2170488
2170488
    LAPP(缆普)
    8(4 对双绞线) 芯 多线对,Cat6 线缆 绿色 26AWG 箔,编织线 在订单数量中输入英尺数
2170488 数据手册
ETHERLINE® Ethernet Cable, Connectors & Tools CAT.6 4 Pair Cable ETHERLINE® 4 Pair: CAT.6; Continuous Flex Industrial Ethernet Cable for Continuous Flex Applications Construction LAPP KABEL Conductors: Stranded tinned copper ETHERLINE® CAT.6 Designed with 4 pairs, a foil and braid shield, and a rugged PUR jacket, this ETHERLINE® cable meets CAT.6 requirements. It can be used in continuous flex applications. Pairs: 4 pairs divided by central filler element Insulation: Polypropylene Shielding: FRNC inner jacket; foil and braid Jacket: Polyurethane; green Recommended Applications Application Advantage Continuous flex applications; cable tracks; cordsets •P  UR outer jacket is highly resistant to oils, abrasion, and UV radiation • Premium screening against EMI Approvals Cable Attributes page 640 OIL OR-04 FLAME FR-02 MOTION CF-01 MECH. MP-05 Complete the Installation SKINTOP® MS-SC page 516 ÖLFLEX® CONNECT Solution RJ45 Connectors page 251 ÖLFLEX® CONNECT CABLES page 597 Technical Data Minimum Bend Radius: - for stationary use: 4 x cable diameter - for continuous flexing: 7.5 x cable diameter Test Voltage: 700V Temperature Range: - for stationary use: -40°C to +80°C - for continuous flexing: -30°C to +70°C Color Code: White & blue, white & orange, white & green, white & brown Characteristic Impedance: 100Ω ± 15Ω Nominal Voltage: 100V (not for power applications) Part Number Size / Pairs CAT.6 Cable 2170488* 26 AWG/4pr * Max cable run: 196 ft (60 m) Approvals: UL: CMX Canada: c(UL) CMX Additional: RoHS Stranding Jacket Material Jacket Color Approvals Fast Connect 19 wire PUR Green UL/CSA CMX No Nominal Outer Diameter (in) (mm) 0.307 7.8 Approx. Weight (lbs/mft) SKINTOP® MS-SC PG Thread 42 53112220 Recommended SKINTOP® assumes minimal OD variance. Additional configurations are available; please see our SKINTOP® section. If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. 242 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com
2170488 价格&库存
很抱歉,暂时无法提供与“2170488”相匹配的价格&库存,您可以联系我们找货
