects and powers control module and adjusts behavior accordingly 130mm x 77mm x 30mm (L x W x H) ▪ Available in 30W and 60W brick and 60W linear options ▪ 88% efficiency at full load ▪ Compatible with Bridgelux Vesta® tunable white light sources ▪ Flicker free per IEEE P1789, CEC Title 24 ▪ Universal input voltage range of 120V – 277V 130mm x 77mm x 30mm (L x W x H) ▪ UL Class P 320mm x 32mm x 28mm (L x W x H) 6 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex: Wireless NFC Programming Tool ▪ NFC Programming of Vesta Flex • Vesta Flex Driver NFC port requires BLX NFC programming tool • Vesta Flex Driver NFC port may not be compatible with 3rd party NFC programming tools ▪ Vesta flex programming tool kit includes: • Bridgelux NFC Reader with micro USB connector, USB cable • Bridgelux proprietary software ▪ Samples available now User interface, Data communication 135mm x 48mm x 17mm NFC reader and USB cable NFC ▪ NFC programmable settings include • Linear, square, or logarithmic dimming curves • Maximum output currents • Over temperature protection overwrite • Minimum dim levels (0.1%, 1%, 5%, 10%) • Fade time Bridgelux software Bridgelux Vesta Flex 7 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex: Wireless Control Modules WiSilica Enabled BLE Control ▪ Connect lighting fixtures to an intelligent non-flooding BLE mesh network ▪ Commission and manage lighting fixtures via iOS and Android apps or web portal ▪ Interoperated with beacons and sensors via BLE ▪ Large ecosystem of compatible sensors, switches, gateways, and 3rd party clouds ▪ Cloud services such as system monitoring, device management, predictive maintenance, asset tracking, and data analytics 75mm x 32mm x 20mm (L x W x H) WiZ Enabled Wi-Fi Control ▪ Connect lighting fixtures to the internet via Wi-Fi, no hub needed ▪ Interoperates with sensors via BLE ▪ Commission and manage lighting fixtures via iOS and Android apps or web portal ▪ Large ecosystem of compatible sensors, switches, gateways, and cloud platform ▪ Cloud services such as system monitoring, device management, predictive maintenance, asset tracking, and data analytics 75mm x 32mm x 20mm (L x W x H) 8 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex: Wireless Control Modules Casambi Enabled BLE Control ▪ Connect lighting fixtures and accessories to Casambi’s proprietary BLE mesh network ▪ Commission and manage lighting fixtures via iOS and Android apps or a web portal ▪ Build-in iBeacon technology enabling location awareness ▪ Large ecosystem of compatible, sensors, switches, and DALI or 0-10V compatible controllers ▪ Cloud services for device configuration and access management, system monitoring, and connecting to 3rd party cloud systems for services such as data analytics 75mm x 32mm x 20mm (L x W x H) Silvair Enabled BLE Control ▪ Connect lighting components to Silvair’s open BLE SIG compatible mesh network ▪ Commission and manage lighting fixtures via an iOS app or a web portal ▪ Interoperable with any 3rd party BLE SIG compatible device ▪ Large ecosystem of compatible sensors, switches, and DALI or 0-10V compatible controllers ▪ System services for device, configuration and access management, system monitoring, and optimization of energy consumption 75mm x 32mm x 20mm (L x W x H) 9 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex: Wireless Application User Interfaces WiSilica Dimming CCT tuning Commissioning Groups, Scenes WiZ Dimming CCT tuning Commissioning Groups Pre-Sets Scenes Casambi Circadian Rhythm Programmability Dimming CCT tuning Commissioning Groups, Scenes 10 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex: Wired Control Modules DALI2 DT8 Control Module ▪ DALI2 DT8 certified ▪ Two-channel control of color temperature and intensity ▪ Compatible with industry standard DALI2 DT8 devices ▪ Commission and manage lighting fixtures via any DALI2 certified controller 50mm x 32mm x 20mm (L x W x H) 0-10V Control Module ▪ 0-10V control protocol ▪ Two-channel control of color temperature and intensity ▪ Compatible with industry standard 0-10V current sourcing of current