ESP32-S3-DEVKITC-1-N8R2
    ESPRESSIF(乐鑫)
    ESP32-S ESP32-S3-WROOM-1-N8R2 收发器; 802.11 b/g/n(Wi-Fi,WiFi,WLAN),Bluetooth® 5 2.4GHz 评估板
ESP32-S3-DEVKITC-1-N8R2 数据手册
 ESP-IDF Programming Guide  » Get Started » ESP32-S3-DevKitC-1 L ESP32-S3-DevKitC-1 TI A This user guide will help you get started with ESP32-S3-DevKitC-1 and will also provide more in-depth information. The ESP32-S3-DevKitC-1 is an entry-level development board equipped with either ESP32-S3-WROOM1 or ESP32-S3-WROOM-1U, a general-purpose Wi-Fi + Bluetooth LE MCU module that integrates complete Wi-Fi and Bluetooth LE functions. Most of the I/O pins on the module are broken out to the pin headers on both sides of this board for easy C O N FI D EN interfacing. Developers can either connect peripherals with jumper wires or mount ESP32-S3-DevKitC-1 on a breadboard. ESP32-S3-DevKitC-1 The document consists of the following major sections: Getting started: Overview of the board and hardware/software setup instructions to get started. Hardware Reference: More detailed information about the board’s hardware. Hardware Revision Details: Revision history, known issues, and links to user guides for previous versions (if any) of the board. L Getting Started TI A This section provides a brief introduction of ESP32-S3-DevKitC-1, instructions on how to do the initial hardware setup and how to flash firmware onto it. N FI D EN Description of Components ESP32-S3-DevKitC-1 - front O The key components of the board are described in a counter-clockwise direction. Key Component Description 5 V to 3.3 V LDO Power regulator that converts a 5 V supply into a 3.3 V output. Pin Headers All available GPIO pins (except for the SPI bus for flash) are broken out to the pin headers on the board for easy interfacing and programming. For details, please see Header Block. C ESP32-S3-WROOM-1/1U ESP32-S3-WROOM-1 and ESP32-S3-WROOM-1U are two powerful, generic Wi-Fi + Bluetooth LE MCU modules that have a rich set of peripherals. They provide acceleration for neural network computing and signal processing workloads. Description USB-to-UART Port A Micro-USB port used for power supply to the board, as well as the communication with the ESP32-S3 chip via the on-board USB-toUART bridge. Boot Button Download button. Holding down Boot and then pressing Reset initiates Firmware Download mode for downloading firmware through the serial port. Reset Button Press this button to restart the system. ESP32-S3 USB Port ESP32-S3 full-speed USB OTG interface, compliant with the USB 1.1 specification. USB-to-UART Bridge Single USB-to-UART bridge chip provides transfer rates up to 3 Mbps. RGB LED Addressable RGB LED, driven by GPIO48. 3.3 V Power On LED Turns on when the USB power is connected to the board. TI A EN Start Application Development L Key Component Before powering up your board, please make sure that it is in good condition with no obvious signs of damage. Required Hardware  Note FI D ESP32-S3-DevKitC-1 USB 2.0 cable (Standard-A to Micro-B) Computer running Windows, Linux, or macOS Be sure to use an appropriate USB cable. Some cables are for charging only and do not provide the N needed data lines nor work for programming the boards. Software Setup O Please proceed to Get Started, where Section Installation Step by Step will quickly help you set up the development environment and then flash an application example onto your board. C Contents and Packaging Retail orders If you order a few samples, each board comes in an individual