KRTBAELPS2.32
KRTBAELPS2.32
    AMSOSRAM(艾迈斯半导体)
    可寻址照明 - 1 LED 离散式 红色,绿色,蓝色(RGB) 5.50mm 长 x 1.80mm 宽
KRTBAELPS2.32 数据手册
www.osram-os.com KRTB AELPS2.32 DATASHEET KRTBAELPS2.32 Datasheet   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All reserved | Version 1.0 | 2022-09-06 1 rights KRTB AELPS2.32 DATASHEET OSIRE® E5515 KRTB AELPS2.32 The ams OSRAM OSIRE KRTB AELPS2.32 RGB sidelooker device is specifically designed for automotive interior applications. It offers individually addressable LED chips for a maximum of flexibility in terms of color point, driver selection and interconnection. Due to the low profile, the OSIRE KRTB AELPS2.32 is ideally suited for coupling into thin lightguides and enables ultra compact designs. The housing material´s temperature stability has been optimized for improved compatibility to suitable IMSE® (In-mold structural electronics) processing. Applications - Ambient Lighting - Automotive Aftermarket Features  - Functional Illumination - Package: white SMT package, colorless clear silicone resin - Chip technology: Thinfilm / UX:3 - Typ. Radiation: 120° (Lambertian emitter) - Color: λdom = 625 nm (● red); λdom = 528 nm (● true green); λdom = 465 nm (● blue) - Corrosion Robustness Class: 3B - Qualifications: AEC-Q102 Qualified  - ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) 2 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Ordering Information  Type Brightness 1) Ordering Code KRTBAELPS2.32-1V7A-JW+6B5C-D8+3S4U-7Z Q65113A4846 ● red ● Iv = 710 ... 1590 mcd (IF = 20 mA) Q65113A4846 ● true green ● Iv = 2010 ... 3150 mcd (IF = 20 mA) Q65113A4846 ● blue ● Iv = 224 ... 710 mcd (IF = 20 mA) Q65113A4846   3 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Maximum Ratings  Parameter Symbol Values ● red Values ● true green Values ● blue Operating Temperature  Top min. max. -40 °C 110 °C -40 °C 110 °C -40 °C 110 °C Storage Temperature  Tstg min. max. -40 °C 110 °C -40 °C 110 °C -40 °C 110 °C Junction Temperature  Tj max. 125 °C 125 °C 125 °C Forward Current  TS = 25 °C IF min. max. 5 mA 50 mA 5 mA 50 mA 5 mA 50 mA Surge Current  t ≤ 10 µs; D = 0.005 ; TS = 25 °C IFS max. 100 mA 300 mA 300 mA Reverse voltage 2) TS = 25 °C VR max. 5V 5V ESD withstand voltage  acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD 2 kV 2 kV Reverse voltage 3) VR   4 | Version 1.0 | 2022-09-06 2 kV Not designed Not designed Not designed for reverse for reverse for reverse operation operation operation KRTB AELPS2.32 DATASHEET Characteristics  IF = 20 mA; TS = 25 °C Parameter Symbol Values ● red Values ● true green Values ● blue Peak Wavelength  λpeak typ. 632 nm 523 nm 462 nm Dominant Wavelength 4) λdom min. typ. max. 620 nm 625 nm 632 nm 519 nm 528 nm 546 nm 447 nm 465 nm 476 nm Spectral bandwidth at 50% Irel,max  ∆λ typ. 18 nm 33 nm 25 nm Viewing angle at 50% IV  2φ typ. 120 ° 120 ° 120 ° Forward Voltage  IF = 20 mA VF min. typ. max. 1.60 V 1.95 V 2.30 V 2.10 V 2.60 V 3.00 V 2.50 V 2.85 V 3.20 V Reverse current 3) IR Real thermal resistance junction/solderpoint 6) RthJS real 5)   5 | Version 1.0 | 2022-09-06 Not designed Not designed Not designed for reverse for reverse for reverse operation operation operation typ. max. 53 K / W 78 K / W 38 K / W 52 K / W 30 K / W 48 K / W KRTB AELPS2.32 DATASHEET Brightness Groups  ● red Group Luminous Intensity 1) IF = 20 mA min. Iv Luminous Intensity 1) IF = 20 mA max. Iv 1V 710 mcd 800 mcd 2V 800 mcd 900 mcd 3V 900 mcd 1000 mcd 4V 1000 mcd 1120 mcd 5A 1120 mcd 1250 mcd 6A 1250 mcd 1400 mcd 7A 1400 mcd 1590 mcd Brightness Groups  ● true green Group Luminous Intensity 1) IF = 20 mA min. Iv Luminous Intensity 1) IF = 20 mA max. Iv 6B 2010 mcd 2240 