sinking wired control devices ▪ Dim-to-off hysteresis with turn off at 0.6V and turn on at 0.8V 50mm x 32mm x 20mm (L x W x H) 11 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Bridgelux Vesta® COB Portfolio: Tunable White and Dim To Warm Vesta Product Dim-To-Warm Arrays Tunable White Arrays Tunable White Arrays Technology Dispensed phosphor CSP Dispensed phosphor Sample Image CRI Typ. Flux (lm) at coolest CCT (25°C) Drive Current (mA) Voltage (V) (25°C) Efficacy (lm/W) (25°C) 90 660 350 17.0 111 90, 95 490 684 1360 2312 3725 250 350 350 600 950 17.0 17.0 33.8 33.5 34.1 115 115 115 115 115 90 5350 13000 1300 2350 36.0 48.0 115 115 90 1385 2750 700 700 18.1 36.0 106 106 2700K-5000/6500K2 600 150 36.0 110 2700K-5000/6500K2 1800K-3000/4000K2 1190 2250 500 / 250 500 18.0 / 34.8 36.3 137 124 2884 4026 6106 7043 650 900 900 1050 35.5 35.3 53.0 52.4 125 127 128 128 Part Numbers LES / Dimensions BXRV-DR-18xxG-0600-A-13 6mm (7W) BXRV-DR-18xxx-1000-G-13 BXRV-DR-18xxx-1000-A-13 BXRV-DR-18xxx-1000-B-13 BXRV-DR-18xxx-2000-A-13 BXRV-DR-18xxx-3000-A-13 9 mm (4W) 9 mm (6W) 9 mm (12W) 13 mm (21W) 15 mm (33W) BXRV-DR-18xxG-4000-A-13 BXRV-DR-18xxG-1K00-A-13 18mm (47W) 29mm (113W) BXRV-TR-2750G-1000-A-2x BXRV-TR-2750G-2000-A-2x 9 mm (12W) 13 mm (25W) 2700K-5000K2 BXRV-TR-27xxG-06A0-A-23 6mm (5.5W) BXRV-TR-xxxxG-10A0-x-23 BXRV-TR-xxxxG-20A0-A-23 9 mm (9W) 13mm (18W) BXRV-TR-2750G-30A0-A-23 BXRV-TR-2750G-40A0-A-23 BXRV-TR-2750G-65A0-A-23 BXRV-TR-2750G-1KA0-A-23 15mm (21W) 18mm (25W) 22mm (44W) 29mm (54W) Tunable / Dimming CCT Range 1800K-2700/3000K1 90 2700K-5000/6500K2 Application Highlights Residential, Hospitality, Lowest system cost High color angular uniformity (CAU) optical performance Higher efficacy, Higher lm/$ options Notes: 1. Tc = 25°C; 2. Tc = 85°C 12 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Bridgelux Vesta® SE Portfolio: Tunable White and Dim To Warm Vesta Product Dim-ToWarm Integrated Arrays Tunable White Integrated Arrays Sample Image Part Numbers LES Diameter Integrated Array Diameter CRI Typ. Flux (lm) at coolest CCT (25°C) Drive Current (mA) Voltage (V) (25°C) Peak Efficacy (lm/W) (25°C) BXRV-DR-18xxG-0600-A-13-SE 6mm (7W) 30.8mm 90 627 350 17.0 105 BXRV-DR-18xxx-1000-G-13-SE BXRV-DR-18xxx-1000-A-13-SE BXRV-DR-18xxx-1000-B-13-SE 9 mm (4W) 9 mm (6W) 9 mm (12W) 30.8mm 90, 95 467 650 1292 250 350 350 17.0 17.0 33.8 109 109 109 BXRV-DR-18xxx-2000-A-13-SE BXRV-DR-18xxx-3000-A-13-SE 13 mm (21W) 15 mm (33W) 36.2mm 90, 95 2220 3576 600 950 33.5 34.1 110 110 BXRV-DR-18xxG-4000-A-13-SE 18mm (47W) TBD 90 5350 1300 36.0 115 BXRV-DR-18xxG-1K00-A-13-SE 29mm (113W) TBD 90 13000 2350 48.0 115 BXRV-TR-27xxG-06A0-A-23-SE 6mm (5.5W) 36.2mm 2700K-5000/6500K2 90 582 150 36.0 108 BXRV-TR-xxxxG-10A0-x-23-SE BXRV-TR-xxxxG-20A0-A-23-SE 9 mm (9W) 13mm (18W) 36.2mm 2700K-5000/6500K2 1800K-3000/4000K2 90 1154 2205 500 / 250 500 18.0 / 34.8 36.3 133 121 BXRV-TR-2750G-30A0-A-23-SE BXRV-TR-2750G-40A0-A-23-SE BXRV-TR-2750G-65A0-A-23-SE 15mm (21W) 18mm (25W) 22mm (44W) 45.0mm 90 2826 3945 5984 650 900 900 35.5 35.3 53.0 122 124 125 BXRV-TR-2750G-1KA0-A-23-SE 29mm (54W) 49.2mm 90 6902 1050 52.4 125 Tunable / Dimming CCT Range 1800K-3000/2700K1 2700K-5000/6500K2 Application Highlights Hole positions and dimensions are compatible with those of the Vero SE array Zhaga compliant Alignment holes for secondary optics Notes: 1. Tc = 25°C; 2. Tc = 85°C 13 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Bridgelux Vesta® Linear Portfolio: Tunable White Solutions Vesta Product CRI Typical Flux (lm) Drive Current (mA) Voltage (V) Peak Efficacy (lm/W) Application Highlights Part Numbers Dimensions Tunable CCT Range TL Gen 3 1 SMD Row BXEB-TL-L0280Z-xxxxy1000-B-C3 BXEB-TL-L0560Z-xxxxy2000-B-C3 BXEB-TL-L1120Z-xxxxy4000-B-C3 280 mm x 24 mm 560 mm x 24 mm 1120 mm x 24 mm 1800K-3000K 1800K-4000K 2700K-5000K 2700K-6500K 80 90 Thrive 1360 2725 5450 375 750 750 19.7 19.7 39.4 184 Same form factor as standard EB modules TL Gen 3 2 SMD Rows BXEB-TL-L0280Z-27xxy1000-A-C3 BXEB-TL-L0560Z-27xxy2000-A-C3 BXEB-TL-L1120Z-27xxy4000-A-C3 280 mm x 31 mm 560 mm x 31 mm 1120 mm x 31 