QLSP08RGB_B
(5050 Black-Face Multi-Color LED)
QLSP08RGB_B V1.2
Product Outline:
This is a multi-color LED that provides high lumen output in the 5050 package. Creating a
small optical light source because of the compact design it’s ideal for color mixing
applications
Features:
Tri-Color LED, Red/Green/Blue LED
With Black-face Lead frame
High brightness output @ 20mA,
Package Dimension = 5.4mmX5.0mmX1.45mm
RoHS compliant
Reflow solderable- JEDEC J-STD-020
Custom Bin available upon special request
View angel >120°
Resin color by diffused white
Application:
Stage lighting,
Architecture Lighting
Garden Lighting
Indoor directional lighting
Entertainment lighting.
Compliance and Certification:
1
QLSP08RGB_B V1.2
Mechanical Property:
(Dimension)
* All dimensions are in millimeters,
* Tolerances are ± 0.10mm.
2
QLSP08RGB_B V1.2
Recommended Solder footprint:
* All dimensions are in millimeters.
* The LEDs is designed to be reflow soldered on to a PCB. IF dip soldered that QL cannot guarantee its
reliability.
* Reflow soldering must not be performed more than twice.
Characteristics
◼ Absolute Maximum Ratings
(Ta=25℃)
Parameter
Symbol
Rating
Unit
DC Forward Current
If
mA
Leakage Current (5V)
Ir
10
μA
Total Power Dissipation
Pd
180
mW
Pulse Forward Current
Ifp
30
mA
LED Junction Temperature
TJ
120
Storage Temperature
Tstg
-40 ~ 100
Operation Temperature
Topr
-40 ~ 85
Soldering Temperature
Tsol
260 < 10 sec
(1) Proper current rating must be observed to maintain junction temperature below maximum at all time
(2) IFP Condition: Duty 1/10, Pulse within 10msec
3
QLSP08RGB_B V1.2
Electrical / Optical Characteristic
Parameter
Symbol Condition
Forward Voltage - Red
Vf
Forward Voltage – Green
Vf
Forward Voltage - Blue
Vf
View Angle
θ
20mA
(Ta=25 oC)
Min.
Typ.
Max.
Unit
2.0
2.4
V
3.0
3.4
V
3.0
3.4
V
125
deg
(1) Tolerance of measurement: VF=+/- 0.1V
◼ Specification
Product
Color Condition
Red
QLSP08RGB_B
Green
Blue
20mA
Vf(V)
Typ.
Dominant
Wavelength
(nm)
Luminous
Intensity
(mcd)
Min.
Typ.
2.2
620~630
600
700
3.2
515~530
1400
1500
3.2
460~470
400
500
*Tolerance = +/- 10%
4
QLSP08RGB_B V1.2
◼ Groups
Dominant Wavelength
Wd (nm) @20mA
Color
Red
Green
Blue
Code name
Min.
Max.
A8
A9
DM
DN
DP
DC
DD
620
625
515
520
525
460
465
625
630
520
525
530
465
470
Measurement tolerance is +/- 1nm
Forward Voltage (VF) Bin:
VF Rank@20mA
Color
Code name
Low
High
Red
Green/Blue
R4
24
2.0
3.0
2.4
3.4
The forward voltage tolerance is ± 0.1V
Luminous Intensity Bin:
Rank (mcd)@20mA
Color
Code name
Low
High
Red
P31
600
800
Green
N102
1400
1600
Blue
N32
400
600
luminous flux tolerance is ± 7%
5
QLSP08RGB_B V1.2
Characteristic Curves
(1) Color Spectrum
(2). Typical Representative Spatial Radiation Pattern
6
QLSP08RGB_B V1.2
(3). Forward Current Characteristics
(4). Forward Current vs Forward Voltage
7
QLSP08RGB_B V1.2
◼ Reliability test:
No
Item
Condition
Time/Cycle
Sample
size
1
Steady State Operating Life of Room
Temperature
25℃ Operating
1000 Hrs
20 pcs
2
Steady State Operating Life of Low
Temperature -40℃
-40℃ Operating
1000 Hrs
20 pcs
3
Temperature 60℃
60℃ Operating
1000 Hrs
20 pcs
4
Temperature 85℃
85℃ Operating
1000 Hrs
20 pcs
5
Low temperature storage -40℃
-40℃ Storage
1000 Hrs
20 pcs
6
High temperature storage 100℃
100℃ Storage
1000 Hrs
20 pcs
7
Steady State Operating Life of High
Humidity Heat 60℃90%
60oC/90% Operating
1000 Hrs
20 pcs
8
Steady State
Condition
25℃10Hz duty=1/10 Operating
200 Cycle
20 pcs
9
Resistance to soldering heat on PCB
(JEDEC MSL3)
pre-store@60℃, 60%RH for
52hrs Tsld max.=260 10sec
3 Times
20 pcs
10
Heat Cycle Test (JEDEC MRC)
25℃~65℃~-10℃, 90%RH,
24hr/1cycle
10 Cycle
20 pcs
11
Thermal shock
-40℃/ 20minr~ 5minr~100℃
/20min
300 Cycle
20 pcs
Pulse Operating Life
◼ Judgment Criteria:
Item
Symbol
Test Condition
Judgment
Criteria
Forward Voltage
Vf
20 mA
△Vf< 10%
Luminous Flux
Iv
20 mA
△Iv< 30%
8
QLSP08RGB_B V1.2
Solder Profile:
-The recommended reflow soldering profile is as follows (temperatures indicated are as
measured on the surface of the LED resin):
Note:
Taping & Packing:
Unit : mm
9
QLSP08RGB_B V1.2
10
QLSP08RGB_B V1.2
Labeling
Ordering Information:
Part #
QLSP08RGB_B
Multiple Quantities
Quantity per Reel
1000 pcs
11
QLSP08RGB_B V1.2
Revision History:
Revision Date:
Changes:
Version #:
09-23-2019
Initial release
1.0
12-21-2019
Revised the solder pin to swap led color places
1.1
09-17-2023
Revised the quantity per reel to 1K
1.2
12
很抱歉,暂时无法提供与“QLSP08RGB_B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.915131+0.37695
- 10+2.0042910+0.25917
- 100+1.41283100+0.18269
- 500+1.14513500+0.14808
- 国内价格 香港价格
- 1000+1.056651000+0.13664
- 2000+0.981372000+0.12690
- 3000+0.942623000+0.12189
- 5000+0.898795000+0.11622
- 7000+0.872677000+0.11285
- 10000+0.8471710000+0.10955
