44420037
44420037
    LAPP(缆普)
    针位圆形连接器 插头外壳 自由悬挂 底壳,连接螺母,防拉线扣
44420037 数据手册
EPIC® UNCONTROLLED COPY Circular connectors SIGNAL M23 EPIC® SIGNAL M23 Rugged nickel-plated zinc connectors for power applications Approvals Application advantage • Rugged nickel-plated, die-cast zinc body •P  ositive vibration protection for use with motor drives and moving assemblies • Integral EMC cable gland provides strain relief, IP67/68 protection, and 360° shielding •C  oding rings ensure correct mating selection in multiple connector installations EPIC® SIGNAL M23 connectors are available in 11 housing styles that can accommodate 3 different insert keying positions. Inserts are offered in 7 contact configurations for mounting male or female, crimp, or solder contacts. Common to all arrangements are a rugged nickel-plated zinc body, plastic contact insulation body and sleeve, and gold-plated electrical contacts. Cable mounted arrangements also include an integral EMC shield ring and cable clamp and seal. The figure above shows the general construction of these connectors. The connectors are offered with insert configurations for 6, 7, 8+1, 9, 12, 16 & 17 crimp or solder contacts in either a clockwise or counter-clockwise orientation. Used in combination, they connect one cable to another (cable coupler) or a cable to fixed wiring in a control enclosure or on a machine, instrument, encoder or servo motor. Technical data Number of contacts: 6, 7, 8+1, 9, 12, 16, 17 Temperature range: -25°C to +125°C Rated voltage: - 6, 7, 8+1 & 9 poles: 150V - 12 & 16 poles: 100V - 17 poles: 50V Wire gauge: - crimp termination: - 1 mm contacts: - 2 mm contacts: - solder termination: - 1 mm contacts: - 2 mm contacts: 26 - 18 AWG (0.14 - 1.0 mm²) 18 - 14 AWG (1.0 - 2.5 mm²) up to 18 AWG (1.0 mm²) up to 14 AWG (2.5 mm²) Cable diameter: 7.0 - 13.5 mm Rated current: - 6 & 7 poles: 14A - 8+1, 9, 12, 16 & 17 poles: 7A Impulse voltage: - 6 & 7 poles: - 8+1 poles: - 9, 12 & 16 poles: - 17 poles: Mating cycles: 100 minimum Material: - housing: - style C2: - insulation body: - contacts: - gaskets & seals: 4kV 2.5kV 1.5kV 0.8kV Protection class: IP67/68 (10h/1m) - style A3: IP65 Contact resistance: nickel-plated die-cast zinc nickel-plated copper alloy PA, PBT, V-0 per UL 94 gold-plated copper alloy FPM < 4 mΩ Approvals: DIN EN 61984 cRUus #E75770 446 for current information see: www.lappusa.com • www.lappcanada.com EPIC® UNCONTROLLED COPY SIGNAL M23 Circular connectors EPIC® SIGNAL M23 inserts Connector inserts will accept both male and female contacts. A complete connection requires one E-type insert and one P-type insert. E-type inserts Description without contacts with male solder contacts with female solder contacts insert configurations 6 contacts 7 contacts 8+1 contacts 9 contacts 12 contacts 16 contacts 17 contacts 73002766 44420154 73002742 73002730 73002718 73002706 73008500 73002768 44420156 73002744 73002732 73002720 73002708 73028500 73002770 44420158 73002746 73002734 73002722 73002710 73018500 2 mm contacts 2 mm contacts 1 & 2 mm contacts 1 mm contacts 1 mm contacts 1 mm contacts 1 mm contacts clockwise numbered contacts viewed from the mating side 12 & 17 pole inserts for PCB soldering are available on request (non-stock) P-type inserts Description without contacts with male solder contacts with female solder contacts insert configurations 6 contacts 7 contacts 8+1 contacts 9 contacts 12 contacts 16 contacts 17 contacts 73002760 44420148 73002736 73002724 73002712 73002700 73008000 73002762 44420150 73002738 73002726 73002714 73002702 73028000 73002764 44420152 73002740 73002728 73002716 73002704 73018000 2 mm contacts 2 mm contacts 1 & 2 mm contacts 1 mm contacts 1 mm contacts 1 mm contacts 1 mm contacts counter-clockwise numbered contacts viewed from the mating side 12 & 17 pole inserts for PCB soldering are available on request (non-stock) EPIC® SIGNAL M23 contacts Size AWG mm2 1 