package in either antistatic bag or any packaging depending on your retailer. For retail orders, please go to https://www.espressif.com/en/company/contact/buy-a-sample. Wholesale Orders If you order in bulk, the boards come in large cardboard boxes. For wholesale orders, please go to https://www.espressif.com/en/contact-us/sales-questions. Hardware Reference L Block Diagram FI D EN TI A The block diagram below shows the components of ESP32-S3-DevKitC-1 and their interconnections. ESP32-S3-DevKitC-1 (click to enlarge) Power Supply Options N There are three mutually exclusive ways to provide power to the board: O USB-to-UART Port, default power supply (recommended) 5 V and GND pins 3V3 and GND pins Header Block C The two tables below provide the Name and Function of the pins on both sides of the board (J1 and J3). The pin names are shown in ESP32-S3-DevKitC-1 - front. The numbering is the same as in the Board Schematic (PDF). J1 No. Name Type 1 Function Name Type Function 1 3V3 P 3.3 V power supply 2 3V3 P 3.3 V power supply 3 RST I EN 4 4 I/O/T RTC_GPIO4, GPIO4, TOUCH4, ADC1_CH3 5 5 I/O/T RTC_GPIO5, GPIO5, TOUCH5, ADC1_CH4 6 6 I/O/T RTC_GPIO6, GPIO6, TOUCH6, ADC1_CH5 7 7 I/O/T RTC_GPIO7, GPIO7, TOUCH7, ADC1_CH6 8 15 I/O/T RTC_GPIO15, GPIO15, U0RTS, ADC2_CH4, XTAL_32K_P 9 16 I/O/T RTC_GPIO16, GPIO16, U0CTS, ADC2_CH5, XTAL_32K_N 10 17 I/O/T RTC_GPIO17, GPIO17, U1TXD, ADC2_CH6 11 18 I/O/T RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, CLK_OUT3 12 8 I/O/T RTC_GPIO8, GPIO8, TOUCH8, ADC1_CH7, SUBSPICS1 13 3 I/O/T RTC_GPIO3, GPIO3, TOUCH3, ADC1_CH2 14 46 I/O/T GPIO46 15 9 I/O/T RTC_GPIO9, GPIO9, TOUCH9, ADC1_CH8, FSPIHD, SUBSPIHD 16 10 I/O/T RTC_GPIO10, GPIO10, TOUCH10, ADC1_CH9, FSPICS0, FSPIIO4, SUBSPICS0 17 11 I/O/T RTC_GPIO11, GPIO11, TOUCH11, ADC2_CH0, FSPID, FSPIIO5, SUBSPID 18 12 I/O/T RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6, SUBSPICLK 19 13 I/O/T RTC_GPIO13, GPIO13, TOUCH13, ADC2_CH2, FSPIQ, FSPIIO7, SUBSPIQ 20 14 I/O/T RTC_GPIO14, GPIO14, TOUCH14, ADC2_CH3, FSPIWP, FSPIDQS, SUBSPIWP TI A EN FI D N O 21 5V P 5 V power supply 22 G G Ground No. Name Type Function 1 G G Ground 2 TX I/O/T U0TXD, GPIO43, CLK_OUT1 C L No. J3 Name Type Function 3 RX I/O/T U0RXD, GPIO44, CLK_OUT2 4 1 I/O/T RTC_GPIO1, GPIO1, TOUCH1, ADC1_CH0 5 2 I/O/T RTC_GPIO2, GPIO2, TOUCH2, ADC1_CH1 6 42 I/O/T MTMS, GPIO42 7 41 I/O/T MTDI, GPIO41, CLK_OUT1 8 40 I/O/T MTDO, GPIO40, CLK_OUT2 9 39 I/O/T MTCK, GPIO39, CLK_OUT3, SUBSPICS1 10 38 I/O/T GPIO38, FSPIWP, SUBSPIWP 11 37 I/O/T SPIDQS, GPIO37, FSPIQ, SUBSPIQ 12 36 I/O/T SPIIO7, GPIO36, FSPICLK, SUBSPICLK 13 35 I/O/T SPIIO6, GPIO35, FSPID, SUBSPID 14 0 I/O/T RTC_GPIO0, GPIO0 15 45 I/O/T GPIO45 16 48 I/O/T GPIO48 2, SPICLK_N, SUBSPICLK_N_DIFF 17 47 I/O/T GPIO47, SPICLK_P, SUBSPICLK_P_DIFF 18 21 I/O/T RTC_GPIO21, GPIO21 19 20 I/O/T RTC_GPIO20, GPIO20, U1CTS, ADC2_CH9, CLK_OUT1, USB_D+ 20 19 I/O/T RTC_GPIO19, GPIO19, U1RTS, ADC2_CH8, CLK_OUT2, USB_D- 21 G G Ground 22 G G Ground P: Power supply; I: Input; O: Output; T: High impedance. O Used to drive the RGB LED. C Pin Layout TI A EN FI D N 1 2 L No. L TI A ESP32-S3-DevKitC-1 Pin Layout (click to enlarge) No previous versions available. EN Hardware Revision Details Provide feedback about this document FI D  Previous Next  © Copyright 2016 - 2021, Espressif Systems (Shanghai) Co., Ltd C O N Built with Sphinx using a theme based on Read the Docs Sphinx Theme.  Download PDF
ESP32-S3-DEVKITC-1-N8R2 价格&库存
很抱歉,暂时无法提供与“ESP32-S3-DEVKITC-1-N8R2”相匹配的价格&库存,您可以联系我们找货