mm 2700K-5000K 2700K-6500K 80 90 Thrive 1835 3670 7340 500 1000 1000 19.7 19.7 39.4 189 Highest flux and highest efficacy Edge BXEB-TL-L0570A-2750G-2000-E-A3 570 mm x 6 mm 2700K-5000K 90 2730 600 34.6 132 Ideal for edge lit panel lighting TL 2 SMD Rows BXEB-TL-2750G-1000-A-13 BXEB-TL-2750G-3000-A-13 280 mm x 31 mm 560 mm x 31 mm 2700K-5000K 90 1680 3350 500 1000 24.8 135 Original Vesta TL Sample Image Note: Performance data measured at 5000K, 80 CRI, and 25C (90 CRI for bottom two products) 14 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Bridgelux Roadmap: Vesta® Flex Vesta Flex Drivers Vesta Flex 30W Brick Driver Vesta Flex 20W Compact / Stick Driver Vesta Flex 60W Brick Driver Vesta Flex 40W Compact / Stick Driver Vesta Flex 100W Linear Driver Vesta Flex 60W Linear Driver Vesta Flex Casambi BLE Control Modules Vesta Flex Silvair BLE Control Modules Vesta Flex Controls Vesta Flex 0-10V Control Module Vesta Flex DALI2 DT8 Control Module Vesta Flex Wisilica BLE Control Module Vesta Flex Wiz WiFi Control Module Q4.2019 15 Q1.2020 Q2.2020 Q3.2020 Q4.2020 Q1.2021 Q2.2021 Q3.2021 Unless otherwise specified point of arrow indicates target market launch date. Alpha engineering samples typically available 4-6 weeks prior to market launch, productions samples typically available 2-4 weeks prior to market launch. BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Market Applications Vesta® Flex ▪ Retail & Hospitality ▪ Office & Education ▪ Residential ▪ Healthcare ▪ Architectural ▪ Museums ▪ Entertainment 16 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Review: Vesta Flex Key Features, Benefits and Products Features / Differentiation Benefits Specification grade two-channel drivers with dimming to 0.1% and dim-to-off High resolution CCT tuning and dimming Compatible with multiple control protocols including 0-10V, DALI2 DT8, Wi-Fi, and multiple Bluetooth mesh control options Future-ready flexible solution to support project-based requirements without recertification Bundled light source, driver and controls solutions from one supplier Guaranteed to work together seamlessly out of the box NFC programmable output parameters Adjustability to support a wide range of applications and installations Samples Available Now Under Development Vesta® Flex 60W Linear Driver Vesta® Flex Vesta® Flex 60W Brick Driver 60W Brick Driver Vesta® Flex Vesta® Flex WiSilica BLE Control 0-10V Control WiZ Wi-Fi Control DALI2 Control Vesta® Flex Vesta® Flex Casambi BLE Control Silvair BLE Control Note: Images not show to scale 17 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Summary: The Vesta® Flex Advantage ▪ With Vesta® Flex, Bridgelux delivers a bundled tunable white solution guaranteed to work together out of the box • Plug and play compatibility ▪ The flexibility to work with up to 6 different control systems supports the ability to respond to projectbased control system requirements • 0-10V, DALI2 DT8, WiSilica BLE, WiZ Wi-Fi available now • Casambi and Silvair BLE available by end of Q2 ▪ Vesta® Flex is a future ready solution, able to quickly adapt to new control systems without requiring luminaire recertification • New control modules can be developed as new control protocols emerge 18 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Bridging Light and Life™ 19 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Bridging Light and Life™ Back Up Material 20 BRIDGELUX CONFIDENTIAL – No Redistribution or Reproduction Permitted. ©2020 Bridgelux, Inc. Bridging Light and Life™ Vesta® Flex Driver: Superior CCT Tuning Dynamic Range ▪ Minimum dimming level is 0.1% • 2000mA x 0.1% = 2mA • 1000mA x 0.1% = 1mA • Minimum output current per channel is
BXRV-DR-1827G-0600-A-13 价格&库存
很抱歉,暂时无法提供与“BXRV-DR-1827G-0600-A-13”相匹配的价格&库存,您可以联系我们找货
      • 1+25.01280
      • 210+9.97920
      • 490+9.64440
      • 1015+9.48240
      • 1+33.883811+4.38210
      • 10+24.8708910+3.21649
      • 100+19.54560100+2.52778
      • 500+17.21234500+2.22603
      • 1000+16.452891000+2.12781
      • 2000+15.810302000+2.04471
      • 5000+15.110505000+1.95420
      库存:235
