FSSO512GBS-M50S
FSSO512GBS-M50S
    FLEXXON
    固态硬盘(SSD) FLASH - NAND(TLC) 512GB SATA III M.2 模块 3.3V
FSSO512GBS-M50S 数据手册
Industrial M.2 2280 Specification (INSPIRE SERIES, 3D TLC) Version 1.7 Address: 28 Genting Lane, #09-03/4/5 Platinum 28, Singapore 349585 Tel : +65-6493 5035 Fax : +65-6493 5037 Website: http://www.flexxon.com Email: flexxon@flexxon.com ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. TABLE OF CONTENTS 1. 2. GENERAL DESCRIPTION ............................................................................ 3 1.1. Introduction ....................................................................................................................... 3 1.2. Product Overview .............................................................................................................. 3 1.3. Power Loss Protection (Optional) ..................................................................................... 4 PRODUCT SPECIFICATIONS ....................................................................... 5 2.1. Performance ....................................................................................................................... 5 2.2. Power ................................................................................................................................. 5 2.3. TBW (Terabytes Written) .................................................................................................. 6 2.4. MTBF ................................................................................................................................ 6 2.5. Data Retention ................................................................................................................... 6 3. ENVIRONMENTAL SPECIFICATIONS .......................................................... 7 4. ATA COMMANDS ........................................................................................ 8 5. PIN ASSIGNMENT .................................................................................... 10 6. PHYSICAL DIMENSION ............................................................................ 13 7. ORDERING INFORMATION ...................................................................... 14 ALL RIGHTS ARE STRICTLY RESERVED. ANY PORTION OF THIS PAPER SHALL NOT BE REPRODUCED, COPIED, OR TRANSLATED TO ANY OTHER FORMS WITHOUT PERMISSION FROM FLEXXON. 1. GENERAL DESCRIPTION 1.1. Introduction FLEXXON’s INSPIRE M.2 2280 has SATA III interface, and is fully compliant with the standard Next Generation Form Factor (NGFF) called M.2 Card Format Form Factor. It supports high performance, high endurance, good compatibility and provides comprehensive data protection. It is suitable for multi-tasking application. 1.2. Product Overview Flash   3D TLC Capacity   32GB up to 2TB SATA Interface   Compliant with SATA Revision 3.1  Compatible with SATA 1.5Gbps, 3Gbps and 6Gbps interface ECC Scheme   INSPIRE M.2 2280 applies the LDPC (Low Density Parity Check) of ECC algorithm  UART Function  GPIO  Support SMART and TRIM commands  Support DDR3/DDR3L External DRAM  Low Power Management  Power Failure Protection (Optional)  Data shaping technique for enhanced data endurance  Data Refresh technology for data integrity  Global Wear Leveling Algorithm  AES256 and TCG Opal (Optional)  Temperature Range  ■ Operation (Silver) : 0°C ~ 70°C ■ Operation (Diamond) : -40°C ~ 85°C ■ Storage: -55°C ~ 