mcd 7B 2240 mcd 2500 mcd 8B 2500 mcd 2800 mcd 2800 mcd 3150 mcd   5C 6 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Brightness Groups  ● blue Group Luminous Intensity 1) IF = 20 mA min. Iv Luminous Intensity 1) IF = 20 mA max. Iv 3S 224 mcd 250 mcd 4S 250 mcd 280 mcd 1T 280 mcd 315 mcd 2T 315 mcd 355 mcd 3T 355 mcd 400 mcd 4T 400 mcd 450 mcd 1U 450 mcd 500 mcd 2U 500 mcd 560 mcd 3U 560 mcd 630 mcd 4U 630 mcd 710 mcd   7 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Wavelength Groups  ● red Group Dominant Wavelength 4) min. λdom Dominant Wavelength 4) max. λdom JP 620 nm 625 nm MT 623 nm 629 nm RW 627 nm 632 nm Wavelength Groups  ● true green Group Dominant Wavelength 4) min. λdom Dominant Wavelength 4) max. λdom DJ 519 nm 524 nm FL 521 nm 526 nm JP 524 nm 529 nm LR 526 nm 531 nm PU 529 nm 534 nm RW 531 nm 536 nm U3 534 nm 541 nm 18 539 nm 546 nm   8 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Wavelength Groups  ● blue Group Dominant Wavelength 4) min. λdom Dominant Wavelength 4) max. λdom 73 447 nm 451 nm 51 449 nm 453 nm 3C 451 nm 456 nm AF 454 nm 459 nm DH 457 nm 461 nm FK 459 nm 463 nm HM 461 nm 465 nm KP 463 nm 467 nm MS 465 nm 470 nm QV 468 nm 473 nm TZ 471 nm 476 nm   9 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Chromaticity Coordinate Groups KRTBAELPS2.32 Cy 0,8 550 nm 0,7 0,6 500 nm 0,5 0,4 600 nm 0,3 700 750 nm 0,2 0,1 400 380 nm 0,0 0,0 0,1 0,2 0,3 0,4 0,5 0,6 0,7 Cx Chromaticity Coordinate Groups  ● red Group Cx Cy JP 0.6879 0.3086 0.6915 0.3083 0.7006 0.2993 0.6969 0.2996 0.6936 0.3030 0.6972 0.3027 0.7066 0.2934 0.7028 0.2938 0.7000 0.2966 0.7037 0.2962 0.7105 0.2895 0.7067 0.2899 MT   RW 10 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Chromaticity Coordinate Groups  ● true green Group Cx Cy 18 0.2362 0.7067 0.2288 0.7353 0.2752 0.7042 0.2776 0.6881 0.1401 0.6951 0.1201 0.7325 0.1415 0.7518 0.1606 0.7102 0.1486 0.7014 0.1273 0.7439 0.1517 0.7547 0.1698 0.7127 0.1606 0.7102 0.1415 0.7518 0.1679 0.7565 0.1831 0.7174 0.1694 0.7136 0.1517 0.7547 0.1794 0.7549 0.1933 0.7170 0.1831 0.7174 0.1678 0.7565 0.1973 0.7500 0.2091 0.7142 0.1932 0.7170 0.1794 0.7549 0.2098 0.7449 0.2196 0.7122 0.2091 0.7142 0.1974 0.7500 0.2419 0.7273 0.2474 0.7029 DJ FL JP LR PU  RW  U3 11 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Chromaticity Coordinate Groups  ● blue Group Cx Cy 3C 0.1588 0.0243 0.1556 0.0186 0.1500 0.0246 0.1543 0.0317 0.1606 0.0222 0.1576 0.0168 0.1534 0.0206 0.1570 0.0268 0.1622 0.0203 0.1595 0.0152 0.1556 0.0186 0.1588 0.0243 0.1562 0.0285 0.1524 0.0219 0.1462 0.0293 0.1509 0.0370 0.1532 0.0332 0.1489 0.0262 0.1436 0.0332 0.1487 0.0414 0.1509 0.0370 0.1462 0.0293 0.1407 0.0376 0.1463 0.0463 0.1487 0.0414 0.1436 0.0332 0.1375 0.0428 0.1436 0.0519 0.1463 0.0463 0.1407 0.0376 0.1338 0.0493 0.1404 0.0588 51 73 AF DH FK  HM  KP 12 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Chromaticity Coordinate Groups  ● blue Group Cx Cy MS 0.1436 0.0519 0.1375 0.0428 0.1272 0.0620 0.1354 0.0727 0.1389 0.0631 0.1317 0.0532 0.1199 0.0785 0.1295 0.0899 0.1335 0.0779 0.1251 0.0672 0.1115 0.1000 0.1231 0.1122 QV TZ   13 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Relative Spectral Emission 7) Irel = f (λ); IF = 20 mA; TS = 25 °C Irel KRTB AELPS1.32 EN 1.0 : Vλ : red : true green : blue 0.8 0.6 0.4 0.2 0.0 350 400 Radiation Characteristics 450 500 550 600 650 700 750 800 λ / nm 7) Irel = f (ϕ); TS = 25 °C KRTB AELPS1.32 EN ϕ/°  -40° -50° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° 1.0 -30° 0.8 0.6 -60° -70° 0.4 -80° 0.2 -90° 0.0  -100° 14 | Version 1.0 | 2022-09-06 Irel KRTB AELPS2.32 DATASHEET Forward current Forward current 7) IF = f(VF); TS = 