FCCB6400BC-FD00
FCCB6400BC-FD00
    FLEXXON
    固态硬盘(SSD) FLASH - NAND(TLC) 6.4TB NVMe U.2 模块
FCCB6400BC-FD00 数据手册
Enterprise PCIe U.2 SSD Specification (EMP I PRO Series, 3D NAND) Version 1.1 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ..................................................................................................... 3 1.1. Introduction .....................................................................................................................3 1.2 Product Overview.............................................................................................................3 PRODUCT SPECIFICATIONS ................................................................................................ 4 2.1. Performance ....................................................................................................................4 2.2. Power ...............................................................................................................................4 2.3. DWPD (Drive Write Per Day) ............................................................................................4 2.4. MTBF ................................................................................................................................5 2.5. Data Retention .................................................................................................................5 3. ENVIRONMENTAL SPECIFICATIONS ................................................................................... 6 4. SUPPORTED COMMANDS ................................................................................................. 7 5. PIN ASSIGNMENT .............................................................................................................. 8 6. PHYSICAL DIMENSION ..................................................................................................... 11 7. ORDERING INFORMATION .............................................................................................. 12 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s Enterprise EMP I PRO U.2 PCIe SSD has PCIe Gen4x4 interface, and is fully compliant with NVMe 1.4 industrial standard. It supports ultimate performance, high density and great reliability, suitable for enterprise application. 1.2 Product Overview Capacity ❖ ■ 3.2TB~ 12.8TB Flash ❖ ■ 3D NAND PCIe Interface ❖ ■ PCIe Gen4 x4 lanes ■ Compliant with NVMe 1.4a ■ Compatible with PCIe I/II/III x4 interface ECC Scheme ❖ ■ LDPC (Low Density Parity Check) of ECC algorithm ❖ Dynamic and Static Wear Leveling ❖ Support SMART commands ❖ Power Loss Protection Algorithm ❖ Support AES 256/TCG OPAL (Optional) ❖ RAID ❖ Temperature Range ■ ■ ❖ Operation: 0°C ~ 70°C Storage: -40°C ~ 85°C RoHS Compliant 3 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Sustained Performance of EMP I PRO U.2 PCIe SSD Sequential Capacity Read (MB/s) Write (MB/s) 7,500 6,000 3.2TB ~ 12.8TB NOTES: 1. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of EMP I PRO U.2 PCIe SSD Parameter Rating Operating Voltage 12V Table 2-3 Power Consumption of EMP I PRO U.2 PCIe SSD Capacity Power Consumption, W Maximum Idle 18.0 5.0 3.2TB ~ 12.8TB 2.3. DWPD (Drive Write Per Day) Capacity DWPD 3.2TB 3 6.4TB 3 12.8TB 3 4 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s EMP I PRO PCIe U.2 SSD is more than 2 million hours. 2.5. Data Retention • • 10 years if > 90% life remaining (@25C) 1 year if < 10% life remaining (@25C) 5 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -40°C ~ 85°C Operating Temperature 0°C ~ 70°C Storage Humidity 40°C, 95% RH Operating Humidity 40°C, 95% RH Shock 1000G, Half Sin Pulse Duration 0.5ms Vibration 2.17Grms (5~700Hz) ESD +/-8KV 6 4. SUPPORTED COMMANDS Table 4-1 NVMe Management Interface Command Set support Identifier Command Support Descriptio Read NVMe-MI Data Structure YES 01h NVM nSubsystem Health Status Poll YES 02h Controller Health Status Poll YES 03h Configuration Set YES 04h Configuration Get YES 05h VPD Read YES 06h VPD Write NO 07h Reset NO 08h SES Receive NO 09h SES Send NO 0Ah Management Endpoint Buffer Read NO 0Bh Management Endpoint Buffer Write NO 0Ch to BFh Reserved NO C0h to FFh Vendor specific NO 00h 7 5. PIN ASSIGNMENT Figure 5-1 EMP I PRO U.2 PCIe SSD Pin Locations Table 5-1 U.2 PCIe SSD SFF-8639 Connector Pin Assignment and Descriptions Pin Number Name Description P1 NC P2 NC P3 NC P4 IfDet# P5 GND Ground P6 GND Ground P7 NC P8 NC P9 NC P10 PRSNT# Presence detect P11 ACTIVITY# Activity indicator P12 GND P13 +12V Precharge P14 +12V 12V POWER P15 +12V 12V POWER S1 GND Ground S2 NC S3 NC S4 GND Interface type Detect Ground +12V Prercharge POWER Ground 8 Pin Number Name Description S5 NC S6 NC S7 GND Ground S8 GND Ground S9 NC S10 NC S11 GND S12 NC S13 NC S14 GND Ground S15 RSVD Reserved S16 GND Ground S17 PETp1 Transmitter differential pair, Lane 1 S18 PETn1 Transmitter differential pair, Lane 1 S19 GND S20 PERn1 Receiver differential pair, Lane 1 S21 PERp1 Receiver differential pair, Lane 1 S22 GND S23 PETp2 Transmitter differential pair, Lane 2 S24 PETn2 Transmitter differential pair, Lane 2 S25 GND S26 PERn2 Receiver differential pair, Lane 2 S27 PERp2 Receiver differential pair, Lane 2 S28 GND E1 REFCLK1+ Reference clock for dual port E2 REFCLK1- Reference clock for dual port E3 +3.3 Vaux 3.3 V auxiliary power E4 PERST1# / CLKREQ E5 PERST0# E6 RSVD E7 REFCLK0+ Reference clock E8 REFCLK0- Reference clock E9 GND E10 PETp0 Transmitter differential pair, Lane 0 E11 PETn0 Transmitter differential pair, Lane 0 E12 GND Ground Ground Ground Ground Ground Fundamental reset for dual port, Clkreq for signal port Fundamental reset Reserved Ground Ground 9 Pin Number Name Description E13 PERn0 Receiver differential pair, Lane 0 E14 PERp0 Receiver differential pair, Lane 0 E15 GND Ground E16 RSVD Reserved E17 PETp3 Transmitter differential pair, Lane 3 E18 PETn3 Transmitter differential pair, Lane 3 E19 GND E20 PERn3 Receiver differential pair, Lane 3 E21 PERp3 Receiver differential pair, Lane 3 E22 GND E23 SMBCLK SMBus (System Management Bus) clock E24 SMBDAT SMBus (System Management Bus) data E25 DualPortEn# Ground Ground Dual-port Enable 10 6. PHYSICAL DIMENSION Dimension: 100.2mm(L) x 69.9mm(W) x 14.80mm(H) 11 7. ORDERING INFORMATION Capacity MPN 3.2TB FCCB3200BC-FD00 6.4TB FCCB6400BC-FD00 12.8TB FCCB128TBC-FD00 12 Revision History Revision Date Description 1.0 2022/06 Preliminary release 1.1 2022/07 Update product information 13
FCCB6400BC-FD00 价格&库存
很抱歉,暂时无法提供与“FCCB6400BC-FD00”相匹配的价格&库存,您可以联系我们找货
FCCB6400BC-FD00
  • 1+31909.983751+4126.22132
库存:2
