Industrial M.2 2280 Specification
(INSPIRE SERIES, 3D TLC)
Version 1.7
Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585
Tel : +65-6493 5035
Fax : +65-6493 5037
Website: http://www.flexxon.com
Email: flexxon@flexxon.com
ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED,
OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON.
TABLE OF CONTENTS
1.
2.
GENERAL DESCRIPTION ............................................................................ 3
1.1.
Introduction ....................................................................................................................... 3
1.2.
Product Overview .............................................................................................................. 3
1.3.
Power Loss Protection (Optional) ..................................................................................... 4
PRODUCT SPECIFICATIONS ....................................................................... 5
2.1.
Performance ....................................................................................................................... 5
2.2.
Power ................................................................................................................................. 5
2.3.
TBW (Terabytes Written) .................................................................................................. 6
2.4.
MTBF ................................................................................................................................ 6
2.5.
Data Retention ................................................................................................................... 6
3.
ENVIRONMENTAL SPECIFICATIONS .......................................................... 7
4.
ATA COMMANDS ........................................................................................ 8
5.
PIN ASSIGNMENT .................................................................................... 10
6.
PHYSICAL DIMENSION ............................................................................ 13
7.
ORDERING INFORMATION ...................................................................... 14
1. GENERAL DESCRIPTION
1.1. Introduction
FLEXXON’s INSPIRE M.2 2280 has SATA III interface, and is fully compliant with the standard Next
Generation Form Factor (NGFF) called M.2 Card Format Form Factor. It supports high performance,
high endurance, good compatibility and provides comprehensive data protection. It is suitable for
multi-tasking application.
1.2. Product Overview
Flash
3D TLC
Capacity
32GB up to 2TB
SATA Interface
Compliant with SATA Revision 3.1
Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface
ECC Scheme
INSPIRE M.2 2280 applies the LDPC (Low Density Parity Check) of ECC algorithm
UART Function
GPIO
Support SMART and TRIM commands
Support DDR3/DDR3L External DRAM
Low Power Management
Power Failure Protection (Optional)
Data shaping technique for enhanced data endurance
Data Refresh technology for data integrity
Global Wear Leveling Algorithm
AES256 and TCG Opal (Optional)
Temperature Range
Operation (Silver) : 0°C ~ 70°C
Operation (Diamond) : -40°C ~ 85°C
Storage: -55°C ~ 95°C
RoHS Compliant
3
1.3. Power Loss Protection (Optional)
FLEXXON designs SSD device with a hardware power loss protection mechanism. It has a voltage
drop detector, so when the SSD device detects the host power dropping, the SSD’s power loss
protection circuit will be triggered and begin providing power to the SSD. The SSD then will start to
flush cached data from DRAM memory to NAND flash memory in order to preserve data integrity
and prevent data loss.
Normal operation
Unexpected Power Loss happens
When the SSD detects the host power
The SSD is powered by the host power, and
dropping, the power loss protection circuit
the power loss protection circuit is charged
starts to provide power to the SSD while it
by the host power.
flushes cached data from DRAM to NAND.
Figure 1-1 power loss protection mechanism
4
2. PRODUCT SPECIFICATIONS
2.1. Performance
Table 2-1 Performance of INSPIRE M.2 2280
Sequential
Capacity
CrystalDiskMark
Read (MB/s)
Write (MB/s)
Read (IOPS)
Write (IOPS)
32GB
300
180
18732
18688
40GB
345
200
25073
27468
60/64GB
351
204
31372
30973
120/128GB
390
402
51147
47144
240/256GB
410
401
91553
78320
480/512GB
563
511
132788
109668
960GB/1TB
563
517
132568
115747
1920GB/2TB
563
512
132635
112758
NOTES:
1.
The performance was measured using CrystalDiskMark with SATA 6Gbps host.
2.
Performance may differ according to flash configuration and platform.
2.2. Power
Table 2-2 Supply Voltage of INSPIRE M.2 2280
Parameter
Rating
Operating Voltage
3.3V +/- 5%
Table 2-3 Power Consumption of INSPIRE M.2 2280
Parameter
Power Consumption
Idle (max.)
0.415W
Active (max.)
