Industrial M.2 2242 Specification
(INSPIRE Series, 3D TLC)
Version 1.5
Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585
Tel : +65-6493 5035
Fax : +65-6493 5037
Website: http://www.flexxon.com
Email: flexxon@flexxon.com
ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED,
OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON.
TABLE OF CONTENTS
1.
2.
GENERAL DESCRIPTION ............................................................................. 1
1.1.
Introduction........................................................................................................................ 1
1.2.
Product Overview .............................................................................................................. 1
1.3.
Power Loss Protection (Optional) ..................................................................................... 2
PRODUCT SPECIFICATIONS ........................................................................ 3
2.1.
Performance ....................................................................................................................... 3
2.2.
Power ................................................................................................................................. 3
2.3.
TBW (Terabytes Written) .................................................................................................. 4
2.4.
MTBF ................................................................................................................................ 4
2.5.
Data Retention ................................................................................................................... 4
3.
ENVIRONMENTAL SPECIFICATIONS........................................................... 5
4.
ATA COMMANDS .......................................................................................... 6
5.
PIN ASSIGNMENT ....................................................................................... 8
6.
PHYSICAL DIMENSION ............................................................................. 11
7.
ORDERING INFORMATION ....................................................................... 12
1. GENERAL DESCRIPTION
1.1. Introduction
FLEXXON’s INSPIRE M.2 2242 has SATA III interface, and is fully compliant with standard Next
Generation Form Factor (NGFF) called M.2 Card Format. It supports high performance, high
endurance, good compatibility and provides comprehensive data protection. It is suitable for
multi-tasking application.
1.2. Product Overview
Flash
3D TLC
Capacity
64GB up to 1TB
SATA Interface
Compliant with SATA Revision 3.2
Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface
ECC Scheme
INSPIRE M.2 2242 applies the LDPC (Low Density Parity Check) of ECC algorithm
UART Function
GPIO
Support SMART and TRIM commands
Support DDR3/DDR3L External DRAM
Low Power Management
Power Failure Protection
Data shaping technique for enhanced data endurance
Data Refresh technology for data integrity
Global Wear Levelling Algorithm
AES256 and TCG OPAL (Optional)
Temperature Range
Operation (Silver) : 0°C ~ 70°C
Operation (Diamond) : -40°C ~ 85°C
Storage: -55°C ~ 95°C
RoHS Compliant
1
1.3. Power Loss Protection (Optional)
FLEXXON designs SSD device with a hardware power loss protection mechanism. It has a voltage
drop detector, so when the SSD device detects the host power dropping, the SSD’s power loss
protection circuit will be triggered and begin providing power to the SSD. The SSD then will start to
flush cached data from DRAM memory to NAND flash memory in order to preserve data integrity
and prevent data loss.
Normal operation
Unexpected Power Loss happens
When the SSD detects the host power
The SSD is powered by the host power, and
dropping, the power loss protection circuit
the power loss protection circuit is charged
starts to provide power to the SSD while it
by the host power.
flushes cached data from DRAM to NAND.
Figure 1-power loss protection mechanism
2
2. PRODUCT SPECIFICATIONS
2.1. Performance
Table 2-1 Performance of INSPIRE M.2 2242
Capacity
Sequential
Random
Read (MB/s)
Write (MB/s)
Read (IOPS)
Write (IOPS)
60/64GB
390
242
29907
30933
120/128GB
475
394
50977
46655
240/256GB
549
481
91064
77832
480/512GB
553
502
83594
81079
960GB/1TB
558
505
122568
104775
NOTES:
1. The performance was measured using CrystalDiskMarkv5.0x64 with SATA 6Gbps host.
2. Performance may differ according to flash configuration and platform.
2.2. Power
Table 2-2 Supply Voltage of INSPIRE M.2 2242
Parameter
Rating
Operating Voltage
3.3V +/-5%
Table 2-3 Power Consumption of INSPIRE M.2 2242
Parameter
Power Consumption
Idle (Max.)
0.415W
Active (Max.)
2.362W
NOTE:
1. Power Consumption may differ from flash configuration and platform.
3
2.3. TBW (Terabytes Written)
Capacity
TBW
64GB
95
128GB
191
256GB
384
512GB
769
1TB
1535
NOTES:
1. TBW may differ according to flash configuration and platform.
2. Samples were tested under JESD218A endurance test method and JESD219A endurance
workloads specification.
2.4. MTBF
MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value
represents the average time between a repair and the next failure. The predicted result of
FLEXXON’s INSPIRE M.2 2242 is more than 2 million hours.
