FSSL512GBE-M500
FSSL512GBE-M500
    FLEXXON
    固态硬盘(SSD) FLASH - NAND(TLC) 512GB SATA III M.2 模块
FSSL512GBE-M500 数据手册
Industrial M.2 2242 Specification (INSPIRE Series, 3D TLC) Version 1.5 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................. 1 1.1. Introduction........................................................................................................................ 1 1.2. Product Overview .............................................................................................................. 1 1.3. Power Loss Protection (Optional) ..................................................................................... 2 PRODUCT SPECIFICATIONS ........................................................................ 3 2.1. Performance ....................................................................................................................... 3 2.2. Power ................................................................................................................................. 3 2.3. TBW (Terabytes Written) .................................................................................................. 4 2.4. MTBF ................................................................................................................................ 4 2.5. Data Retention ................................................................................................................... 4 3. ENVIRONMENTAL SPECIFICATIONS........................................................... 5 4. ATA COMMANDS .......................................................................................... 6 5. PIN ASSIGNMENT ....................................................................................... 8 6. PHYSICAL DIMENSION ............................................................................. 11 7. ORDERING INFORMATION ....................................................................... 12 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s INSPIRE M.2 2242 has SATA III interface, and is fully compliant with standard Next Generation Form Factor (NGFF) called M.2 Card Format. It supports high performance, high endurance, good compatibility and provides comprehensive data protection. It is suitable for multi-tasking application. 1.2. Product Overview  Flash  3D TLC  Capacity  64GB up to 1TB  SATA Interface  Compliant with SATA Revision 3.2  Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface  ECC Scheme  INSPIRE M.2 2242 applies the LDPC (Low Density Parity Check) of ECC algorithm  UART Function  GPIO  Support SMART and TRIM commands  Support DDR3/DDR3L External DRAM  Low Power Management  Power Failure Protection  Data shaping technique for enhanced data endurance  Data Refresh technology for data integrity  Global Wear Levelling Algorithm  AES256 and TCG OPAL (Optional)  Temperature Range  ■ Operation (Silver) : 0°C ~ 70°C ■ Operation (Diamond) : -40°C ~ 85°C ■ Storage: -55°C ~ 95°C RoHS Compliant 1 1.3. Power Loss Protection (Optional) FLEXXON designs SSD device with a hardware power loss protection mechanism. It has a voltage drop detector, so when the SSD device detects the host power dropping, the SSD’s power loss protection circuit will be triggered and begin providing power to the SSD. The SSD then will start to flush cached data from DRAM memory to NAND flash memory in order to preserve data integrity and prevent data loss. Normal operation Unexpected Power Loss happens When the SSD detects the host power The SSD is powered by the