2.362W
NOTE:
1. Power Consumption may differ according to flash configuration and platform.
5
2.3. TBW (Terabytes Written)
Capacity
TBW
32GB
60
40GB
93
60/64GB
95
120/128GB
191
240/256GB
384
480/512GB
769
960/1TB
1536
1920/2TB
3077
NOTES:
1. TBW may differ according to flash configuration and platform.
2. Samples were tested under JESD218A endurance test method and JESD219A endurance
workloads specification.
2.4. MTBF
MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value
represents the average time between a repair and the next failure. The predicted result of FLEXXON’s
INSPIRE M.2 2280 is more than 2 million hours.
2.5. Data Retention
10 years if > 90% life remaining (@25C)
1 year if < 10% life remaining (@25C)
6
3. ENVIRONMENTAL SPECIFICATIONS
Test Items
Test Conditions
Storage Temperature
-55°C ~ 95°C
Operating Temperature
Silver Grade: 0°C ~ 70°C
Diamond Grade: -40°C~ 85°C
Storage Humidity
Silver Grade: 40°C, 95% RH
Diamond Grade: 55°C, 95% RH
Operating Humidity
Silver Grade: 40°C, 93% RH
Shock
1500G, Half Sin Pulse Duration 0.5ms
Vibration
80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min
Drop
80cm free fall, 6 face of each unit, 2 times each
Bending
≥ 20N, Hold 1 min/5 times
ESD
24°C, 49% RH, +/-4KV 25 times, Air +/-8KV 10 times
7
4. ATA COMMANDS
Table 4-1 Supported ATA Command Set
Command
Code
Protocol
Execute Drive Diagnostic
90h
Device diagnostic
Flush Cache
E7h
Non-data
Identify Device
ECh
PIO data-in
Initialize Drive Parameters
91h
Non-data
Read DMA
C8h
DMA
Read Log Ext
2Fh
PIO data-in
Read Multiple
C4h
PIO data-in
Read Sector(s)
20h
PIO data-in
General Feature Set
40h or
Read Verify Sector(s)
41h
Non-data
Set Feature
EFh
Non-data
Set Multiple Mode
C6h
Non-data
Write DMA
CAh
DMA
Write Multiple
C5h
PIO data-out
Write Sector(s)
30h
PIO data-out
NOP
00h
Non-data
Read Buffer
E4h
PIO data-in
Write Buffer
E8h
PIO data-out
Power Management Feature Set
E5h or
Check Power Mode
98h
E3h or
Idle
97h
E1h or
Idle Immediate
95h
E6h or
Sleep
99h
E2h or
Standby
96h
E0h or
Standby Immediate
94h
Non-data
Non-data
Non-data
Non-data
Non-data
Non-data
Security Mode Feature Set
Security Set Password
F1h
8
PIO data-out
Security Unlock
F2h
PIO data-out
Security Erase Prepare
F3h
Non-data
Security Erase Unit
F4h
PIO data-out
Security Freeze Lock
F5h
Non-data
Security Disable Password
F6h
PIO data-out
SMART Disable Operations
B0h
Non-data
SMART Enable/Disable Autosave
B0h
Non-data
SMART Enable Operations
B0h
Non-data
SMART Execute Off-Line Immediate
B0h
Non-data
SMART Read Data
B0h
PIO data-in
SMART Read Threshold
B0h
PIO data-in
SMART Return Status
B0h
Non-data
SMART Save Attribute Values
B0h
Non-data
Read Native Max Address
F8h
Non-data
Set Max Address
F9h
Non-data
Set Max Set Password
F9h
PIO data-out
Set Max Lock
F9h
Non-data
Set Max Freeze Lock
F9h
Non-data
Set Max Unlock
F9h
PIO data-out
Flush Cache Ext
Eah
Non-data
Read Sector(s) Ext
24h
PIO data-in
Read DMA Ext
25h
DMA
Read Multiple Ext
29h
PIO data-in
Read Native Max Address Ext
27h
Non-data
Read Verify Sector(s) Ext
42h
Non-data
Set Max Address Ext
37h
Non-data
Write DMA Ext
35h
DMA
Write Multiple Ext
39h
PIO data-out
Write Sector(s) Ext
34h
PIO data-out
Read FPDMA Queued
60h
DMA Queued
Write FPDMA Queued
61h
DMA Queued
Data Set Management
06h
DMA
Seek
70h
Non-data
SMART Feature Set
Host Protected Area Feature Set
48-bit Address Feature Set
NCQ Feature Set
Others
9
5. PIN ASSIGNMENT
Table 5-1 Pin Assignment and Description of INSPIRE M.2 2280
Pin #
SATA Pin
Description
1
CONFIG_3 = GND
Ground
2
3.3V
Supply pin
3
GND
Ground
4
3.3V
Supply pin
5
N/C
No Connect
6
N/C
No Connect
7
N/C
No Connect
8
N/C
No Connect
9
N/C
No Connect
Status indicators via LED devices that will be provided by the
system Active Low. A pulled-up LED with series current
10
DAS/DSS# (I/O)
11
N/C
12
Module Key
13
Module Key
14
Module Key
15
Module Key
16
Module Key
17
Module Key
18
Module Key
19
Module Key
N/C
No Connect
21
CONFIG_0 = GND
Ground
22
N/C
No Connect
23
N/C
No Connect
24
N/C
No Connect
25
N/C
No Connect
26
N/C
No Connect
27
GND
Ground
28
N/C
No Connect
29
N/C
No Connect
30
N/C
No Connect
limiting resistor should allow for 9mA when On.
