2170296
2170296
    LAPP(缆普)
    8(4 对双绞线) 芯 多线对,Cat5e 线缆 青色 24 AWG 箔,编织线 在订单数量中输入英尺数
2170296 数据手册
ETHERLINE® UNCONTROLLED COPY 4 pair cable Data communication systems for Ethernet technology ETHERLINE® 4 pair: CAT.5e; stationary Industrial Ethernet cable for stationary applications Construction LAPP KABEL Conductors: solid bare copper ETHERLINE® CAT.5e ETHERLINE® 4 pair cables for stationary applications are suitable for CAT.5e data transmission. Designed with a foil and braid shield, the cable is protected against EMI and can be used in areas where reliable data transmission is key. The cable is available with a PUR or halogen-free jacket, or with a double halogen-free inner and outer jacket. Recommended applications Pairs: 4 pairs twisted together Insulation: foam skin Shielding: foil and tinned copper braid Jacket: polyurethane or halogen-free; teal • 2170298: halogen-free inner & outer jackets Application advantage Stationary applications; industrial field and cell level networking; PLCs, sensors, and other network devices; dry and damp rooms • Suitable for EtherCAT® & EtherNet/IP applications • Excellent EMI protection • Flame retardant • Suitable for PoE per IEEE 802.3at Approvals Cable attributes page 648 Complete the installation ÖLFLEX® CONNECT solution SKINTOP® MS-SC See attribute list by part number on page 234 RJ45 connectors page 522 ÖLFLEX® CONNECT CABLES page 605 page 257 Technical data Minimum bend radius: - for stationary use: 8 x cable diameter Characteristic impedance: 100Ω ± 15Ω Temperature range: -30°C to +80°C Nominal voltage: (not for power applications) - 2170297: 1000V - 2170296, 2170298: 125V Test voltage: 1000V Part number CAT.5e 2170296 2170297 2170298 Color code: white/blue & blue, white/orange & orange, white/green & green, white/brown & brown Approvals: UL: AWM 21576 (2170297) Canada: cRU AWM I/II A/B FT2 (2170297) Additional: RoHS Construction Stranding Jacket material Jacket color Approvals Fast connect PoE 24 AWG/4pr 24 AWG/4pr 24 AWG/4pr solid solid solid halogen-free PUR halogen-free* teal teal teal — UL/CSA AWM, 1000V — no no no yes yes yes Nominal outer diameter in mm 0.248 0.248 0.296 6.3 6.3 7.5 Approx. weight lbs/mft SKINTOP® MS-SC PG thread 36 42 54 53112210 53112210 53112220 * Inner and outer jacket EtherCAT® is a registered trademark of Beckhoff Automation GmbH. Photographs are not to scale and are not true representations of the products in question. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. for current information see:  www.lappusa.com • www.lappcanada.com 243
2170296 价格&库存
很抱歉,暂时无法提供与“2170296”相匹配的价格&库存,您可以联系我们找货
