FSSE008GSE-M100
FSSE008GSE-M100
    FLEXXON
    固态硬盘(SSD) FLASH - NAND(SLC) 8GB SATA III mSATA 3.3V
FSSE008GSE-M100 数据手册
Industrial mSATA Specification (ACHIEVER SERIES, SLC) Version 1.5 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................ 1 1.1. Introduction ....................................................................................................................... 1 1.2. Product Overview .............................................................................................................. 2 PRODUCT SPECIFICATIONS ....................................................................... 3 2.1. Performance ....................................................................................................................... 3 2.2. Power ................................................................................................................................. 3 2.3. TBW (Terabytes Written) .................................................................................................. 4 2.4. MTBF ................................................................................................................................ 4 2.5. Data Retention ................................................................................................................... 4 3. ENVIRONMENTAL SPECIFICATIONS .......................................................... 5 4. ATA COMMANDS ........................................................................................ 6 5. PIN ASSIGNMENT ...................................................................................... 9 6. PHYSICAL DIMENSION ............................................................................ 11 7. ORDERING INFORMATION ...................................................................... 12 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s ACHIEVER mSATA has SATA III interface, and is fully compliant with standard mSATA form factor, known as JEDEC MO-300. It supports high performance, high reliability and low power management. It is suitable for heavy-loading or multi-tasking applications. Figure 1-1 ACHIEVER mSATA Controller Block Diagram 1 1.2. Product Overview Flash   SLC Capacity   2GB up to 32GB SATA Interface   Compliant with SATA Revision 3.1  Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface ECC Scheme   Up to 66 bits error in 1K Byte data.  UART Function  GPIO  Support SMART and TRIM commands  Low Power Management  Internal data shaping technique increase data endurance  Global Wear Leveling Algorithm  Hardware Write Protect (Optional)  Temperature Range  ■ Operation (Silver): 0°C ~ 70°C ■ Operation (Diamond): -40°C ~ 85°C ■ Storage: -55°C ~ 85°C RoHS Compliant 2 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of ACHIEVER mSATA Capacity Sequential Read (MB/s) Write (MB/s) 2GB 38 34 4GB 42 36 8GB 84 77 16GB 169 149 32GB 172 156 NOTES: 1. The performance was measured using CrystalDiskMark with SATA 6Gbps Host. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of ACHIEVER mSATA Parameter Parameter Specifications Input Voltage 3.3V +/-5% Table 2-3 Power Consumption of ACHEIVER mSATA Parameter Specifications(W) Idle (max.) 0.372W Active (max.) 1.425W NOTE: 1. Power Consumption may differ from flash configuration and platform. 3 2.3. TBW (Terabytes Written) Capacity TBW 2GB 108 4GB 120 8GB 240 16GB 481 32GB 962 NOTES: 1. TBW may differ according to flash configuration and platform. 2. Samples were tested under JESD218A endurance test method and JESD219A endurance workloads specification. 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s ACHIEVER mSATA is more than 2 million hours. 