95°C RoHS Compliant 3 1.3. Power Loss Protection (Optional) FLEXXON designs SSD device with a hardware power loss protection mechanism. It has a voltage drop detector, so when the SSD device detects the host power dropping, the SSD’s power loss protection circuit will be triggered and begin providing power to the SSD. The SSD then will start to flush cached data from DRAM memory to NAND flash memory in order to preserve data integrity and prevent data loss. Normal operation Unexpected Power Loss happens When the SSD detects the host power The SSD is powered by the host power, and dropping, the power loss protection circuit the power loss protection circuit is charged starts to provide power to the SSD while it by the host power. flushes cached data from DRAM to NAND. Figure 1-1 power loss protection mechanism 4 2. PRODUCT SPECIFICATIONS 2.1. Performance Table 2-1 Performance of INSPIRE M.2 2280 Sequential Capacity CrystalDiskMark Read (MB/s) Write (MB/s) Read (IOPS) Write (IOPS) 32GB 300 180 18732 18688 40GB 345 200 25073 27468 60/64GB 351 204 31372 30973 120/128GB 390 402 51147 47144 240/256GB 410 401 91553 78320 480/512GB 563 511 132788 109668 960GB/1TB 563 517 132568 115747 1920GB/2TB 563 512 132635 112758 NOTES: 1. The performance was measured using CrystalDiskMark with SATA 6Gbps host. 2. Performance may differ according to flash configuration and platform. 2.2. Power Table 2-2 Supply Voltage of INSPIRE M.2 2280 Parameter Rating Operating Voltage 3.3V +/- 5% Table 2-3 Power Consumption of INSPIRE M.2 2280 Parameter Power Consumption Idle (max.) 0.415W Active (max.) 2.362W NOTE: 1. Power Consumption may differ according to flash configuration and platform. 5 2.3. TBW (Terabytes Written) Capacity TBW 32GB 60 40GB 93 60/64GB 95 120/128GB 191 240/256GB 384 480/512GB 769 960/1TB 1536 1920/2TB 3077 NOTES: 1. TBW may differ according to flash configuration and platform. 2. Samples were tested under JESD218A endurance test method and JESD219A endurance workloads specification. 2.4. MTBF MTBF, an acronym for Mean Time Between Failures, is a measure of a device’s reliability. Its value represents the average time between a repair and the next failure. The predicted result of FLEXXON’s INSPIRE M.2 2280 is more than 2 million hours. 2.5. Data Retention   10 years if > 90% life remaining (@25C) 1 year if < 10% life remaining (@25C) 6 3. ENVIRONMENTAL SPECIFICATIONS Test Items Test Conditions Storage Temperature -55°C ~ 95°C Operating Temperature Silver Grade: 0°C ~ 70°C Diamond Grade: -40°C~ 85°C Storage Humidity Silver Grade: 40°C, 95% RH Diamond Grade: 55°C, 95% RH Operating Humidity Silver Grade: 40°C, 93% RH Diamond Grade: 55°C, 95% RH Shock 1500G, Half Sin Pulse Duration 0.5ms Vibration 80Hz ~ 2000Hz/20G, 20Hz ~ 80Hz/1.52mm, 3 axis/60min Drop 80cm free fall, 6 face of each unit, 2 times each Bending ≥ 20N, Hold 1 min/5 times ESD 24°C, 49% RH, +/-4KV 25 times, Air +/-8KV 10 times 7 4. ATA COMMANDS Table 4-1 Supported ATA Command Set # Command Code Protocol Execute Drive Diagnostic 90h Device diagnostic Flush Cache E7h Non-data Identify Device ECh PIO data-in Initialize Drive Parameters 91h Non-data Read DMA C8h DMA Read Log Ext 2Fh PIO data-in Read Multiple C4h PIO data-in Read Sector(s) 20h PIO data-in General Feature Set 40h or Read Verify Sector(s) 41h Non-data Set Feature EFh Non-data Set Multiple Mode C6h Non-data Write DMA CAh DMA Write Multiple C5h PIO data-out Write