Industrial mSATA Specification
(ACHIEVER SERIES, SLC)
Version 1.5
Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585
Tel : +65-6493 5035
Fax : +65-6493 5037
Website: http://www.flexxon.com
Email: flexxon@flexxon.com
ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED,
OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON.
TABLE OF CONTENTS
1.
2.
GENERAL DESCRIPTION ............................................................................ 1
1.1.
Introduction ....................................................................................................................... 1
1.2.
Product Overview .............................................................................................................. 2
PRODUCT SPECIFICATIONS ....................................................................... 3
2.1.
Performance ....................................................................................................................... 3
2.2.
Power ................................................................................................................................. 3
2.3.
TBW (Terabytes Written) .................................................................................................. 4
2.4.
MTBF ................................................................................................................................ 4
2.5.
Data Retention ................................................................................................................... 4
3.
ENVIRONMENTAL SPECIFICATIONS .......................................................... 5
4.
ATA COMMANDS ........................................................................................ 6
5.
PIN ASSIGNMENT ...................................................................................... 9
6.
PHYSICAL DIMENSION ............................................................................ 11
7.
ORDERING INFORMATION ...................................................................... 12
1. GENERAL DESCRIPTION
1.1. Introduction
FLEXXON’s ACHIEVER mSATA has SATA III interface, and is fully compliant with standard mSATA form
factor, known as JEDEC MO-300. It supports high performance, high reliability and low power
management. It is suitable for heavy-loading or multi-tasking applications.
Figure 1-1 ACHIEVER mSATA Controller Block Diagram
1
1.2. Product Overview
Flash
SLC
Capacity
2GB up to 32GB
SATA Interface
Compliant with SATA Revision 3.1
Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface
ECC Scheme
Up to 66 bits error in 1K Byte data.
UART Function
GPIO
Support SMART and TRIM commands
Low Power Management
Internal data shaping technique increase data endurance
Global Wear Leveling Algorithm
Hardware Write Protect (Optional)
Temperature Range
Operation (Silver): 0°C ~ 70°C
Operation (Diamond): -40°C ~ 85°C
Storage: -55°C ~ 85°C
RoHS Compliant
2
2. PRODUCT SPECIFICATIONS
2.1. Performance
Table 2-1 Performance of ACHIEVER mSATA
Capacity
Sequential
Read (MB/s)
Write (MB/s)
2GB
38
34
4GB
42
36
8GB
84
77
16GB
169
149
32GB
172
156
NOTES:
1. The performance was measured using CrystalDiskMark with SATA 6Gbps Host.
2. Performance may differ according to flash configuration and platform.
2.2. Power
Table 2-2 Supply Voltage of ACHIEVER mSATA
Parameter
Parameter Specifications
Input Voltage
3.3V +/-5%
Table 2-3 Power Consumption of ACHEIVER mSATA
Parameter
Specifications(W)
Idle (max.)
0.372W
Active (max.)
1.425W
NOTE:
1. Power Consumption may differ from flash configuration and platform.
3
2.3. TBW (Terabytes Written)
Capacity
TBW
2GB
108
4GB
120
8GB
240
16GB
481
32GB
962
NOTES:
1. TBW may differ according to flash configuration and platform.
2. Samples were tested under JESD218A endurance test method and JESD219A endurance
workloads specification.
2.4. MTBF
MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value
represents the average time between a repair and the next failure. The predicted result of FLEXXON’s
ACHIEVER mSATA is more than 2 million hours.
2.5. Data Retention
10 years if > 90% life remaining (@25C)
1 year if < 10% life remaining (@25C)
4
3. ENVIRONMENTAL SPECIFICATIONS
Test Items
Test Conditions
Storage Temperature
-55°C ~ 95°C
Operating Temperature
Silver Grade: 0°C ~ 70°C
Diamond Grade: -40°C~ 85°C
Storage Humidity
Silver Grade: 40°C, 95% RH
Diamond Grade: 55°C, 95% RH
Operating Humidity
Silver Grade: 40°C, 93% RH
Shock
1500G, Half Sin Pulse Duration 0.5ms
Vibration
80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min
Drop
80cm free fall, 6 face of each unit, 2 times each
Bending
≥50N, Hold 1 min/5 times
ESD