2.5. Data Retention
10 years if > 90% life remaining (@25C)
1 year if < 10% life remaining (@25C)
4
3. ENVIRONMENTAL SPECIFICATIONS
Test Items
Test Conditions
Storage Temperature
-55°C ~ 95°C
Operating Temperature
Silver Grade: 0°C ~ 70°C
Diamond Grade: -40°C~ 85°C
Storage Humidity
Silver Grade: 40°C, 95% RH
Diamond Grade: 55°C, 95% RH
Operating Humidity
Silver Grade: 40°C, 93% RH
Shock
1500G, Half Sin Pulse Duration 0.5ms
Vibration
80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min
Drop
80cm free fall, 6 face of each unit
Bending
≥ 20N, Hold 1 min/5 times
ESD
24°C, 49% RH, +/-4KV
5
4. ATA COMMANDS
Table 4-1 Supported ATA Command Set
Command
Code
Protocol
Execute Drive Diagnostic
90h
Device diagnostic
Flush Cache
E7h
Non-data
Identify Device
ECh
PIO data-in
Initialize Drive Parameters
91h
Non-data
Read DMA
C8h
DMA
Read Log Ext
2Fh
PIO data-in
Read Multiple
C4h
PIO data-in
Read Sector(s)
20h
PIO data-in
Read Verify Sector(s)
40h or 41h
Non-data
Set Feature
EFh
Non-data
Set Multiple Mode
C6h
Non-data
Write DMA
CAh
DMA
Write Multiple
C5h
PIO data-out
Write Sector(s)
30h
PIO data-out
NOP
00h
Non-data
Read Buffer
E4h
PIO data-in
Write Buffer
E8h
PIO data-out
Check Power Mode
E5h or 98h
Non-data
Idle
E3h or 97h
Non-data
Idle Immediate
E1h or 95h
Non-data
Sleep
E6h or 99h
Non-data
Standby
E2h or 96h
Non-data
Standby Immediate
E0h or 94h
Non-data
Security Set Password
F1h
PIO data-out
Security Unlock
F2h
PIO data-out
Security Erase Prepare
F3h
Non-data
Security Erase Unit
F4h
PIO data-out
Security Freeze Lock
F5h
Non-data
Security Disable Password
F6h
PIO data-out
General Feature Set
Power Management Feature Set
Security Mode Feature Set
6
SMART Feature Set
SMART Disable Operations
B0h
Non-data
SMART Enable/Disable Autosave
B0h
Non-data
SMART Enable Operations
B0h
Non-data
SMART Execute Off-Line Immediate
B0h
Non-data
SMART Read Data
B0h
PIO data-in
SMART Read Threshold
B0h
PIO data-in
SMART Return Status
B0h
Non-data
SMART Save Attribute Values
B0h
Non-data
Read Native Max Address
F8h
Non-data
Set Max Address
F9h
Non-data
Set Max Set Password
F9h
PIO data-out
Set Max Lock
F9h
Non-data
Set Max Freeze Lock
F9h
Non-data
Set Max Unlock
F9h
PIO data-out
Flush Cache Ext
EAh
Non-data
Read Sector(s) Ext
24h
PIO data-in
Read DMA Ext
25h
DMA
Read Multiple Ext
29h
PIO data-in
Read Native Max Address Ext
27h
Non-data
Read Verify Sector(s) Ext
42h
Non-data
Set Max Address Ext
37h
Non-data
Write DMA Ext
35h
DMA
Write Multiple Ext
39h
PIO data-out
Write Sector(s) Ext
34h
PIO data-out
Read FPDMA Queued
60h
DMA Queued
Write FPDMA Queued
61h
DMA Queued
Data Set Management
06h
DMA
Seek
70h
Non-data
Host Protected Area Feature Set
48-bit Address Feature Set
NCQ Feature Set
Others
7
5. PIN ASSIGNMENT
Table 5-1 Pin Assignment and Description of INSPIRE M.2 2242
Pin #
SATA Pin
Description
1
CONFIG_3 = GND
Ground
2
3.3V
Supply pin
3
GND
Ground
4
3.3V
Supply pin
5
N/C
No Connect
6
N/C
No Connect
7
N/C
No Connect
8
N/C
No Connect
9
N/C
No Connect
Status indicators via LED devices that will be provided by
the system Active Low. A pulled-up LED with series
10
DAS/DSS# (I/O)
11
N/C
12
Module Key
13
Module Key
14
Module Key
15
Module Key
16
Module Key
17
Module Key
18
Module Key
19
Module Key
N/C
No Connect
21
CONFIG_0 = GND
Ground
22
N/C
No Connect
23
N/C
No Connect
24
N/C
No Connect
25
N/C
No Connect
26
N/C
No Connect
27
GND
Ground
28
N/C
No Connect
29
N/C
No Connect
30
N/C
No Connect
current limiting resistor should allow for 9mA when On.