Sector(s) 30h PIO data-out NOP 00h Non-data Read Buffer E4h PIO data-in Write Buffer E8h PIO data-out Power Management Feature Set E5h or Check Power Mode 98h E3h or Idle 97h E1h or Idle Immediate 95h E6h or Sleep 99h E2h or Standby 96h E0h or Standby Immediate 94h Non-data Non-data Non-data Non-data Non-data Non-data Security Mode Feature Set Security Set Password F1h 8 PIO data-out Security Unlock F2h PIO data-out Security Erase Prepare F3h Non-data Security Erase Unit F4h PIO data-out Security Freeze Lock F5h Non-data Security Disable Password F6h PIO data-out SMART Disable Operations B0h Non-data SMART Enable/Disable Autosave B0h Non-data SMART Enable Operations B0h Non-data SMART Execute Off-Line Immediate B0h Non-data SMART Read Data B0h PIO data-in SMART Read Threshold B0h PIO data-in SMART Return Status B0h Non-data SMART Save Attribute Values B0h Non-data Read Native Max Address F8h Non-data Set Max Address F9h Non-data Set Max Set Password F9h PIO data-out Set Max Lock F9h Non-data Set Max Freeze Lock F9h Non-data Set Max Unlock F9h PIO data-out Flush Cache Ext Eah Non-data Read Sector(s) Ext 24h PIO data-in Read DMA Ext 25h DMA Read Multiple Ext 29h PIO data-in Read Native Max Address Ext 27h Non-data Read Verify Sector(s) Ext 42h Non-data Set Max Address Ext 37h Non-data Write DMA Ext 35h DMA Write Multiple Ext 39h PIO data-out Write Sector(s) Ext 34h PIO data-out Read FPDMA Queued 60h DMA Queued Write FPDMA Queued 61h DMA Queued Data Set Management 06h DMA Seek 70h Non-data SMART Feature Set Host Protected Area Feature Set 48-bit Address Feature Set NCQ Feature Set Others 9 5. PIN ASSIGNMENT Table 5-1 Pin Assignment and Description of INSPIRE M.2 2280 Pin # SATA Pin Description 1 CONFIG_3 = GND Ground 2 3.3V Supply pin 3 GND Ground 4 3.3V Supply pin 5 N/C No Connect 6 N/C No Connect 7 N/C No Connect 8 N/C No Connect 9 N/C No Connect Status indicators via LED devices that will be provided by the system Active Low. A pulled-up LED with series current 10 DAS/DSS# (I/O) 11 N/C 12 Module Key 13 Module Key 14 Module Key 15 Module Key 16 Module Key 17 Module Key 18 Module Key 19 Module Key 20 N/C No Connect 21 CONFIG_0 = GND Ground 22 N/C No Connect 23 N/C No Connect 24 N/C No Connect 25 N/C No Connect 26 N/C No Connect 27 GND Ground 28 N/C No Connect 29 N/C No Connect 30 N/C No Connect limiting resistor should allow for 9mA when On. No Connect 10 31 N/C No Connect 32 N/C No Connect 33 GND Ground 34 N/C No Connect 35 N/C No Connect 36 N/C No Connect 37 N/C No Connect Device Sleep, Input. When driven high the host is informing the SSD to enter a 38 DEVSLP (I) (0/3.3V) 39 GND Ground 40 N/C No Connect 41 SATA A+ SATA differential signals in the SATA specification 42 N/C No Connect 43 SATA A- SATA differential signals in the SATA specification 44 N/C No Connect 45 GND Ground 46 N/C No Connect 47 SATA B- SATA differential signals in the SATA specification 48 N/C No Connect 49 SATA B+ SATA differential signals in the SATA specification 50 N/C No Connect 51 GND Ground 52 N/C No Connect 53 N/C No Connect 54 N/C No Connect 55 N/C No Connect 56 N/C Not Connect 57 GND Ground 58 N/C No Connect 59 Module Key 60 Module Key 61 Module Key 62 Module Key 63 Module Key 64 Module Key 65 Module Key low power state 11 66 Module Key 67 N/C No Connect 68 N/C No Connect 69 CONFIG_1 = GND Defines module type 70 3.3V Supply pin 71 GND Ground 72 3.3V Supply pin 73 GND Ground 74 3.3V Supply