No Connect
10
31
N/C
No Connect
32
N/C
No Connect
33
GND
Ground
34
N/C
No Connect
35
N/C
No Connect
36
N/C
No Connect
37
N/C
No Connect
Device Sleep, Input.
When driven high the host is informing the SSD to enter a
38
DEVSLP (I) (0/3.3V)
39
GND
Ground
40
N/C
No Connect
41
SATA A+
SATA differential signals in the SATA specification
42
N/C
No Connect
43
SATA A-
44
N/C
No Connect
45
GND
Ground
46
N/C
No Connect
47
SATA B-
48
N/C
No Connect
49
SATA B+
50
N/C
No Connect
51
GND
Ground
52
N/C
No Connect
53
N/C
No Connect
54
N/C
No Connect
55
N/C
No Connect
56
N/C
Not Connect
57
GND
Ground
58
N/C
No Connect
59
Module Key
60
Module Key
61
Module Key
62
Module Key
63
Module Key
64
Module Key
65
Module Key
low power state
11
66
Module Key
67
N/C
No Connect
68
N/C
No Connect
69
CONFIG_1 = GND
Defines module type
70
3.3V
Supply pin
71
GND
Ground
72
3.3V
Supply pin
73
GND
Ground
74
3.3V
Supply pin
75
CONFIG_2 = GND
Ground
12
6. PHYSICAL DIMENSION
Dimension: 80mm(L) x 22 mm(W) x 3.8mm(H)
13
7. ORDERING INFORMATION
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSO032GBS-M500
40GB
FSSO040GBE-M500
FSSO040GBS-M500
64GB
FSSO064GBE-M500
FSSO064GBS-M500
60GB
FSSO060GBE-M500
FSSO060GBS-M500
128GB
FSSO128GBE-M500
FSSO128GBS-M500
120GB
FSSO120GBE-M500
FSSO120GBS-M500
256GB
FSSO256GBE-M500
FSSO256GBS-M500
240GB
FSSO240GBE-M500
FSSO240GBS-M500
512GB
FSSO512GBE-M500
FSSO512GBS-M500
480GB
FSSO480GBE-M500
FSSO480GBS-M500
1TB
FSSO001TBE-M500
FSSO001TBS-M500
960GB
FSSO960GBE-M500
FSSO960GBS-M500
2TB
FSSO002TBE-M500
FSSO002TBS-M500
1920GB
FSSO1920BE-M500
FSSO1920BS-M500
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSO032GBS-M50V
40GB
FSSO040GBE-M50V
FSSO040GBS-M50V
64GB
FSSO064GBE-M50V
FSSO064GBS-M50V
60GB
FSSO060GBE-M50V
FSSO060GBS-M50V
128GB
FSSO128GBE-M50V
FSSO128GBS-M50V
120GB
FSSO120GBE-M50V
FSSO120GBS-M50V
256GB
FSSO256GBE-M50V
FSSO256GBS-M50V
240GB
FSSO240GBE-M50V
FSSO240GBS-M50V
512GB
FSSO512GBE-M50V
FSSO512GBS-M50V
480GB
FSSO480GBE-M50V
FSSO480GBS-M50V
1TB
FSSO001TBE-M50V
FSSO001TBS-M50V
960GB
FSSO960GBE-M50V
FSSO960GBS-M50V
2TB
FSSO002TBE-M50V
FSSO002TBS-M50V
1920GB
FSSO1920BE-M50V
FSSO1920BS-M50V
TCG OPAL and conformal coating
