AIP0530GX-2R2MPBDG
AIP0530GX-2R2MPBDG
    INPAQ(台湾佳邦)
    SMD,5.7x5.4mm
    2.2 µH 屏蔽 模制 电感器 9.2 A 14.5 毫欧最大 非标准
AIP0530GX-2R2MPBDG 数据手册
PRODUCT SPECIFICATION DOCUMENT NO. ENS000141290 DESCRIPTION DRAWN BY DESIGNED BY CHECKED BY APPROVED BY AIP0530GX Series Irene Peter Logan Phil INPAQ TECHNOLOGY CO., LTD. RoHS Pb Molding Type Power Choke ◢ Scope Features - Thickness max. 3mm. - Flux shielded structure, low radiation. - High saturation current realized by coil design and alloy powder. - Low power loss and temperature rising realized by low DC Resistance. - Low AC loss realized by powder, binder and structure design. - 100% Pb free meet RoHS standard. Applications - 5G - ADAS / Infotainment - Server / Industry / VGA - Desktop / NB / MB - DC to DC converter in low profile high current system such as CPU, VRM, V-core, VGA card…etc. ◢ Explanation of Part Number A I P 0 5 3 0 GX - 1 R 0MP B DG Control code Tolerance M : ±20% Inductance R24=0.24μH ; 1R0=1.0μH ; 100=10μH Type Name Dimensions Product TITLE : AIP0530GX Series Engineering Specification DOCUMENT NO. ENS000141290 Product Code SPEC REV.:A0 Page 2 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40 INPAQ TECHNOLOGY CO., LTD. ◢ Dimensions Code Dimensions[mm] A 5.7 ±0.3 B 5.4 ±0.3 C 3.0 max D 4.2 ±0.3 E 2.0 ±0.3 F 2.4 ±0.3 ◢ Recommended land pattern Code Dimensions[mm] TITLE : AIP0530GX Series Engineering Specification DOCUMENT NO. ENS000141290 A 4.7 B 2 C 4.6 SPEC REV.:A0 Page 3 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40 INPAQ TECHNOLOGY CO., LTD. ◢ Marking The inductor is marked with a 3-digit code (using ink for marking). Example: R24 means 0.24μH 1R0 means 1.0μH 100 means 10μH 1R0 TITLE : AIP0530GX Series Engineering Specification DOCUMENT NO. ENS000141290 SPEC REV.:A0 Page 4 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40 INPAQ TECHNOLOGY CO., LTD. ◢ Specifications 0530 Series PN Li [μH] Rdc [mΩ] Isat [A] Irms [A] SRF [MHz] Initial Value DC resistance Li drop 30% Temp. rising 40℃ Resonance +/-20% typ. max. typ. max. typ. max. typ. AIP0530GX-1R0MPBDG 1 7.2 8.5 17 14 11.1 10.5 55 Notes 1. Test environment of all data is referenced to 25°C ambient. 2. Test conditions: 1MHz, 1Vrms. 3. Isat : DC current (A) that will cause L to drop approximately 30%. 4. Irms : DC current (A) that will cause an approximate ΔT of 40°C(reference ambient temperature is 25°C). 5. Operating temperature range – 40°C to +125°C. 6. The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions. PCB land pattern, trace size - thick, circuit design and proximity to other components are all the factors will affect the temperature performance of the device. Therefore should be approved in application conditions and end product. 7. Rdc Measured with DC resistance meters RM3543(HIOKI) or equivalent. TITLE : AIP0530GX Series Engineering Specification DOCUMENT NO. ENS000141290 SPEC REV.:A0 Page 5 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40 INPAQ TECHNOLOGY CO., LTD. ◢ Bias Properties ◢ Frequency Response TITLE : AIP0530GX Series Engineering Specification DOCUMENT NO. ENS000141290 SPEC REV.:A0 Page 6 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40 INPAQ TECHNOLOGY CO., LTD. ◢ Recommendable Reflow Soldering Profile Feature Preheat - Temperature Min(Tsmin) - Temperature Max(Tsmax) - Time (ts) from (Tsmin to Tsmax) 150°C 200°C 60-120 seconds Ramp-up rate (TL to TP) 1°C / second max. Liquidous temperature(TL) Time (t) maintained above TL 217°C 60-120 seconds Peak package body temperature(TP) Time within 5°C of actual peak temperature(tp) Ramp-down rate (TP to TL) 250°C 10-20 seconds 6°C / second max. Time 25°C to peak temperature Number of Reflow cycles allowed TITLE : AIP0530GX Series Engineering Specification Pb-Free Assembly DOCUMENT NO. ENS000141290 6 minutes max. 2 cycles max. SPEC REV.:A0 Page 7 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40 INPAQ TECHNOLOGY CO., LTD. ◢ Tape & Reel ► Reel dimensions (unit: mm) Type A B C D 13’x12 13±0.2 100±0.2 13+0.3/-0.1 330±1.0 ► Tape dimensions (unit: mm) Type AIP0530GX W P1 P0 P2 D0 D1 t A0 B0 K0 E F 12 8 4 2 1.5 0.35 5.7 5.9 3.25 1.75 5.5 NIL ±0.3 ±0.1 ±0.1 ±0.1 +0.1 ±0.05 ±0.1 ±0.1 ±0.1 ±0.1 ±0.1 TITLE : AIP0530GX Series Engineering Specification DOCUMENT NO. ENS000141290 SPEC REV.:A0 Page 8 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40 INPAQ TECHNOLOGY CO., LTD. ► Taping Drawings ► Taping Package Storage Condition Storage Temperature: 5 to 40°C Relative Humidity: < 65%RH Storage Time: 12 months max ► Label Marking The label specified as follows shall be put on the side of reel. (1) (2) (3) Part No. Quantity. Lot No. * Part No. And Quantity shall be marked on outer packaging. ► Quantity of products in the package Type Reel Inner Box Outer Box AIP0530GX 2000 4000 20000 TITLE : AIP0530GX Series Engineering Specification DOCUMENT NO. ENS000141290 SPEC REV.:A0 Page 9 of 9 www.inpaq.com.tw ; www.inpaqgp.com B I-FM-04-40
AIP0530GX-2R2MPBDG 价格&库存
很抱歉,暂时无法提供与“AIP0530GX-2R2MPBDG”相匹配的价格&库存,您可以联系我们找货