pin 75 CONFIG_2 = GND Ground 12 6. PHYSICAL DIMENSION Dimension: 80mm(L) x 22 mm(W) x 3.8mm(H) 13 7. ORDERING INFORMATION Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSO032GBS-M500 40GB FSSO040GBE-M500 FSSO040GBS-M500 64GB FSSO064GBE-M500 FSSO064GBS-M500 60GB FSSO060GBE-M500 FSSO060GBS-M500 128GB FSSO128GBE-M500 FSSO128GBS-M500 120GB FSSO120GBE-M500 FSSO120GBS-M500 256GB FSSO256GBE-M500 FSSO256GBS-M500 240GB FSSO240GBE-M500 FSSO240GBS-M500 512GB FSSO512GBE-M500 FSSO512GBS-M500 480GB FSSO480GBE-M500 FSSO480GBS-M500 1TB FSSO001TBE-M500 FSSO001TBS-M500 960GB FSSO960GBE-M500 FSSO960GBS-M500 2TB FSSO002TBE-M500 FSSO002TBS-M500 1920GB FSSO1920BE-M500 FSSO1920BS-M500 Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSO032GBS-M50V 40GB FSSO040GBE-M50V FSSO040GBS-M50V 64GB FSSO064GBE-M50V FSSO064GBS-M50V 60GB FSSO060GBE-M50V FSSO060GBS-M50V 128GB FSSO128GBE-M50V FSSO128GBS-M50V 120GB FSSO120GBE-M50V FSSO120GBS-M50V 256GB FSSO256GBE-M50V FSSO256GBS-M50V 240GB FSSO240GBE-M50V FSSO240GBS-M50V 512GB FSSO512GBE-M50V FSSO512GBS-M50V 480GB FSSO480GBE-M50V FSSO480GBS-M50V 1TB FSSO001TBE-M50V FSSO001TBS-M50V 960GB FSSO960GBE-M50V FSSO960GBS-M50V 2TB FSSO002TBE-M50V FSSO002TBS-M50V 1920GB FSSO1920BE-M50V FSSO1920BS-M50V TCG OPAL and conformal coating 14 Power Loss Protection Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSO032GBS-M50P 40GB FSSO040GBE-M50P FSSO040GBS-M50P 64GB FSSO064GBE-M50P FSSO064GBS-M50P 60GB FSSO060GBE-M50P FSSO060GBS-M50P 128GB FSSO128GBE-M50P FSSO128GBS-M50P 120GB FSSO120GBE-M50P FSSO120GBS-M50P 256GB FSSO256GBE-M50P FSSO256GBS-M50P 240GB FSSO240GBE-M50P FSSO240GBS-M50P 512GB FSSO512GBE-M50P FSSO512GBS-M50P 480GB FSSO480GBE-M50P FSSO480GBS-M50P 1TB FSSO001TBE-M50P FSSO001TBS-M50P 960GB FSSO960GBE-M50P FSSO960GBS-M50P 2TB FSSO002TBE-M50P FSSO002TBS-M50P 1920GB FSSO1920BE-M50P FSSO1920BS-M50P Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSO032GBS-M50S 40GB FSSO040GBE-M50S FSSO040GBS-M50S 64GB FSSO064GBE-M50S FSSO064GBS-M50S 60GB FSSO060GBE-M50S FSSO060GBS-M50S 128GB FSSO128GBE-M50S FSSO128GBS-M50S 120GB FSSO120GBE-M50S FSSO120GBS-M50S 256GB FSSO256GBE-M50S FSSO256GBS-M50S 240GB FSSO240GBE-M50S FSSO240GBS-M50S 512GB FSSO512GBE-M50S FSSO512GBS-M50S 480GB FSSO480GBE-M50S FSSO480GBS-M50S 1TB FSSO001TBE-M50S FSSO001TBS-M50S 960GB FSSO960GBE-M50S FSSO960GBS-M50S 2TB FSSO002TBE-M50S FSSO002TBS-M50S 1920GB FSSO1920BE-M50S FSSO1920BS-M50S AES 256 and TCG OPAL 15 Conformal coating and Power Loss Protection Capacity MPN (Diamond Grade) MPN (Silver Grade) 32GB - FSSO032GBS-M50D 40GB FSSO040GBE-M50D FSSO040GBS-M50D 64GB FSSO064GBE-M50D FSSO064GBS-M50D 60GB FSSO060GBE-M50D FSSO060GBS-M50D 128GB FSSO128GBE-M50D FSSO128GBS-M50D 120GB FSSO120GBE-M50D FSSO120GBS-M50D 256GB FSSO256GBE-M50D FSSO256GBS-M50D 240GB FSSO240GBE-M50D FSSO240GBS-M50D 512GB FSSO512GBE-M50D FSSO512GBS-M50D 480GB FSSO480GBE-M50D FSSO480GBS-M50D 1TB FSSO001TBE-M50D FSSO001TBS-M50D 960GB FSSO960GBE-M50D FSSO960GBS-M50D 2TB FSSO002TBE-M50D FSSO002TBS-M50D 1920GB FSSO1920BE-M50D FSSO1920BS-M50D 16 Revision History Revision Date Description 1.0 2019/07 Preliminary release 1.1 2019/08 Update capacity 1.2 2019/09 Update ordering information 1.3 2019/12 Update capacity and performance 1.4 2020/03 Update ordering information 1.5 2021/04 Update ordering information 1.6 2022/02 Update capacity 1.7 2022/04 Update ordering information 17
FSSO512GBS-M50S 价格&库存
很抱歉,暂时无法提供与“FSSO512GBS-M50S”相匹配的价格&库存,您可以联系我们找货