No Connect
8
31
N/C
No Connect
32
N/C
No Connect
33
GND
Ground
34
N/C
No Connect
35
N/C
No Connect
36
N/C
No Connect
37
N/C
No Connect
Device Sleep, Input.
When driven high the host is informing the SSD to enter
38
DEVSLP (I) (0/3.3V)
39
GND
Ground
40
N/C
No Connect
41
SATA A+
SATA differential signals in the SATA specification
42
N/C
No Connect
43
SATA A-
44
N/C
No Connect
45
GND
Ground
46
N/C
No Connect
47
SATA B-
48
N/C
No Connect
49
SATA B+
50
N/C
No Connect
51
GND
Ground
52
N/C
No Connect
53
N/C
No Connect
54
N/C
No Connect
55
N/C
No Connect
56
N/C
Not Connect
57
GND
Ground
58
N/C
No Connect
59
Module Key
60
Module Key
61
Module Key
62
Module Key
63
Module Key
64
Module Key
65
Module Key
a low power state
9
66
Module Key
67
N/C
No Connect
68
N/C
No Connect
69
CONFIG_1 = GND
Defines module type
70
3.3V
Supply pin
71
GND
Ground
72
3.3V
Supply pin
73
GND
Ground
74
3.3V
Supply pin
75
CONFIG_2 = GND
Ground
10
6. PHYSICAL DIMENSION
Dimension: 42mm(L) x 22mm(W) x 3.8mm(H)
11
7. ORDERING INFORMATION
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
64GB
FSSL064GBE-M500
FSSL064GBS-M500
60GB
FSSL060GBE-M500
FSSL060GBS-M500
128GB
FSSL128GBE-M500
FSSL128GBS-M500
120GB
FSSL120GBE-M500
FSSL120GBS-M500
256GB
FSSL256GBE-M500
FSSL256GBS-M500
240GB
FSSL240GBE-M500
FSSL240GBS-M500
512GB
FSSL512GBE-M500
FSSL512GBS-M500
480GB
FSSL480GBE-M500
FSSL480GBS-M500
1TB
FSSL001TBE-M500
FSSL001TBS-M500
960GB
FSSL960GBE-M500
FSSL960GBS-M500
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
64GB
FSSL064GBE-M50P
FSSL064GBS-M50P
60GB
FSSL060GBE-M50P
FSSL060GBS-M50P
128GB
FSSL128GBE-M50P
FSSL128GBS-M50P
120GB
FSSL120GBE-M50P
FSSL120GBS-M50P
256GB
FSSL256GBE-M50P
FSSL256GBS-M50P
240GB
FSSL240GBE-M50P
FSSL240GBS-M50P
512GB
FSSL512GBE-M50P
FSSL512GBS-M50P
480GB
FSSL480GBE-M50P
FSSL480GBS-M50P
1TB
FSSL001TBE-M50P
FSSL001TBS-M50P
960GB
FSSL960GBE-M50P
FSSL960GBS-M50P
12
AES 256 and TCG OPAL
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
64GB
FSSL064GBE-M50S
FSSL064GBS-M50S
60GB
FSSL060GBE-M50S
FSSL060GBS-M50S
128GB
FSSL128GBE-M50S
FSSL128GBS-M50S
120GB
FSSL120GBE-M50S
FSSL120GBS-M50S
256GB
FSSL256GBE-M50S
FSSL256GBS-M50S
240GB
FSSL240GBE-M50S
FSSL240GBS-M50S
512GB
FSSL512GBE-M50S
FSSL512GBS-M50S
480GB
FSSL480GBE-M50S
FSSL480GBS-M50S
1TB
FSSL001TBE-M50S
FSSL001TBS-M50S
960GB
FSSL960GBE-M50S
FSSL960GBS-M50S
13
Revision History
Revision
Draft Date
History
1.0
2019/08
Preliminary release
1.1
2019/11
Update performance
1.2
2020/05
Update Ordering Information
1.3
2021/07
1.4
2021/09
1.5
2021/09
Update Capacity
14
很抱歉,暂时无法提供与“FSSL256GBE-M500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1386.477031+179.83053
- 10+1277.5425910+165.70138
- 25+1235.2548525+160.21653
- 50+1203.8962850+156.14922