host power, and dropping, the power loss protection circuit the power loss protection circuit is charged starts to provide power to the SSD while it by the host power. flushes cached data from DRAM to NAND. Figure 1-power loss protection mechanism 2 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of INSPIRE M.2 2242 Capacity Sequential Random Read (MB/s) Write (MB/s) Read (IOPS) Write (IOPS) 60/64GB 390 242 29907 30933 120/128GB 475 394 50977 46655 240/256GB 549 481 91064 77832 480/512GB 553 502 83594 81079 960GB/1TB 558 505 122568 104775 NOTES: 1. The performance was measured using CrystalDiskMarkv5.0x64 with SATA 6Gbps host. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of INSPIRE M.2 2242 Parameter Rating Operating Voltage 3.3V +/-5% Table 2-3 Power Consumption of INSPIRE M.2 2242 Parameter Power Consumption Idle (Max.) 0.415W Active (Max.) 2.362W NOTE: 1. Power Consumption may differ from flash configuration and platform. 3 2.3. TBW (Terabytes Written) Capacity TBW 64GB 95 128GB 191 256GB 384 512GB 769 1TB 1535 NOTES: 1. TBW may differ according to flash configuration and platform. 2. Samples were tested under JESD218A endurance test method and JESD219A endurance workloads specification. 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s INSPIRE M.2 2242 is more than 2 million hours. 2.5. Data Retention  10 years if > 90% life remaining (@25C)  1 year if < 10% life remaining (@25C) 4 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -55°C ~ 95°C Operating Temperature Silver Grade: 0°C ~ 70°C Diamond Grade: -40°C~ 85°C Storage Humidity Silver Grade: 40°C, 95% RH Diamond Grade: 55°C, 95% RH Operating Humidity Silver Grade: 40°C, 93% RH Diamond Grade: 55°C, 95% RH Shock 1500G, Half Sin Pulse Duration 0.5ms Vibration 80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min Drop 80cm free fall, 6 face of each unit Bending ≥ 20N, Hold 1 min/5 times ESD 24°C, 49% RH, +/-4KV 5 4. ATA COMMANDS Table 4-1 Supported ATA Command Set # Command Code Protocol Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Initialize Drive Parameters 91h Non-data Read DMA C8h DMA Read Log Ext 2Fh PIO data-in Read Multiple C4h PIO data-in Read Sector(s) 20h PIO data-in Read Verify Sector(s) 40h or 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out Write Sector(s) 30h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Check Power Mode E5h or 98h Non-data Idle E3h or 97h Non-data Idle Immediate E1h or 95h Non-data Sleep E6h or 99h Non-data Standby E2h or 96h Non-data Standby Immediate E0h or 94h Non-data Security Set Password F1h PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out General Feature Set Power Management Feature Set Security Mode Feature Set 6 SMART Feature Set SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Execute Off-Line Immediate B0h Non-data SMART Read Data B0h PIO data-in SMART Read Threshold B0h PIO data-in SMART Return Status B0h Non-data SMART Save Attribute Values B0h Non-data Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Flush Cache Ext EAh Non-data Read Sector(s) Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Read Native Max Address Ext 27h Non-data Read Verify Sector(s) Ext 42h Non-data Set Max Address Ext 37h Non-data Write DMA Ext 35h DMA Write Multiple Ext 39h PIO data-out Write Sector(s) Ext 34h PIO data-out Read FPDMA Queued 60h DMA Queued Write FPDMA Queued 61h DMA Queued Data Set Management 06h DMA Seek 70h Non-data Host Protected Area Feature Set 48-bit Address Feature Set NCQ Feature Set Others 7 5. PIN ASSIGNMENT Table 5-1 Pin