25 °C IF / mA IF = f(VF); TS = 25 °C KRTB AELPS2.32 50 IF / mA : true green 30 30 20 20 10 10 2.2 2.4 2.6 2.8 3.0 3.2 3.5 VF / V Forward current 7) IF = f(VF); TS = 25 °C IF / mA : blue 40 2 KRTB AELPS2.32 50 : red 40  30 20 10 5 1.3 1.6 1.8 2.0 2.2 2.4 2.6 2.9  VF / V 15 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 50 40 5 7) 5 2.32.4 2.6 2.8 3.0 3.2 3.4 3.6 VF / V KRTB AELPS2.32 DATASHEET Relative Luminous Intensity 7), 8) Iv/Iv(20 mA) = f(IF); TS = 25 °C IV IV(20mA) 7), 8) Iv/Iv(20 mA) = f(IF); TS = 25 °C KRTB AELPS2.32 IV KRTB AELPS2.32 2.0 Relative Luminous Intensity IV(20mA) : true green : blue 2.0 1.5 1.5 1.0 1.0 0.5 0.5 IF / mA Relative Luminous Intensity 7), 8) Iv/Iv(20 mA) = f(IF); TS = 25 °C IV KRTB AELPS2.32 2.5 IV(20mA) : red  2.0 1.5 1.0 0.5 50 40 45 35 30 20 25 15 5 10 0.0  IF / mA 16 | Version 1.0 | 2022-09-06 45 50 40 35 25 30 20 15 5 10 50 40 45 35 30 20 25 15 5 0.0 10 0.0 IF / mA KRTB AELPS2.32 DATASHEET Dominant Wavelength Dominant Wavelength 7) Δλdom = f(IF); TS = 25 °C ∆λ dom / nm Δλdom = f(IF); TS = 25 °C KRTB AELPS2.32 10 7) ∆λ dom / nm : true green KRTB AELPS2.32 8 : blue 6 5 4 2 0 0 -2 -5 -4 -6 IF / mA   17 | Version 1.0 | 2022-09-06 45 50 40 35 25 30 20 15 5 10 50 40 45 35 30 20 25 15 5 -8 10 -10 IF / mA KRTB AELPS2.32 DATASHEET Forward Voltage Forward Voltage 7) ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA KRTB AELPS2.32 ∆VF / V 7) : true green ∆VF / V KRTB AELPS2.32 0.3 : blue 0.4 0.2 0.1 0.2 0.0 0.0 -0.1 -0.2 -0.2 -40 -20 0 20 40 60 80 100 120 Tj / °C Forward Voltage 7) ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ∆VF / V KRTB AELPS2.32 0.3 : red  0.2 0.1 0.0 -0.1 -0.2 -0.3 -40 -20 0 20 40 60 80 100 120  Tj / °C 18 | Version 1.0 | 2022-09-06 -0.3 -40 -20 0 20 40 60 80 100 120 Tj / °C KRTB AELPS2.32 DATASHEET Relative Luminous Intensity 7) Iv/Iv(25 °C) = f(Tj); IF = 20 mA Iv Iv(25°C) Iv : true green : blue 0.8 0.8 0.6 0.6 0.4 0.4 0.2 0.2 20 40 60 80 100 120 Tj / °C Relative Luminous Intensity 7) Iv/Iv(25 °C) = f(Tj); IF = 20 mA Iv Iv(25°C) 1.0 0 KRTB AELPS2.32 1.6 Iv(25°C) : red 1.4  1.2 1.0 0.8 0.6 0.4 0.2 0.0 -40 -20 0 20 40 60 80 100 120  Tj / °C 19 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 1.2 1.0 0.0 -40 -20 7) Iv/Iv(25 °C) = f(Tj); IF = 20 mA KRTB AELPS2.32 1.2 Relative Luminous Intensity 0.0 -40 -20 0 20 40 60 80 100 120 Tj / °C KRTB AELPS2.32 DATASHEET Dominant Wavelength Dominant Wavelength 7) Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 20 mA ∆λ dom / nm Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 20 mA KRTB AELPS2.32 KRTB AELPS2.32 10 7) ∆λ dom / nm : true green 8 : blue 8 6 6 4 4 2 2 0 0 -2 -2 -4 -4 -6 -6 -8 -40 -20 0 20 40 60 80 100 120 Tj / °C Dominant Wavelength 7) Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 20 mA KRTB AELPS2.32 ∆λ dom / nm 8 : red  6 4 2 0 -2 -4 -6 -8 -10 -40 -20 0 20 40 60 80 100 120  Tj / °C 20 | Version 1.0 | 2022-09-06 -40 -20 0 20 40 60 80 100 120 Tj / °C KRTB AELPS2.32 DATASHEET Max. Permissible Forward Current Max. Permissible Forward Current IF = f(T); ● true green IF = f(T); ● blue 55 one chip on IF / mA 50 45 45 40 40 35 35 30 : Ts 25 15 15 10 10 5 5 20 40 60 80 100 T / °C Max. Permissible Forward Current IF = f(T); ● red 55 one chip on 50  45 40 red 35 30 : Ts 25 20 15 10 5 0 0 20 40 60 80 100  T / °C 21 | Version 1.0 | 2022-09-06 : Ts 25 20 0 one chip on 30 20 0 IF / mA 55 50 blue true green IF / mA 0 0 20 40 60 80 100 T / °C KRTB AELPS2.32 DATASHEET Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C; ● true green IF = f(tp); D: Duty cycle; TS = 25 °C; ● blue KRTB AELPS2.32 KRTB AELPS2.32 TS = 0°C ... 110°C TS = 0°C ... 