2.5. Data Retention   10 years if > 90% life remaining (@25C) 1 year if < 10% life remaining (@25C) 4 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -55°C ~ 95°C Operating Temperature Silver Grade: 0°C ~ 70°C Diamond Grade: -40°C~ 85°C Storage Humidity Silver Grade: 40°C, 95% RH Diamond Grade: 55°C, 95% RH Operating Humidity Silver Grade: 40°C, 93% RH Diamond Grade: 55°C, 95% RH Shock 1500G, Half Sin Pulse Duration 0.5ms Vibration 80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min Drop 80cm free fall, 6 face of each unit, 2 times each Bending ≥50N, Hold 1 min/5 times ESD 24°C, 49% RH, +/-4KV 25 times, Air +/-8KV 10 times 5 4. ATA COMMANDS Table 4-1 Supported ATA Command Set # Command Code Protocol Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Initialize Drive Parameters 91h Non-data Read DMA C8h DMA Read Log Ext 2Fh PIO data-in Read Multiple C4h PIO data-in Read Sector(s) 20h PIO data-in General Feature Set 40h or Read Verify Sector(s) 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out Write Sector(s) 30h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Power Management Feature Set E5h or Check Power Mode 98h E3h or Idle 97h E1h or Idle Immediate 95h E6h or Sleep 99h E2h or Standby 96h E0h or Standby Immediate 94h 6 Non-data Non-data Non-data Non-data Non-data Non-data Security Mode Feature Set Security Set Password F1h PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Execute Off-Line Immediate B0h Non-data SMART Read Log B0h PIO data-in SMART Read Data B0h PIO data-in SMART Read Threshold B0h PIO data-in SMART Return Status B0h Non-data SMART Save Attribute Values B0h Non-data SMART Write Log B0h PIO data-in Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Flush Cache Ext EAh Non-data Read Sector(s) Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Read Native Max Address Ext 27h Non-data Read Verify Sector(s) Ext 42h Non-data Set Max Address Ext 37h Non-data Write DMA Ext 35h DMA Write Multiple Ext 39h PIO data-out Write Sector(s) Ext 34h PIO data-out 60h DMA Queued SMART Feature Set Host Protected Area Feature Set 48-bit Address Feature Set NCQ Feature Set Read FPDMA Queued 7 Write FPDMA Queued 61h DMA Queued Data Set Management 06h DMA Seek 70h Non-data Others 8 5. PIN ASSIGNMENT Table 5-1 Pin Assignment and Description of ACHIEVER mSATA Pin # mSATA Pin Description 1 NC No Connect 2 +3.3V 3.3V Source 3 NC No Connect 4 GND Ground 5 NC No Connect 6 NC No Connect 7 NC No Connect 8 NC No Connect 9 GND Ground 10 NC No Connect 11 NC No Connect 12 NC No Connect 13 NC No Connect 14 NC No Connect 15 GND Ground 16 NC No Connect 17 NC No Connect 18 GND Ground 19 NC No Connect 20 NC No Connect 21 GND Ground 22 NC No Connect 23 TXP (out) Host Receiver Differential Signal Pair 24 +3.3V 3.3V Source 25 TXN (out) Host Receiver Differential Signal Pair 26 GND Ground 27 GND Ground 28 NC No Connect 29 GND Ground 30 NC No Connect 31 RXN (in) Host Transmitter Differential Signal Pair 32 NC No Connect 9 Pin # mSATA Pin Description 33 RXP (in) Host Transmitter Differential Signal Pair 34 GND Ground 35 GND Ground 36 NC No Connect 37 GND Ground 38 NC No Connect 39 +3.3V 3.3V Source 40 GND Ground 41 +3.3V 3.3V Source 42 NC No Connect 43 NC No Connect 44 NC No Connect 45 NC Reserved pin 46 NC No Connect 47 NC No Connect 48 NC No Connect 49 DAS Device Activity Signal 50 GND Ground 51 PD Presence Detect (0 ohm to 220 ohm) 52 +3.3V 3.3V Source 10 6. PHYSICAL DIMENSION Dimension (mm): 50.8 (L) x 29.85 (W) x 3.83 (H) 11 7. ORDERING INFORMATION Capacity MPN (Diamond Grade) MPN (Silver Grade) 2GB FSSE002GSE-M100 FSSE002GSS-M100 4GB FSSE004GSE-M100 FSSE004GSS-M100 8GB FSSE008GSE-M100 FSSE008GSS-M100 16GB FSSE016GSE-M100 FSSE016GSS-M100 32GB FSSE032GSE-M100 FSSE032GSS-M100 30GB FSSE030GSE-M100 FSSE030GSS-M100 Hardware Write Protect Capacity MPN (Diamond Grade) MPN (Silver Grade) 2GB FSSE002GSE-M10K FSSE002GSS-M10K 4GB FSSE004GSE-M10K FSSE004GSS-M10K 8GB FSSE008GSE-M10K FSSE008GSS-M10K 16GB FSSE016GSE-M10K FSSE016GSS-M10K 32GB FSSE032GSE-M10K FSSE032GSS-M10K 30GB FSSE030GSE-M10K FSSE030GSS-M10K Hardware Write Protect and Conformal Coating Capacity MPN (Diamond Grade) MPN (Silver Grade) 2GB FSSE002GSE-M10F FSSE002GSS-M10F 4GB FSSE004GSE-M10F FSSE004GSS-M10F 8GB FSSE008GSE-M10F FSSE008GSS-M10F 16GB FSSE016GSE-M10F FSSE016GSS-M10F 32GB FSSE032GSE-M10F FSSE032GSS-M10F 30GB FSSE030GSE-M10F FSSE030GSS-M10F 12 Revision History Revision Date Description 1.0 2017/05 First release 1.1 2017/12 Update Product Overview 1.2 2018/05 Update Ordering information 1.3 2019/01 Update part number 1.4 2019/11 Update capacity 1.5 2020/04 Update capacity 13
FSSE008GSE-M100 价格&库存
很抱歉,暂时无法提供与“FSSE008GSE-M100”相匹配的价格&库存,您可以联系我们找货
FSSE008GSE-M100
  • 1+1245.419701+161.12828
  • 10+1147.8351710+148.50312
  • 25+1109.9128825+143.59686
  • 50+1081.7721950+139.95611
库存:2