Assignment and Description of INSPIRE M.2 2242 Pin # SATA Pin Description 1 CONFIG_3 = GND Ground 2 3.3V Supply pin 3 GND Ground 4 3.3V Supply pin 5 N/C No Connect 6 N/C No Connect 7 N/C No Connect 8 N/C No Connect 9 N/C No Connect Status indicators via LED devices that will be provided by the system Active Low. A pulled-up LED with series 10 DAS/DSS# (I/O) 11 N/C 12 Module Key 13 Module Key 14 Module Key 15 Module Key 16 Module Key 17 Module Key 18 Module Key 19 Module Key 20 N/C No Connect 21 CONFIG_0 = GND Ground 22 N/C No Connect 23 N/C No Connect 24 N/C No Connect 25 N/C No Connect 26 N/C No Connect 27 GND Ground 28 N/C No Connect 29 N/C No Connect 30 N/C No Connect current limiting resistor should allow for 9mA when On. No Connect 8 31 N/C No Connect 32 N/C No Connect 33 GND Ground 34 N/C No Connect 35 N/C No Connect 36 N/C No Connect 37 N/C No Connect Device Sleep, Input. When driven high the host is informing the SSD to enter 38 DEVSLP (I) (0/3.3V) 39 GND Ground 40 N/C No Connect 41 SATA A+ SATA differential signals in the SATA specification 42 N/C No Connect 43 SATA A- SATA differential signals in the SATA specification 44 N/C No Connect 45 GND Ground 46 N/C No Connect 47 SATA B- SATA differential signals in the SATA specification 48 N/C No Connect 49 SATA B+ SATA differential signals in the SATA specification 50 N/C No Connect 51 GND Ground 52 N/C No Connect 53 N/C No Connect 54 N/C No Connect 55 N/C No Connect 56 N/C Not Connect 57 GND Ground 58 N/C No Connect 59 Module Key 60 Module Key 61 Module Key 62 Module Key 63 Module Key 64 Module Key 65 Module Key a low power state 9 66 Module Key 67 N/C No Connect 68 N/C No Connect 69 CONFIG_1 = GND Defines module type 70 3.3V Supply pin 71 GND Ground 72 3.3V Supply pin 73 GND Ground 74 3.3V Supply pin 75 CONFIG_2 = GND Ground 10 6. PHYSICAL DIMENSION Dimension: 42mm(L) x 22mm(W) x 3.8mm(H) 11 7. ORDERING INFORMATION Capacity MPN (Diamond Grade) MPN (Silver Grade) 64GB FSSL064GBE-M500 FSSL064GBS-M500 60GB FSSL060GBE-M500 FSSL060GBS-M500 128GB FSSL128GBE-M500 FSSL128GBS-M500 120GB FSSL120GBE-M500 FSSL120GBS-M500 256GB FSSL256GBE-M500 FSSL256GBS-M500 240GB FSSL240GBE-M500 FSSL240GBS-M500 512GB FSSL512GBE-M500 FSSL512GBS-M500 480GB FSSL480GBE-M500 FSSL480GBS-M500 1TB FSSL001TBE-M500 FSSL001TBS-M500 960GB FSSL960GBE-M500 FSSL960GBS-M500 Capacity MPN (Diamond Grade) MPN (Silver Grade) 64GB FSSL064GBE-M50P FSSL064GBS-M50P 60GB FSSL060GBE-M50P FSSL060GBS-M50P 128GB FSSL128GBE-M50P FSSL128GBS-M50P 120GB FSSL120GBE-M50P FSSL120GBS-M50P 256GB FSSL256GBE-M50P FSSL256GBS-M50P 240GB FSSL240GBE-M50P FSSL240GBS-M50P 512GB FSSL512GBE-M50P FSSL512GBS-M50P 480GB FSSL480GBE-M50P FSSL480GBS-M50P 1TB FSSL001TBE-M50P FSSL001TBS-M50P 960GB FSSL960GBE-M50P FSSL960GBS-M50P Power Loss Protection 12 AES 256 and TCG OPAL Capacity MPN (Diamond Grade) MPN (Silver Grade) 64GB FSSL064GBE-M50S FSSL064GBS-M50S 60GB FSSL060GBE-M50S FSSL060GBS-M50S 128GB FSSL128GBE-M50S FSSL128GBS-M50S 120GB FSSL120GBE-M50S FSSL120GBS-M50S 256GB FSSL256GBE-M50S FSSL256GBS-M50S 240GB FSSL240GBE-M50S FSSL240GBS-M50S 512GB FSSL512GBE-M50S FSSL512GBS-M50S 480GB FSSL480GBE-M50S FSSL480GBS-M50S 1TB FSSL001TBE-M50S FSSL001TBS-M50S 960GB FSSL960GBE-M50S FSSL960GBS-M50S 13 Revision History Revision Draft Date History 1.0 2019/08 Preliminary release 1.1 2019/11 Update performance 1.2 2020/05 Update Ordering Information 1.3 2021/07 Update Ordering Information 1.4 2021/09 Update Ordering Information 1.5 2021/09 Update Capacity 14
FSSL512GBE-M500 价格&库存
很抱歉,暂时无法提供与“FSSL512GBE-M500”相匹配的价格&库存,您可以联系我们找货