110°C IF / A IF / A 0,3 : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0,2 blue true green 0,3 0,1 0,2 0,1 10 -6 10-5 10 -4 10 -3 0,01 0,1 1 10 -6 10 / Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TS = 25 °C; ● red KRTB AELPS2.32 TS = 0°C ... 110°C IF / A : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0,12  0,10 red : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0,08 0,06 10 -6 10-5 10 -4 10 -3 0,01 0,1 1 10  / 22 | Version 1.0 | 2022-09-06 10-5 10 -4 10 -3 0,01 0,1 1 10 / KRTB AELPS2.32 DATASHEET Dimensional Drawing 9) Further Information: Approximate Weight: 26.0 mg Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43)   23 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Electrical Internal Circuit   24 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Recommended Solder Pad 9) For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for any kind of wet cleaning or ultrasonic cleaning.   25 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 26 | Version 1.0 | 2022-09-06 °C 480 s K/s s KRTB AELPS2.32 DATASHEET Taping 9)   27 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Tape and Reel 10) Reel Dimensions A 180 mm W Nmin 12 + 0.3 / - 0.1 mm   28 | Version 1.0 | 2022-09-06 W1 60 mm W2 max 12.4 + 2 mm 18.4 mm Pieces per PU 2000 KRTB AELPS2.32 DATASHEET Barcode-Product-Label (BPL) Dry Packing Process and Materials 9) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 29 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   30 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on our website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications Our components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. Our products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using our components in product safety devices/ applications or medical devices/applications, buyer and/or customer has to inform our local sales partner immediately and we and buyer and /or customer will analyze and coordinate the customer-specific request between us and buyer and/or customer.   31 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Glossary 1) Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of k = 3). 2) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 3) Reverse Operation: Not designed for reverse operation. Continuous reverse operation can cause migration and damage of the device. 4) Wavelength: The wavelength is measured at a current pulse of typically 25 ms, with an internal reproducibility of ±0.5 nm and an expanded uncertainty of ±1 nm (acc. to GUM with a coverage factor of k = 3). 5) Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage factor of k = 3). 6) Thermal Resistance: Rth max is based on statistic values (6σ). 7) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 8) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 9) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 10) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   32 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET Revision History Version Date Change 1.0 2022-09-06 Initial Version   33 | Version 1.0 | 2022-09-06 KRTB AELPS2.32 DATASHEET   Published by ams-OSRAM AG Tobelbader Strasse 30, 8141 Premstaetten, Austria Phone +43 3136 500-0 ams-osram.com © All rights reserved 34 | Version 1.0 | 2022-09-06
KRTBAELPS2.32 价格&库存
很抱歉,暂时无法提供与“KRTBAELPS2.32”相匹配的价格&库存,您可以联系我们找货
KRTBAELPS2.32
  • 1+9.227371+1.11454
  • 10+5.6546210+0.68300
  • 100+3.83589100+0.46333
  • 500+3.12140500+0.37703
  • 1000+2.902141000+0.35054
库存:5582
KRTBAELPS2.32
  • 2000+2.722552000+0.32885
  • 4000+2.575334000+0.31107
  • 6000+2.501846000+0.30219
  • 10000+2.4206010000+0.29238
  • 14000+2.3732214000+0.28666
  • 20000+2.3277420000+0.28116
库存:5582