24°C, 49% RH, +/-4KV 25 times, Air +/-8KV 10 times
5
4. ATA COMMANDS
Table 4-1 Supported ATA Command Set
Command
Code
Protocol
Execute Drive Diagnostic
90h
Device diagnostic
Flush Cache
E7h
Non-data
Identify Device
ECh
PIO data-in
Initialize Drive Parameters
91h
Non-data
Read DMA
C8h
DMA
Read Log Ext
2Fh
PIO data-in
Read Multiple
C4h
PIO data-in
Read Sector(s)
20h
PIO data-in
General Feature Set
40h or
Read Verify Sector(s)
41h
Non-data
Set Feature
EFh
Non-data
Set Multiple Mode
C6h
Non-data
Write DMA
CAh
DMA
Write Multiple
C5h
PIO data-out
Write Sector(s)
30h
PIO data-out
NOP
00h
Non-data
Read Buffer
E4h
PIO data-in
Write Buffer
E8h
PIO data-out
Power Management Feature Set
E5h or
Check Power Mode
98h
E3h or
Idle
97h
E1h or
Idle Immediate
95h
E6h or
Sleep
99h
E2h or
Standby
96h
E0h or
Standby Immediate
94h
6
Non-data
Non-data
Non-data
Non-data
Non-data
Non-data
Security Mode Feature Set
Security Set Password
F1h
PIO data-out
Security Unlock
F2h
PIO data-out
Security Erase Prepare
F3h
Non-data
Security Erase Unit
F4h
PIO data-out
Security Freeze Lock
F5h
Non-data
Security Disable Password
F6h
PIO data-out
SMART Disable Operations
B0h
Non-data
SMART Enable/Disable Autosave
B0h
Non-data
SMART Enable Operations
B0h
Non-data
SMART Execute Off-Line Immediate
B0h
Non-data
SMART Read Log
B0h
PIO data-in
SMART Read Data
B0h
PIO data-in
SMART Read Threshold
B0h
PIO data-in
SMART Return Status
B0h
Non-data
SMART Save Attribute Values
B0h
Non-data
SMART Write Log
B0h
PIO data-in
Read Native Max Address
F8h
Non-data
Set Max Address
F9h
Non-data
Set Max Set Password
F9h
PIO data-out
Set Max Lock
F9h
Non-data
Set Max Freeze Lock
F9h
Non-data
Set Max Unlock
F9h
PIO data-out
Flush Cache Ext
EAh
Non-data
Read Sector(s) Ext
24h
PIO data-in
Read DMA Ext
25h
DMA
Read Multiple Ext
29h
PIO data-in
Read Native Max Address Ext
27h
Non-data
Read Verify Sector(s) Ext
42h
Non-data
Set Max Address Ext
37h
Non-data
Write DMA Ext
35h
DMA
Write Multiple Ext
39h
PIO data-out
Write Sector(s) Ext
34h
PIO data-out
60h
DMA Queued
SMART Feature Set
Host Protected Area Feature Set
48-bit Address Feature Set
NCQ Feature Set
Read FPDMA Queued
7
Write FPDMA Queued
61h
DMA Queued
Data Set Management
06h
DMA
Seek
70h
Non-data
Others
8
5. PIN ASSIGNMENT
Table 5-1 Pin Assignment and Description of ACHIEVER mSATA
Pin #
mSATA Pin
Description
1
NC
No Connect
2
+3.3V
3.3V Source
3
NC
No Connect
4
GND
Ground
5
NC
No Connect
6
NC
No Connect
7
NC
No Connect
8
NC
No Connect
9
GND
Ground
10
NC
No Connect
11
NC
No Connect
12
NC
No Connect
13
NC
No Connect
14
NC
No Connect
15
GND
Ground
16
NC
No Connect
17
NC
No Connect
18
GND
Ground
19
NC
No Connect
NC
No Connect
21
GND
Ground
22
NC
No Connect
23
TXP (out)
Host Receiver Differential Signal Pair
24
+3.3V
3.3V Source
25
TXN (out)
26
GND
Ground
27
GND
Ground
28
NC
No Connect
29
GND
Ground
30
NC
No Connect
31
RXN (in)
Host Transmitter Differential Signal Pair
32
NC
No Connect
9
Pin #
mSATA Pin
Description
33
RXP (in)
34
GND
Ground
35
GND
Ground
36
NC
No Connect
37
GND
Ground
38
NC
No Connect
39
+3.3V
3.3V Source
40
GND
Ground
41
+3.3V
3.3V Source
42
NC
No Connect
43
NC
No Connect
44
NC
No Connect
45
NC
Reserved pin
46
NC
No Connect
47
NC
No Connect
48
NC
No Connect
49
DAS
Device Activity Signal
50
GND
Ground
51
PD
Presence Detect (0 ohm to 220 ohm)
52
+3.3V
3.3V Source
10
6. PHYSICAL DIMENSION
Dimension (mm): 50.8 (L) x 29.85 (W) x 3.83 (H)
11
7. ORDERING INFORMATION
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
2GB
FSSE002GSE-M100
FSSE002GSS-M100
4GB
FSSE004GSE-M100
FSSE004GSS-M100
8GB
FSSE008GSE-M100
FSSE008GSS-M100
16GB
FSSE016GSE-M100
FSSE016GSS-M100
32GB
FSSE032GSE-M100
FSSE032GSS-M100
30GB
FSSE030GSE-M100
FSSE030GSS-M100
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
2GB
FSSE002GSE-M10K
FSSE002GSS-M10K
4GB
FSSE004GSE-M10K
FSSE004GSS-M10K
8GB
FSSE008GSE-M10K
FSSE008GSS-M10K
16GB
FSSE016GSE-M10K
FSSE016GSS-M10K
32GB
FSSE032GSE-M10K
FSSE032GSS-M10K
30GB
FSSE030GSE-M10K
FSSE030GSS-M10K
Hardware Write Protect and Conformal Coating
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
2GB
FSSE002GSE-M10F
FSSE002GSS-M10F
4GB
FSSE004GSE-M10F
FSSE004GSS-M10F
8GB
FSSE008GSE-M10F
FSSE008GSS-M10F
16GB
FSSE016GSE-M10F
FSSE016GSS-M10F
32GB
FSSE032GSE-M10F
FSSE032GSS-M10F
30GB
FSSE030GSE-M10F
FSSE030GSS-M10F
12
Revision History
Revision
Date
Description
1.0
2017/05
First release
1.1
2017/12
Update Product Overview
1.2
2018/05
Update Ordering information
1.3
2019/01
Update part number
1.4
2019/11
Update capacity
1.5
2020/04
Update capacity
13
很抱歉,暂时无法提供与“FSSE016GSE-M100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+1616.433895+209.88590