mm contacts 26 - 18 0.14 - 1.0 26 - 18 0.14 - 1.0 26 - 18 0.14 - 1.0 up to 18 up to 1.0 up to 18 up to 1.0 Description Termination type Part number gold male contacts gold female contacts HYP gold female contacts gold male contacts gold female contacts crimp crimp crimp solder solder 72400000 74200600 74034500 72402000 72402600 Size AWG mm2 2 mm contacts 18 - 14 1.0 - 2.5 18 - 14 1.0 - 2.5 up to 14 up to 2.5 up to 14 up to 2.5 for current information see:  www.lappusa.com • www.lappcanada.com Description Termination type Part number gold male contacts gold female contacts gold male contacts gold female contacts crimp crimp solder solder 72401000 72401600 72403000 72404000 447 EPIC® UNCONTROLLED COPY Circular connectors SIGNAL M23 EPIC® SIGNAL M23 style A1 Straight panel mount base keying: N keying: -20° keying: +20° all dimensions are in mm Keying Part number N -20° +20° 72004000 72004100 72004200 Contact tools Crimp tool: 11148000 Locator: 11148300 Removal tool: 44420078 Locator: 11148300 Removal tool: 44420078 EPIC® SIGNAL M23 style A3 Angled panel mount base all dimensions are in mm Contact tools Part number 24420055 Crimp tool: 11148000 EPIC® SIGNAL M23 style D6 Cable connector keying: N keying: -20° keying: +20° all dimensions are in mm Keying Part number N -20° +20° 44420037 44420036 44420038 Contact tools Crimp tool: 11148000 Locator: 11148300 If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. 448 for current information see: www.lappusa.com • www.lappcanada.com EPIC® UNCONTROLLED COPY SIGNAL M23 Circular connectors EPIC® SIGNAL M23 style F6 Cable coupler keying: N keying: -20° keying: +20° all dimensions are in mm Keying Part number N -20° +20° 44420040 44420039 44420041 Contact tools Crimp tool: 11148000 Locator: 11148300 EPIC® SIGNAL M23 style F7 Cable coupler with flange all dimensions are in mm Max. cable outer diameter Part number 7 - 10 mm 9.5 - 13.5 mm 44420009 44420011 Contact tools Crimp tool: 11148000 Locator: 11148300 EPIC® SIGNAL M23 style G5 Front wall mounting with locknut or M25 x 1.5 thread mount all dimensions are in mm Keying Part number N -20° +20° 44420046 44420044 44420048 Contact tools Crimp tool: 11148000 Locator: 11148300 Removal tool: 44420078 If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. for current information see:  www.lappusa.com • www.lappcanada.com 449 EPIC® UNCONTROLLED COPY Circular connectors SIGNAL M23 EPIC® SIGNAL M23 style G6 Rear wall mounting all dimensions are in mm Contact tools Part number 44420071 Crimp tool: 11148000 Locator: 11148300 Removal tool: 44420078 Locator: 11148300 Removal tool: 44420078 Locator: 11148300 Removal tool: 44420078 EPIC­® SIGNAL M23 style B1 Rear wall mounting all dimensions are in mm Keying Part number N -20° +20° 44420024 44420022 44420026 Contact tools Crimp tool: 11148000 EPIC® SIGNAL M23 style B2 Rear wall mounting all dimensions are in mm Keying Part number N -20° +20° 44420050 44420052 44420035 Contact tools Crimp tool: 11148000 If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. 450 for current information see: www.lappusa.com • www.lappcanada.com EPIC® UNCONTROLLED COPY SIGNAL M23 Circular connectors EPIC® SIGNAL M23 style C2 Panel mount feed-through all dimensions are in mm Number of contacts Part number 12 17 00010108 00010521 Contact tools Crimp tool: 11148000 Locator: 11148300 Removal tool: 44420078 EPIC® SIGNAL M23 accessories & tools metal screw cap Style1 plastic protection cap removal tool SILVYN® adapter Style 2 Style Connector Style Part number Size Part number 1 2 A, F6, G A, B, F7, O 75018110 75018010 D6 A, B, F, G, O 75007710 75007810 Adapter allows connection to jacketed cable run in SILVYN® conduit. Part number 44420078 Size Part number M20 x 1.5 55001312 If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. for current information see:  www.lappusa.com • www.lappcanada.com 451
44420037 价格&库存
很抱歉,暂时无法提供与“44420037”相匹配的价格&库存,您可以联系我们找货
