ETHERLINE®
UNCONTROLLED COPY
4 pair cable
Data communication systems for Ethernet technology
ETHERLINE® 4 pair: CAT.5e; stationary
Industrial Ethernet cable for stationary applications
Construction
LAPP KABEL
Conductors: solid bare copper
ETHERLINE® CAT.5e
ETHERLINE® 4 pair cables for stationary applications are suitable for CAT.5e
data transmission. Designed with a foil and braid shield, the cable is protected
against EMI and can be used in areas where reliable data transmission is
key. The cable is available with a PUR or halogen-free jacket, or with a double
halogen-free inner and outer jacket.
Recommended applications
Pairs: 4 pairs twisted together
Insulation: foam skin
Shielding: foil and tinned copper braid
Jacket: polyurethane or halogen-free; teal • 2170298:
halogen-free inner & outer jackets
Application advantage
Stationary applications; industrial field and cell level networking; PLCs, sensors,
and other network devices; dry and damp rooms
• Suitable for EtherCAT® & EtherNet/IP applications
• Excellent EMI protection
• Flame retardant
• Suitable for PoE per IEEE 802.3at
Approvals
Cable attributes
page 648
Complete the installation
ÖLFLEX® CONNECT solution
SKINTOP®
MS-SC
See attribute list by part
number on page 234
RJ45
connectors
page 522
ÖLFLEX® CONNECT CABLES
page 605
page 257
Technical data
Minimum bend radius:
- for stationary use: 8 x cable diameter
Characteristic impedance: 100Ω ± 15Ω
Temperature range: -30°C to +80°C
Nominal voltage:
(not for power applications)
- 2170297: 1000V
- 2170296, 2170298: 125V
Test voltage: 1000V
Part
number
CAT.5e
2170296
2170297
2170298
Color code: white/blue & blue,
white/orange & orange,
white/green & green,
white/brown & brown
Approvals:
UL: AWM 21576 (2170297)
Canada: cRU AWM I/II A/B FT2 (2170297)
Additional: RoHS
Construction
Stranding
Jacket
material
Jacket
color
Approvals
Fast
connect
PoE
24 AWG/4pr
24 AWG/4pr
24 AWG/4pr
solid
solid
solid
halogen-free
PUR
halogen-free*
teal
teal
teal
UL/CSA AWM, 1000V
no
no
no
yes
yes
yes
Nominal
outer diameter
in
mm
0.248
0.248
0.296
6.3
6.3
7.5
Approx.
weight
lbs/mft
SKINTOP®
MS-SC
PG thread
36
42
54
53112210
53112210
53112220
* Inner and outer jacket
EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Photographs are not to scale and are not true representations of the products in question.
If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question.
for current information see: www.lappusa.com • www.lappcanada.com
243
很抱歉,暂时无法提供与“2170297”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.261971+4.31139
- 国内价格
- 1+27.00000
- 10+22.68000
