TLL122-N1500
Adjustable float switch
Document ref.: DDS_TLL122-N1500_R1.DOCX
25-Jan-21
Rev. 1
The TLL122 is a user adjustable vertical float switch. This float switch can be tailored by the user to suit a
particular application, by adjusting the length of the float switch tube. It is also possible to select the
switching sense by inverting the float, giving either open on rise or close on rise operation.
Mounting is via the 1” NPT header.
The unit is supplied part assembled, with detailed instructions for the user to complete assembly to the
specifications of the application and to install the unit.
Part
Description
Prod. Group
Liquid
Connector
Thread
Length
TLL122-N1500
Adjustable float switch 1"NPT Mounting
Thread, 1500 mm long.
Float Switch, Adjustable
Diesel, Water
DIN 43650
1" NPT
1500 mm
Materials
Header
Stem
Float
Float Stop
Gasket
Flange
Brass
Brass
Polypropylene
304 Stainless Steel
Klingersil C4324
Brass
Ratings
Sealing
Temperature
IP67 if fitted with mating connector
-20 to +70 C
Electricals
Max Voltage
Max Current
Max Power
250 VAC/VDC
1A
10 VA
5
Rochester Gauges, LLC 11616 Harry Hines Blvd., P.O. Box 29242, Dallas, TX 75229, USA
+1(972) 241-2161
rochestergauges.com info@rochestergauges.com
E. & O. E. Rochester Gauges LLC and Fozmula Limited expects that you will conduct the testing and evaluation necessary to determine that these
products are suitable for your application. Materials and specifications are subject to change without notice.
JP 10-Jan-21 5.10 Rev. 1
很抱歉,暂时无法提供与“TLL122-N1500”相匹配的价格&库存,您可以联系我们找货