14
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSO032GBS-M50P
40GB
FSSO040GBE-M50P
FSSO040GBS-M50P
64GB
FSSO064GBE-M50P
FSSO064GBS-M50P
60GB
FSSO060GBE-M50P
FSSO060GBS-M50P
128GB
FSSO128GBE-M50P
FSSO128GBS-M50P
120GB
FSSO120GBE-M50P
FSSO120GBS-M50P
256GB
FSSO256GBE-M50P
FSSO256GBS-M50P
240GB
FSSO240GBE-M50P
FSSO240GBS-M50P
512GB
FSSO512GBE-M50P
FSSO512GBS-M50P
480GB
FSSO480GBE-M50P
FSSO480GBS-M50P
1TB
FSSO001TBE-M50P
FSSO001TBS-M50P
960GB
FSSO960GBE-M50P
FSSO960GBS-M50P
2TB
FSSO002TBE-M50P
FSSO002TBS-M50P
1920GB
FSSO1920BE-M50P
FSSO1920BS-M50P
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSO032GBS-M50S
40GB
FSSO040GBE-M50S
FSSO040GBS-M50S
64GB
FSSO064GBE-M50S
FSSO064GBS-M50S
60GB
FSSO060GBE-M50S
FSSO060GBS-M50S
128GB
FSSO128GBE-M50S
FSSO128GBS-M50S
120GB
FSSO120GBE-M50S
FSSO120GBS-M50S
256GB
FSSO256GBE-M50S
FSSO256GBS-M50S
240GB
FSSO240GBE-M50S
FSSO240GBS-M50S
512GB
FSSO512GBE-M50S
FSSO512GBS-M50S
480GB
FSSO480GBE-M50S
FSSO480GBS-M50S
1TB
FSSO001TBE-M50S
FSSO001TBS-M50S
960GB
FSSO960GBE-M50S
FSSO960GBS-M50S
2TB
FSSO002TBE-M50S
FSSO002TBS-M50S
1920GB
FSSO1920BE-M50S
FSSO1920BS-M50S
AES 256 and TCG OPAL
15
Conformal coating and Power Loss Protection
Capacity
MPN (Diamond Grade)
MPN (Silver Grade)
32GB
FSSO032GBS-M50D
40GB
FSSO040GBE-M50D
FSSO040GBS-M50D
64GB
FSSO064GBE-M50D
FSSO064GBS-M50D
60GB
FSSO060GBE-M50D
FSSO060GBS-M50D
128GB
FSSO128GBE-M50D
FSSO128GBS-M50D
120GB
FSSO120GBE-M50D
FSSO120GBS-M50D
256GB
FSSO256GBE-M50D
FSSO256GBS-M50D
240GB
FSSO240GBE-M50D
FSSO240GBS-M50D
512GB
FSSO512GBE-M50D
FSSO512GBS-M50D
480GB
FSSO480GBE-M50D
FSSO480GBS-M50D
1TB
FSSO001TBE-M50D
FSSO001TBS-M50D
960GB
FSSO960GBE-M50D
FSSO960GBS-M50D
2TB
FSSO002TBE-M50D
FSSO002TBS-M50D
1920GB
FSSO1920BE-M50D
FSSO1920BS-M50D
16
Revision History
Revision
Date
Description
1.0
2019/07
Preliminary release
1.1
2019/08
Update capacity
1.2
2019/09
Update ordering information
1.3
2019/12
Update capacity and performance
1.4
2020/03
1.5
2021/04
1.6
2022/02
Update capacity
1.7
2022/04
17
很抱歉,暂时无法提供与“FSSO001TBS-M500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2876.052671+373.16546
- 10+2645.8773710+343.30040
- 25+2557.4094125+331.82176
