FUUD002GSE-H600
FUUD002GSE-H600
    FLEXXON
    模块
    存储器 - 模块 FLASH - NAND(SLC) 2GB 模块
FUUD002GSE-H600 数据手册
Industrial USB 2.0 Flash Module Specification (FxAlp Series, SLC) Version 1.5 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................. 1 1.1. Introduction........................................................................................................................ 1 1.2. Product Overview .............................................................................................................. 2 PRODUCT SPECIFICATIONS........................................................................ 3 2.1. Performance ....................................................................................................................... 3 2.2. Power ................................................................................................................................. 3 2.3. MTBF ................................................................................................................................ 4 2.4. Data Retention ................................................................................................................... 4 3. ENVIRONMENTAL SPECIFICATIONS........................................................... 5 4. PIN ASSIGNMENT ....................................................................................... 6 5. PHYSICAL DIMENSION ............................................................................... 8 6. ORDERING INFORMATION ......................................................................... 9 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s Industrial USB Flash Module (FxAlp series) is fully compatible with USB specification (USB1.1 / USB 2.0). It offers super performance & fast data transfer especially in 4K random write. Moreover, it also offers wide compatibility and high reliability, suitable for different type of applications and built-in systems in any rigorous environment. 1 1.2. Product Overview  Flash  SLC Capacity   1GB up to 32GB High IOPS   AES 128 & 256 bits encryption engine. Conformal Coating (Anti-Dust & Anti-Moisture).  Compatible with USB specification revision 1.1 and 2.0.  Support Windows 2000 SP4 and Windows XP without device driver.  Support Windows Vista and Windows 7 without device driver.  Support MAC OS X and later without device driver (USB 1.1 speed).  Support MAC OS 10.2.8 and later without device driver (USB 2.0 speed).  Support Linux Kernel ver2.4.0 or above without device driver (USB 1.1  speed). Support Linux Kernel ver2.4.10 or above without device driver (USB 2.0  speed). ECC Scheme   BCH ECC Engine correct up to 96 bits error in 1K Byte Data  No external power is required—DC 4.5V-5.5V from USB port.  Transfer rate for USB interface:  High speed up to 480Mbits/sec for USB 2.0  Full speed up to 12Mbits/sec for USB 1.1  Low Power Consumption  Sudden Power Loss Management  Dynamic, Static & Global Wear Leveling Algorithm  Temperature Range  ■ Operation: -40°C ~ 85°C ■ Storage: -40°C ~ 85°C RoHS Compliant 2 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of FxAlp UFM Sequential Random Max. Read (MB/s) Max. Write (MB/s) Max. Read (IOPS) Max. Write (IOPS) 31 23 2000 1000 NOTES: 1. The performance was measured using CrystalDiskMark. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of FxAlp UFM Parameter Rating Operating Voltage 5V +/-5% Table 2-3 Power Consumption of FxAlp UFM Capacity 1GB ~ 32GB Item Power Consumption (mA) Active
FUUD002GSE-H600
物料型号: - 系列名称:FxAlp - 容量范围:1GB至32GB - 型号示例:FUUD001GSE-H600(1GB)、FUUD032GSE-H600(32GB)
器件简介: - 完全兼容USB规范(USB1.1 / USB 2.0) - 特别在4K随机写入时提供超高性能和快速数据传输 - 具有广泛的兼容性和高可靠性,适用于各种应用和内置系统 - 支持AES 128位和256位加密引擎 - 支持USB规范修订版1.1和2.0 - 无需设备驱动支持Windows 2000 SP4、Windows XP、Windows Vista、Windows 7、MAC OS X及更高版本(USB 1.1速度)、MAC OS 10.2.8及更高版本(USB 2.0速度)、Linux内核版本2.4.0或以上(USB 1.1速度)、Linux内核版本2.4.10或以上(USB 2.0速度) - 具有BCH ECC引擎,可在1KB数据中纠正多达96位的错误 - 无需外部电源,从USB端口提供DC 4.5V-5.5V - USB接口传输速率:USB 2.0高达480Mbits/sec,USB 1.1高达12Mbits/sec - 低功耗,具有突发电源丢失管理、动态、静态和全局磨损均衡算法 - 工作温度范围:-40°C至85°C,存储温度范围:-40°C至85°C - 符合RoHS标准
引脚分配: - 引脚1:VCC,5.0V USB总线电源输入 - 引脚2、4、6、8、10:NC(无连接) - 引脚3:DM,USB2.0数据输入负端 - 引脚5:DP,USB2.0数据输入正端 - 引脚7:GND,OV调节器地参考输入 - 引脚9:Key(键)
参数特性: - 顺序读取最大31MB/s,顺序写入最大23MB/s - 随机读取最大IOPS 2000,随机写入最大IOPS 1000 - 工作电压:5V+/-5% - 功耗:活动状态<160mA,空闲状态<60mA - MTBF(平均故障间隔时间):超过200万小时 - 数据保持:在25°C下,如果剩余寿命超过90%,则为10年;如果剩余寿命小于10%,则为1年
功能详解: - 支持ECC方案,具有BCH ECC引擎 - 无需外部电源,直接从USB端口获取电源 - 具有突发电源丢失管理和磨损均衡算法 - 符合RoHS标准,适用于工业环境
应用信息: - 适用于需要高性能和高可靠性的工业应用 - 支持多种操作系统,无需额外驱动程序
封装信息: - 物理尺寸:36.9(长)x 26.6(宽)x 9.6(高)mm
FUUD002GSE-H600 价格&库存
很抱歉,暂时无法提供与“FUUD002GSE-H600”相匹配的价格&库存,您可以联系我们找货
FUUD002GSE-H600
  • 1+2049.425491+265.91127
  • 10+1886.6751510+244.79454
  • 25+1823.8513125+236.64320
库存:4
