EN
your power partner | Since 1984 | Over 35 Years of Service
Cleaning & Sterilization Instructions
for Medical Grade Power Supplies & AC Adapters
Models: All GlobTek External Power Supplies
Germicidal disposable cloth wipes, or wipes moistened with Isopropyl
Alcohol 90% or higher Ethanol may be used to clean the Power Supply/AC
Adapter. Cleaning with a wipe moistened with these solutions should be
followed by wiping the Power Supply with distilled water. Caustic or abrasive
cleaners should not be used to clean the Power Supply/AC Adapter.
Acceptable Disinfectants:
• Isopropyl Alcohol
• Ethyl Alcohol
Cleaning & Sterilization Instructions for Medical Grade Power Supplies & AC Adapters
Many medical environments have cleaning and sterilization procedures. While GlobTek Medical
Grade Power Supply AC Adapters are not used to directly treat patients, it is reported that
medical personel may sterilize or clean them in medical environments.
Risk of Shock: Cleaning fluids besides Isopropyl Alcohol
could leave a residue when it dries which may be conductive.
Caution: Do not spray or pour any liquid directly on the
Power Supply or accessories.
Risk of Shock: Ensure Power Supply is disconnected from
mains voltage during and after cleaning until completely dry.
Caution: Do not use caustic or abrasive cleaners, or harsh
solvents, including petroleum-based or acetone solutions, to
clean the device. Other cleaning fluids can cause degradation of the Power Supply materials.
Plastic Housing
Cable Ties
1. Remove Cable Tie(s) from Output and Input
Cords if equipped and in place.
2. Clean all 6 sides of unit Plastic Housing
surface with a disinfectant soaked cloth.
AC Input Blades
Output/Input Cord
3. Clean outstretched Input and Output Cord
sets including the Connectors by pulling thru
a disinfectant soaked cloth down its length.
Output Connector
Do the same for the input cord if applicable.
4. Soak cotton swab with disinfectant and
swab around the AC Input Blades and
around Output Connector.
5. Re-attach Cable Tie(s) if applicable.
System designers and companies incorporating Globtek medical grade Power Supplies into their equipment are responsible for
understanding the application environment where the Power Supply will be used and how it may be sterilized. It is the responsibility of the customer to properly instruct the end users on how and when to sterilize GlobTek power supplies, if appropriate.
©2018-2020 GlobTek, Inc. Manufacturer: GlobTek, Inc, 186 Veterans Drive, Northvale NJ 07647, USA. P/N: F-GT-DJD-8.5.5-2 IFU Rev : Al, 07.09.2020. The acceptance of this user manual and use of the product described
in this document indicates the acceptance and binding of the customer to Globtek terms and conditions, which supersede all other agreements, terms, and conditions (https://en.globtek.com/terms-and-conditions/). The
user of this product (Customer) agrees that they are a sophisticated user who understands the technical specifications and safety implications of use of this product and it is their sole responsibility to determine
suitability/fitness of the product described in this specification for their application and to take precautions for protection against any hazards attendant to the handling and use of the product.
TR9CH8888YL4IMCFR6B 价格&库存
很抱歉,暂时无法提供与“TR9CH8888YL4IMCFR6B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+818.039021+105.81338
- 5+752.214095+97.29892
- 20+699.8022420+90.51945
- 40+674.9797340+87.30865
- 60+660.8715260+85.48376
- 100+643.51370100+83.23852
